Commit 0d06ff7f authored by Ryan Herbert's avatar Ryan Herbert Committed by marc duez
url_test add tests for url parameters
parent f6d41d50
...@@ -134,4 +134,61 @@ QUnit.test("plot : modifyURL",function (assert) { with (windowMock) { ...@@ -134,4 +134,61 @@ QUnit.test("plot : modifyURL",function (assert) { with (windowMock) {
QUnit.test("url: parse", function(assert) { with (windowMock) {
windowMock.history.pushState('plop', 'plop', 'mock://foo.bar?param1=foo&param2=bar');
var m = new Model();
var url = new Url(m, windowMock);
var params = url.parseUrlParams(url.url);
assert.deepEqual(params, {
"param1": "foo",
"param2": "bar"
}, "test url parse correct url");
windowMock.history.pushState('plop', 'plop', 'mock://foo.bar?fakeparam&realparam=real');
'realparam': 'real'
QUnit.test("url: generate", function(assert) { with (windowMock) {
var params = {
'param1': 'first',
'param2': 'second',
'param3': 'third'
var param_string = url.generateParamsString(params);
assert.equal(param_string, "param1=first&param2=second&param3=third");
QUnit.test("url: positional parse", function(assert) { with (windowMock) {
windowMock.history.pushState('plop', 'plop', 'mock://foo.bar/browser/1/3?param3=third');
var url = new PositionalUrl(m, windowMock);
var params = url.parseUrlParams();
'sample_set_id': '1',
'config': '3',
'param3': 'third'
QUnit.test("url: positional generate", function(assert) { with (windowMock) {
var params = {
'sample_set_id': 1,
'config': 4,
'foobar': 'barfoo',
'param4': 'fourth'
assert.equal(param_string, '/1/4?foobar=barfoo&param4=fourth');
