Commit 1ddfb746 authored by Mathieu Giraud's avatar Mathieu Giraud
doc/vidjil-algo.md: update, .tsv.gz
closes #4249
parent e758a07c
...@@ -549,6 +549,8 @@ The main output of Vidjil-algo (with the default `-c clones` command) are the th ...@@ -549,6 +549,8 @@ The main output of Vidjil-algo (with the default `-c clones` command) are the th
- The `.tsv` file is the AIRR output, for compatibility with other software - The `.tsv` file is the AIRR output, for compatibility with other software
using the same format. See [below](#airr-tsv-output) for details. using the same format. See [below](#airr-tsv-output) for details.
With the `--gz` option, this file is output as a compressed `.tsv.gz` file.
- The `.vdj.fa` file is *a FASTA file for further processing by other bioinformatics tools*. - The `.vdj.fa` file is *a FASTA file for further processing by other bioinformatics tools*.
Even if it is advised to rather use the full information in the `.vijdil` file, Even if it is advised to rather use the full information in the `.vijdil` file,
the `.vdj.fa` is a convenient way to have sequences of clones for further processing. the `.vdj.fa` is a convenient way to have sequences of clones for further processing.
