Commit 1c2b42a8 authored by Ryan Herbert's avatar Ryan Herbert Committed by Mikaël Salson
fuse.py remove debug print
parent e21bdbcf
...@@ -721,7 +721,6 @@ def main(): ...@@ -721,7 +721,6 @@ def main():
vparser.addPrefix('clones', 'clones.item.top', le, args.top) vparser.addPrefix('clones', 'clones.item.top', le, args.top)
for path_name in files: for path_name in files:
json_clones = vparser.extract(path_name) json_clones = vparser.extract(path_name)
print(json_clones)
clones = json.loads(json_clones) clones = json.loads(json_clones)
f += [c['id'] for c in clones["clones"]] f += [c['id'] for c in clones["clones"]]
f = sorted(set(f)) f = sorted(set(f))
