Commit 0a50bba2 authored by Ryan Herbert's avatar Ryan Herbert
test_003_sample.rb rename go_to_first
parent b37ce50b
...@@ -16,7 +16,7 @@ class TestSampleSet < BrowserTest ...@@ -16,7 +16,7 @@ class TestSampleSet < BrowserTest
end end
end end
def go_to_first def go_to_first_set
# load patient list # load patient list
$b.a(:class => "button button_token patient_token", :text => "patients").click $b.a(:class => "button button_token patient_token", :text => "patients").click
table = $b.table(:id => "table") table = $b.table(:id => "table")
...@@ -32,7 +32,7 @@ class TestSampleSet < BrowserTest ...@@ -32,7 +32,7 @@ class TestSampleSet < BrowserTest
end end
def test_001_add def test_001_add
table = go_to_first table = go_to_first_set
add_button = $b.span(:text => "+ add samples") add_button = $b.span(:text => "+ add samples")
add_button.wait_until_present add_button.wait_until_present
