Commit 1c082016 authored by Ryan Herbert's avatar Ryan Herbert
vidjilparser.py python3-compatible type check
parent b84a2d56
#!/usr/bin/python
import ijson
from six import string_types
class VidjilWriter(object):
......@@ -49,7 +50,7 @@ class VidjilWriter(object):
value = str(value).lower()
mstr = '{}'
padding = ''
if type(value) in [str, unicode] :
if isinstance(value, string_types) :
value = value.replace("\n", "\\n")
value = value.replace("\r", "\\r")
if previous not in ['', 'map_key', 'start_map', 'start_array'] and event not in ['end_map', 'end_array']:
