Commit 0f9ad87c authored by Mikaël Salson's avatar Mikaël Salson
QC30.should-vdj.fa: TRGJ2*01 is better than TRGJ1*01
TRGJ1*01 has one mutation while TRGJ2*01 hasn't. It's the only difference.
TRGJ1*02 is even slightly better as it has no mutation too but fewer deletions
at the 5' end.
parent 2f7a1fd1
...@@ -10,8 +10,8 @@ TGCCGGGCAGTCAGGGCATTAGAAATGATTTAGGCTGGTATCAGCAGAAACCAGGGNAAAGCCCCTAAGCTCCTGATCTA ...@@ -10,8 +10,8 @@ TGCCGGGCAGTCAGGGCATTAGAAATGATTTAGGCTGGTATCAGCAGAAACCAGGGNAAAGCCCCTAAGCTCCTGATCTA
>TRDV2*03 2/4/3 TRAJ48*01 [TRA+D] >TRDV2*03 2/4/3 TRAJ48*01 [TRA+D]
ACTGGTACAGGAAGACCCAAGGTAACACAATGACTTTCATATACCGAGAAAAGGACATCTATGGCCCTGGTTTCAAAGACAATTTCCAAGGTGACATTGATATTGCAAAGAACCTGGCTGTACTTAAGATACTTGCACCATCAGAGAGAGATGAAGGGTCTTACTACTGTGCCTGTGACAGAGACTAACTTTGGAAATGAGAAATTAACCTTTGGGACTGGAACAAGACTCACCATCATACCCAGTAAGTTCTTCATCCTTGGTCAGGAAATCAGCCTGCATAAGATTCTGGGGAA ACTGGTACAGGAAGACCCAAGGTAACACAATGACTTTCATATACCGAGAAAAGGACATCTATGGCCCTGGTTTCAAAGACAATTTCCAAGGTGACATTGATATTGCAAAGAACCTGGCTGTACTTAAGATACTTGCACCATCAGAGAGAGATGAAGGGTCTTACTACTGTGCCTGTGACAGAGACTAACTTTGGAAATGAGAAATTAACCTTTGGGACTGGAACAAGACTCACCATCATACCCAGTAAGTTCTTCATCCTTGGTCAGGAAATCAGCCTGCATAAGATTCTGGGGAA
>TRGV5*01 (5/4/3 TRGJ1*01, 5/4/0 TRGJ1*02) [TRG] >TRGV5*01 (5/4/3 TRGJ2*01, 5/4/0 TRGJ1*02) [TRG]
TTCCGTTCTNCCAACTNCAANGGNNGGTNGTTGGGAATCAGGNACTCAGTNCCAGGNAAAGTATTATACTCATACACCCAGGAGGTGGAGCTGGATATTGATACTACGAAATCTAATTGAAAATGATTCTGGGGTCTATTACTGTGCCACCTGGGCCTTTTATTATAAGAAACTCTTTGGCAGTGGAACAACACTTGTTGTCACAGGTAAGTATCGGAAGAAA TTCCGTTCTNCCAACTNCAANGGNNGGTNGTTGGGAATCAGGNACTCAGTNCCAGGNAAAGTATTATACTCATACACCCAGGAGGTGGAGCTGGATATTGATACTACGAAATCTAATTGAAAATGATTCTGGGGTCTATTACTGTGCCACCTGGGCCTTTTATTATAAGAAACTCTTTGGCAGTGGAACAACACTTGTTGTCACAGGTAAGTATCGGAAGAAA
>TRGV4*02 (4/4/4 TRGJ1*01, 4/4/1 TRGJ1*02, 1/1/1 TRGJ1*02) [TRG] >TRGV4*02 (4/4/1 TRGJ2*01, 1/1/1 TRGJ2*01, 4/4/1 TRGJ1*02, 1/1/1 TRGJ1*02) [TRG]
GGTTTTNTTCGTTGCCNTCCNTTTTTTGNTGGAATCAGGAATCAGCCCAGGGAAAGTATGATACTTACGGAAGCACAAGGTAAGAACTTGAGAATGATACTGCGAAATCTTATTGAAAATGACTCTGGAGTCTATTACTGTGCCACCTGGGAAGGCTATTATAAGAAACTCTTTGGCAGTGGAACAACACTTGTTGTCACAGGTAAGTATCGGAAGATATTCC GGTTTTNTTCGTTGCCNTCCNTTTTTTGNTGGAATCAGGAATCAGCCCAGGGAAAGTATGATACTTACGGAAGCACAAGGTAAGAACTTGAGAATGATACTGCGAAATCTTATTGAAAATGACTCTGGAGTCTATTACTGTGCCACCTGGGAAGGCTATTATAAGAAACTCTTTGGCAGTGGAACAACACTTGTTGTCACAGGTAAGTATCGGAAGATATTCC
\ No newline at end of file
