Commit 2149c28e authored by Ryan Herbert's avatar Ryan Herbert
Merge branch 'hotfix-s/fix-queued-jobs' into 'prod-server'
fix queued jobs
See merge request !256
(cherry picked from commit 711c754f)
3dc5bccb task.py: DONE also exists
parent de494035
Pipeline #34276 passed with stages
in 43 seconds
...@@ -152,7 +152,7 @@ def run_vidjil(id_file, id_config, id_data, grep_reads, ...@@ -152,7 +152,7 @@ def run_vidjil(id_file, id_config, id_data, grep_reads,
from datetime import timedelta as timed from datetime import timedelta as timed
## re schedule if pre_process is still pending ## re schedule if pre_process is still pending
if db.sequence_file[id_file].pre_process_flag != "COMPLETED" and db.sequence_file[id_file].pre_process_flag: if db.sequence_file[id_file].pre_process_flag not in ["COMPLETED", "DONE"] and db.sequence_file[id_file].pre_process_flag:
print("Pre-process is still pending, re-schedule") print("Pre-process is still pending, re-schedule")
