Commit 229c41bd authored by Mikaël Salson's avatar Mikaël Salson
testAffectAnalyser: Differentiate depending on index.
Depending on the length of the affectation, we may not have the same results
parent 85622c02
...@@ -142,11 +142,16 @@ void testAffectAnalyser2() { ...@@ -142,11 +142,16 @@ void testAffectAnalyser2() {
TAP_TEST(ckaa.max() == KmerAffect::getUnknown(), TAP_TEST(ckaa.max() == KmerAffect::getUnknown(),
TEST_COUNT_AA_MAX, "max is " << ckaa.max()); TEST_COUNT_AA_MAX, "max is " << ckaa.max());
for (int i = 4; i < 14 - k; i++) for (int i = 4; i < 14 - k; i++)
TAP_TEST(kaa.getAffectation(i - k + 1) == kaa.getAllAffectations(AO_NONE)[i - k + 1], TEST_AA_GET_ALL_AO_NONE, ""); TAP_TEST(kaa.getAffectation(i - k + 1) == kaa.getAllAffectations(AO_NONE)[i - k + 1], TEST_AA_GET_ALL_AO_NONE, "");
TAP_TEST(kaa.getAffectation(0) == kaa.getAllAffectations(AO_NO_CONSECUTIVE)[0], TEST_AA_GET_ALL_AO_NO_CONSECUTIVE, ""); TAP_TEST(kaa.getAffectation(0) == kaa.getAllAffectations(AO_NO_CONSECUTIVE)[0], TEST_AA_GET_ALL_AO_NO_CONSECUTIVE, "");
TAP_TEST(kaa.getAllAffectations(AO_NO_CONSECUTIVE).size() == 4, TEST_AA_GET_ALL_AO_NO_CONSECUTIVE, "size = " << kaa.getAllAffectations(AO_NO_CONSECUTIVE).size()); if (kaa.count() == sequence.length() - k + 1) {
} else if (kaa.count() == sequence.length()) {
TAP_TEST(kaa.getAllAffectations(AO_NO_CONSECUTIVE).size() == 5, TEST_AA_GET_ALL_AO_NO_CONSECUTIVE, "size = " << kaa.getAllAffectations(AO_NO_CONSECUTIVE).size());
TAP_TEST(kaa.getAffectation(1) == kaa.getAllAffectations(AO_NO_CONSECUTIVE)[1], TEST_AA_GET_ALL_AO_NO_CONSECUTIVE, "actual: " << kaa.getAllAffectations(AO_NO_CONSECUTIVE)[1] << ", expected: " << kaa.getAffectation(1)); TAP_TEST(kaa.getAffectation(1) == kaa.getAllAffectations(AO_NO_CONSECUTIVE)[1], TEST_AA_GET_ALL_AO_NO_CONSECUTIVE, "actual: " << kaa.getAllAffectations(AO_NO_CONSECUTIVE)[1] << ", expected: " << kaa.getAffectation(1));
TAP_TEST(kaa.getAffectation(2) == kaa.getAllAffectations(AO_NO_CONSECUTIVE)[2], TEST_AA_GET_ALL_AO_NO_CONSECUTIVE, kaa.getAllAffectations(AO_NO_CONSECUTIVE)[2] << ", expected: " << kaa.getAffectation(2)); TAP_TEST(kaa.getAffectation(2) == kaa.getAllAffectations(AO_NO_CONSECUTIVE)[2], TEST_AA_GET_ALL_AO_NO_CONSECUTIVE, kaa.getAllAffectations(AO_NO_CONSECUTIVE)[2] << ", expected: " << kaa.getAffectation(2));
TAP_TEST(kaa.getAllAffectations(AO_NO_CONSECUTIVE)[3] == kaa.getAffectation(10-k), TEST_AA_GET_ALL_AO_NO_CONSECUTIVE, kaa.getAllAffectations(AO_NO_CONSECUTIVE)[3] << ", expected: " << kaa.getAffectation(10-k)); TAP_TEST(kaa.getAllAffectations(AO_NO_CONSECUTIVE)[3] == kaa.getAffectation(10-k), TEST_AA_GET_ALL_AO_NO_CONSECUTIVE, kaa.getAllAffectations(AO_NO_CONSECUTIVE)[3] << ", expected: " << kaa.getAffectation(10-k));
Supports Markdown
