Commit 24ba0209 authored by Thonier Florian's avatar Thonier Florian Committed by Mathieu Giraud
index.html: menu entry
parent 0ca30a56
...@@ -213,6 +213,13 @@ ...@@ -213,6 +213,13 @@
<div class="buttonSelector" onclick="m.changeCloneNotation('full_sequence', true)"><input id="menuCloneNotSeq" type="radio" name="show_name" value="full_sequence" /><label for="menuCloneNotSeq">sequence (always)</label></div> <div class="buttonSelector" onclick="m.changeCloneNotation('full_sequence', true)"><input id="menuCloneNotSeq" type="radio" name="show_name" value="full_sequence" /><label for="menuCloneNotSeq">sequence (always)</label></div>
</div> </div>
<div class="menu_box">
primer set</br>
<div class="buttonSelector" onclick="m.switchPrimersSet('biomed2')"><input type="radio" id="primerBiomed2" name="primers" value="biomed2" /><label for="primerBiomed2">biomed2</label></div>
<!-- TODO : construire liste à partir des data disponibles/chargées dans le model.
TODO : passer ça en liste deroulante ? -->
</div>
<div class="submenu" id="system_menu" style="display:none"> <div class="submenu" id="system_menu" style="display:none">
<div class="menu_box"> <div class="menu_box">
