Commit 10e8e9be authored by Mathieu Giraud's avatar Mathieu Giraud
Merge branch 'feature-a/3910-avoir-des-germline-de-poulet' into 'dev'
Resolve "Avoir des germline de poulet"
Closes #3910
See merge request !478
parents 93d824ff 9ca09d24
Pipeline #235772 failed with stages
in 25 minutes and 52 seconds
# each of these sequences are compatible with allele 01 & 02.
# So a warning will be called
>IGLV1-1*01 0//2 IGLJ*01
CTGGGGTCCAAGCCGACGACGAGGCTGTCTATTACTGTGGGAGTGCAGACAGCAGCAGTACTGCTGGTATATTTGGGGCCGGGACAACCCTGACCGTCCTAGGCCAGCCCAAGGTGGCCCCCACCATCACCCTCTTCCCA
>IGLV1-1*01 0/C/6 IGLJ*01
GGTCCAAGCCGACGACGAGGCTGTCTATTACTGTGGGAGTGCAGACAGCAGCAGTACTGCTGCATTTGGGGCCGGGACAACCCTGACCGTCCTAGGCCAGCCCAAGGTGGCCCCCACCATCACCCTCTTCCCACCGTCAAAG
>IGLV1-4*01 0//6 IGLJ*01
GCCGACGACGAGGCTGTCTATTACTGTGGGAGTGCAGACAGCAGCTATGTTGGTATATTTGGGGCCGGGACAACCCTGACCGTCCTAGGCCAGCCCAAGGTGGCCCCCACCATCACCCTCTTCCCACCGTCAAAGGA
\ No newline at end of file
!LAUNCH: $VIDJIL_DIR/$EXEC -3 -c designations -g $VIDJIL_DIR/germline/gallus-gallus.g $VIDJIL_DATA/specie_gallus-gallus.fa
# each sequence here can be allele *01 or *02.
$ First clone is correctly found
1:IGLV1-1.01 0//2 IGLJ.01
$ Second clone is correctly found
1:IGLV1-1.01 0/C/6 IGLJ.01
$ Third clone is correctly found
1:IGLV1-4.01 0//6 IGLJ.01
...@@ -29,7 +29,7 @@ ...@@ -29,7 +29,7 @@
"follows": "IGH", "follows": "IGH",
"recombinations": [ { "recombinations": [ {
"5": ["IGHD+up.fa"], "5": ["IGHD+up.fa"],
"3": ["IGHJ+down.fa"] "3": ["IGHJ.fa"]
"parameters": { "parameters": {
"seed": "12s" "seed": "12s"
