Commit 21392f8e authored by Mathieu Giraud's avatar Mathieu Giraud
tests watir: some $b.unselect... but this is not working now
$b.unselect was not working, we just comment it and do a workaround in some cases
parent e201eb6a
...@@ -142,6 +142,8 @@ class Browser < MiniTest::Test ...@@ -142,6 +142,8 @@ class Browser < MiniTest::Test
$b.clone_name_editor.set 'renamed_click' $b.clone_name_editor.set 'renamed_click'
$b.clone_name_saver.click $b.clone_name_saver.click
assert (clone_name.text == 'renamed_click'), " >> clone name has not changed" assert (clone_name.text == 'renamed_click'), " >> clone name has not changed"
$b.unselect
end end
def test_04_rename_clone_by_enter def test_04_rename_clone_by_enter
...@@ -152,7 +154,6 @@ class Browser < MiniTest::Test ...@@ -152,7 +154,6 @@ class Browser < MiniTest::Test
$b.send_keys :return $b.send_keys :return
assert (clone_name.text == 'renamed_return'), " >> clone name has not changed" assert (clone_name.text == 'renamed_return'), " >> clone name has not changed"
#unselect
$b.unselect $b.unselect
end end
...@@ -211,8 +212,8 @@ class Browser < MiniTest::Test ...@@ -211,8 +212,8 @@ class Browser < MiniTest::Test
check_when_list_or_scatterplot_clicked check_when_list_or_scatterplot_clicked
#unselect
$b.clone_in_scatterplot('24').click # TODO: to be removed when $b.unselect works
assert ($b.clone_in_list('25').class_name == "list"), ">> Incorrect class name, clone is not unselected'" assert ($b.clone_in_list('25').class_name == "list"), ">> Incorrect class name, clone is not unselected'"
end end
...@@ -222,8 +223,8 @@ class Browser < MiniTest::Test ...@@ -222,8 +223,8 @@ class Browser < MiniTest::Test
#unselect
end end
...@@ -238,6 +239,8 @@ class Browser < MiniTest::Test ...@@ -238,6 +239,8 @@ class Browser < MiniTest::Test
$b.menu_settings.click $b.menu_settings.click
$b.radio(:id => 'reset_norm').click $b.radio(:id => 'reset_norm').click
assert ( $b.clone_info('25')[:size].text == '0.130%' ) , ">> fail normalize off : wrong clone size " assert ( $b.clone_info('25')[:size].text == '0.130%' ) , ">> fail normalize off : wrong clone size "
$b.unselect
end end
def test_10_imgt def test_10_imgt
...@@ -182,7 +182,8 @@ class VidjilBrowser < Watir::Browser ...@@ -182,7 +182,8 @@ class VidjilBrowser < Watir::Browser
# Click in the back so that we unselect everything # Click in the back so that we unselect everything
def unselect def unselect
element(:id => "visu_back" ).click # TODO: is not working, 'Element is not clickable at point'
# element(:id => "visu_back" ).click
end end
# Return the div of the list of clones # Return the div of the list of clones
