Une MAJ de sécurité est nécessaire sur notre version actuelle. Elle sera effectuée lundi 02/08 entre 12h30 et 13h. L'interruption de service devrait durer quelques minutes (probablement moins de 5 minutes).
Commit 207059b4 authored by Mathieu Giraud's avatar Mathieu Giraud
Merge branch 'feature-s/1682-allow-user-to-modify-password' into 'dev'
Allow user to modify password
Closes #1682
See merge request !196
parents 4fe87a4a 5cf816ed
Pipeline #43419 failed with stages
in 5 minutes and 4 seconds
...@@ -57,30 +57,32 @@ def index(): ...@@ -57,30 +57,32 @@ def index():
reverse=reverse) reverse=reverse)
def edit(): def edit():
if auth.is_admin(): if auth.can_modify_user(int(request.vars['id'])):
user = db.auth_user[request.vars["id"]] user = db.auth_user[request.vars["id"]]
return dict(message=T("Edit user"), user=user) return dict(message=T("Edit user"), user=user)
return error_message(ACCESS_DENIED) return error_message(ACCESS_DENIED)
def edit_form(): def edit_form():
error = "" error = []
if request.vars["first_name"] == "" : if request.vars["first_name"] == "" :
error += "first name needed, " error.append("first name needed")
if request.vars["last_name"] == "" : if request.vars["last_name"] == "" :
error += "last name needed, " error.append("last name needed")
if request.vars["email"] == "": if request.vars["email"] == "":
error += "email cannot be empty" error.append("email cannot be empty")
elif not re.match(r"[^@]+@[^@]+\.[^@]+", request.vars["email"]): elif not re.match(r"[^@]+@[^@]+\.[^@]+", request.vars["email"]):
error += "incorrect email format" error.append("incorrect email format")
if request.vars["password"] != "": if request.vars["password"] != "":
if request.vars["confirm_password"] != request.vars["password"]: if request.vars["confirm_password"] != request.vars["password"]:
error += "password fields must match" error.append("password fields must match")
else: else:
password = db.auth_user.password.validate(request.vars["password"])[0] password = db.auth_user.password.validate(request.vars["password"])[0]
if not password:
error.append("Password is too short, should be at least of length "+str(auth.settings.password_min_length))
if error == "": if len(error) == 0:
data = dict(first_name = request.vars["first_name"], data = dict(first_name = request.vars["first_name"],
last_name = request.vars["last_name"], last_name = request.vars["last_name"],
email = request.vars["email"]) email = request.vars["email"])
...@@ -95,7 +97,7 @@ def edit_form(): ...@@ -95,7 +97,7 @@ def edit_form():
return gluon.contrib.simplejson.dumps(res, separators=(',',':')) return gluon.contrib.simplejson.dumps(res, separators=(',',':'))
else : else :
res = {"success" : "false", "message" : error} res = {"success" : "false", "message" : ', '.join(error)}
log.error(res) log.error(res)
else : else :
...@@ -310,6 +310,15 @@ class VidjilAuth(Auth): ...@@ -310,6 +310,15 @@ class VidjilAuth(Auth):
and (self.get_permission(PermissionEnum.admin_pre_process.value, 'pre_process', pre_process_id, user)\ and (self.get_permission(PermissionEnum.admin_pre_process.value, 'pre_process', pre_process_id, user)\
or self.is_admin(user)) or self.is_admin(user))
def can_modify_user(self, id):
Returns True if the current user can modify the user
whose ID is given as parameter
:param: id should be an integer
return self.is_admin() or self.user_id == id
def can_modify(self, object_of_action, id, user = None): def can_modify(self, object_of_action, id, user = None):
Returns True if the user can modify the object of action whose ID id id Returns True if the user can modify the object of action whose ID id id
...@@ -78,6 +78,8 @@ auth = VidjilAuth(db) ...@@ -78,6 +78,8 @@ auth = VidjilAuth(db)
crud, service, plugins = Crud(db), Service(), PluginManager() crud, service, plugins = Crud(db), Service(), PluginManager()
auth.settings.password_min_length = 6
## create all tables needed by auth if not custom tables ## create all tables needed by auth if not custom tables
auth.define_tables(username=False, signature=False) auth.define_tables(username=False, signature=False)
...@@ -49,7 +49,7 @@ ...@@ -49,7 +49,7 @@
{{if not auth.is_impersonating() :}} {{if not auth.is_impersonating() :}}
{{=auth.user.first_name}} {{=auth.user.last_name}} {{=auth.user.first_name}} {{=auth.user.last_name}} <a href="#" onclick="db.call('user/edit', {'id': '{{=auth.user_id}}'})"><i class="icon-pencil-2" title="Edit my personal informations"></i></a>
{{pass}} {{pass}}
