Attention une mise à jour du serveur va être effectuée le vendredi 16 avril entre 12h et 12h30. Cette mise à jour va générer une interruption du service de quelques minutes.
Commit 14710113 authored by Mathieu Giraud's avatar Mathieu Giraud
doc/vidjil-algo.md: correct links
Thanks to @mikael-s.
See also #3349.
parent 4437b7e5
...@@ -496,10 +496,10 @@ The main output of Vidjil-algo (with the default `-c clones` command) are two fo ...@@ -496,10 +496,10 @@ The main output of Vidjil-algo (with the default `-c clones` command) are two fo
the detailed V(D)J and CDR3 designation (`-z`, see warning below), and possibly the detailed V(D)J and CDR3 designation (`-z`, see warning below), and possibly
the results of the further clustering. the results of the further clustering.
The web application takes this `.vidjil` file ([possibly merged with `fuse.py`](#fuse_py)) for the *visualization and analysis* of clones and their The web application takes this `.vidjil` file ([possibly merged with `fuse.py`](#following-clones-in-several-samples)) for the *visualization and analysis* of clones and their
tracking along different samples (for example time points in a MRD tracking along different samples (for example time points in a MRD
setup or in a immunological study). setup or in a immunological study).
Please see [browser](browser.org).org for more information on the web application. Please see the [br](browser.org).org for more information on the web application.
- The `.vdj.fa` file is *a FASTA file for further processing by other bioinformatics tools*. - The `.vdj.fa` file is *a FASTA file for further processing by other bioinformatics tools*.
The sequences are at least the windows (and their count in the headers) or The sequences are at least the windows (and their count in the headers) or
