Commit 193fe71c authored by HERBERT Ryan's avatar HERBERT Ryan
VidjilAuth.py Resolving some issues with the usage of the VidjilAuth API
parent 696f9794
...@@ -159,13 +159,13 @@ class VidjilAuth(Auth): ...@@ -159,13 +159,13 @@ class VidjilAuth(Auth):
If the user is None, the current user is taken into account If the user is None, the current user is taken into account
return self.get_permission('admin', 'run', run_id)\ return self.get_permission('admin', 'run', run_id, user=user)\
or self.is_admin(user) or self.is_admin(user)
def can_modify_sample_set(self, sample_set_id, user = None) : def can_modify_sample_set(self, sample_set_id, user = None) :
sample_set = db.sample_set[sample_set_id] sample_set = db.sample_set[sample_set_id]
perm = self.get_permission('admin', 'sample_set', user)\ perm = self.get_permission('admin', 'sample_set', sample_set_id, user)\
if (sample_set.sample_type == "patient") : if (sample_set.sample_type == "patient") :
...@@ -188,7 +188,7 @@ class VidjilAuth(Auth): ...@@ -188,7 +188,7 @@ class VidjilAuth(Auth):
sample_set_list = db(db.sample_set_membership.sequence_file_id == file_id).select(db.sample_set_membership.sample_set_id) sample_set_list = db(db.sample_set_membership.sequence_file_id == file_id).select(db.sample_set_membership.sample_set_id)
for row in sample_set_list : for row in sample_set_list :
if self.can_modify_sample_set(row.sample_set_id) : if self.can_modify_sample_set(row.sample_set_id, user=user) :
return True return True
return False return False
...@@ -209,7 +209,7 @@ class VidjilAuth(Auth): ...@@ -209,7 +209,7 @@ class VidjilAuth(Auth):
return self.get_permission('admin', 'auth_group', user = user)\ return self.get_permission('admin', 'auth_group', group_id, user = user)\
def can_process_file(self, user = None): def can_process_file(self, user = None):
...@@ -218,7 +218,7 @@ class VidjilAuth(Auth): ...@@ -218,7 +218,7 @@ class VidjilAuth(Auth):
return self.get_permission('run', 'results_file', user=user)\ return self.get_permission('run', 'sample_set', user=user)\
def can_upload_file(self, user = None): def can_upload_file(self, user = None):
...@@ -227,7 +227,7 @@ class VidjilAuth(Auth): ...@@ -227,7 +227,7 @@ class VidjilAuth(Auth):
return self.get_permission('upload', 'sequence_file', user=user)\ return self.get_permission('upload', 'sample_set', user=user)\
def can_use_config(self, config_id, user = None): def can_use_config(self, config_id, user = None):
Supports Markdown
