Commit 18616d4e authored by Mathieu Giraud's avatar Mathieu Giraud
core/dynprog.cpp: affine gaps, by Gotoh
Implements affine gaps by storing three matrices, B, Bins and Bdel.
parent 4b07cf8b
...@@ -49,6 +49,10 @@ Cost::Cost(int match, int mismatch, int indel, int del_end, int homopolymer) ...@@ -49,6 +49,10 @@ Cost::Cost(int match, int mismatch, int indel, int del_end, int homopolymer)
this -> deletion = indel ; this -> deletion = indel ;
this -> deletion_end = del_end ; this -> deletion_end = del_end ;
this -> homopolymer = (homopolymer == MINUS_INF ? indel: homopolymer); this -> homopolymer = (homopolymer == MINUS_INF ? indel: homopolymer);
this -> open_insertion = this -> open_deletion = -15 ;
this -> extend_insertion = this -> extend_deletion = -1 ;
this -> affine_gap = true ;
...@@ -107,7 +111,14 @@ DynProg::DynProg(const string &x, const string &y, DynProgMode mode, const Cost& ...@@ -107,7 +111,14 @@ DynProg::DynProg(const string &x, const string &y, DynProgMode mode, const Cost&
for (int i = 0; i <= m; i++) { for (int i = 0; i <= m; i++) {
B[i] = new operation[n+1]; B[i] = new operation[n+1];
Bins = new operation*[m+1];
Bins[i] = new operation[n+1];
Bdel = new operation*[m+1];
Bdel[i] = new operation[n+1];
this -> mode = mode; this -> mode = mode;
this -> cost = cost; this -> cost = cost;
...@@ -127,8 +138,12 @@ DynProg::~DynProg() { ...@@ -127,8 +138,12 @@ DynProg::~DynProg() {
delete [] B[i]; delete [] B[i];
delete [] Bins[i];
delete [] Bdel[i];
delete [] B; delete [] B;
delete [] Bins;
delete [] Bdel;
delete [] gap1; delete [] gap1;
delete [] gap2; delete [] gap2;
delete [] linkgap; delete [] linkgap;
...@@ -141,6 +156,7 @@ void DynProg::init() ...@@ -141,6 +156,7 @@ void DynProg::init()
B[i][0].type = INSER ; B[i][0].type = INSER ;
B[i][0].i = i-1 ; B[i][0].i = i-1 ;
B[i][0].j = 0 ; B[i][0].j = 0 ;
Bdel[i][0].score = Bins[i][0].score = MINUS_INF ;
for (int j=1; j<=n; j++) for (int j=1; j<=n; j++)
...@@ -148,6 +164,7 @@ void DynProg::init() ...@@ -148,6 +164,7 @@ void DynProg::init()
B[0][j].type = DELET ; B[0][j].type = DELET ;
B[0][j].i = 0 ; B[0][j].i = 0 ;
B[0][j].j = j-1 ; B[0][j].j = j-1 ;
Bdel[0][j].score = Bins[0][j].score = MINUS_INF ;
if (mode == Local || mode == LocalEndWithSomeDeletions) if (mode == Local || mode == LocalEndWithSomeDeletions)
...@@ -196,15 +213,36 @@ int DynProg::compute() ...@@ -196,15 +213,36 @@ int DynProg::compute()
best.score = MINUS_INF ; best.score = MINUS_INF ;
// The edit operations, with their backtracking information and their score // The edit operations, with their backtracking information and their score
// Match, mismatch
try_operation(best, SUBST, i-1, j-1, B[i-1][j-1].score + cost.substitution(x[i-1], y[j-1])); try_operation(best, SUBST, i-1, j-1, B[i-1][j-1].score + cost.substitution(x[i-1], y[j-1]));
try_operation(best, INSER, i-1, j , B[i-1][j ].score + cost.insertion);
try_operation(best, DELET, i , j-1, B[i ][j-1].score + cost.deletion);
if (!cost.affine_gap)
// Regular indels
else
// Gotoh affine gaps - insertion
Bins[i][j].score = MINUS_INF ;
try_operation(Bins[i][j], 'o', i-1, j, B[i-1][j].score + cost.open_insertion);
try_operation(Bins[i][j], 'x', Bins[i-1][j].i, j, Bins[i-1][j].score + cost.extend_insertion);
try_operation(best, INSER, Bins[i][j].i, j ,Bins[i][j].score);
// Gotoh affine gaps - deletions
Bdel[i][j].score = MINUS_INF ;
try_operation(Bdel[i][j], 'o', i, j-1, B[i][j-1].score + cost.open_deletion);
try_operation(Bdel[i][j], 'x', i, Bdel[i][j-1].j, Bdel[i-1][j].score + cost.extend_deletion);
try_operation(best, DELET, i, Bdel[i][j].j, Bdel[i][j].score);
// Homopolymers
try_operation(best, HOMO2X, i-2, j-1, i > 1 ? B[i-2][j-1].score + cost.homo2(x[i-2], x[i-1], y[j-1]) : MINUS_INF); try_operation(best, HOMO2X, i-2, j-1, i > 1 ? B[i-2][j-1].score + cost.homo2(x[i-2], x[i-1], y[j-1]) : MINUS_INF);
try_operation(best, HOMO2Y, i-1, j-2, j > 1 ? B[i-1][j-2].score + cost.homo2(y[j-2], y[j-1], x[i-1]) : MINUS_INF); try_operation(best, HOMO2Y, i-1, j-2, j > 1 ? B[i-1][j-2].score + cost.homo2(y[j-2], y[j-1], x[i-1]) : MINUS_INF);
// Local alignment
try_operation(best, BEGIN, 0, 0, 0); try_operation(best, BEGIN, 0, 0, 0);
...@@ -45,6 +45,13 @@ class Cost ...@@ -45,6 +45,13 @@ class Cost
//int ins(char current, char next); //int ins(char current, char next);
//int del(char current, char next); //int del(char current, char next);
int homo2(char xa, char xb, char y); int homo2(char xa, char xb, char y);
int open_insertion;
int open_deletion;
int extend_insertion;
int extend_deletion;
bool affine_gap;
...@@ -111,6 +118,8 @@ class DynProg ...@@ -111,6 +118,8 @@ class DynProg
friend ostream& operator<<(ostream& out, const DynProg& dp); friend ostream& operator<<(ostream& out, const DynProg& dp);
operation **B; // Score and backtrack matrix operation **B; // Score and backtrack matrix
operation **Bins ; // affine gap
operation **Bdel ; // affine gap
int *gap1 ; int *gap1 ;
int *linkgap ; int *linkgap ;
int *gap2 ; int *gap2 ;
