Commit 09ed77dd authored by Mikaël Salson's avatar Mikaël Salson
KmerMultiSegmenter: Number of expected hits randomly.
Should take into account the total number of sequences but we don't know it at first.
Maybe the value should be computed afterwards…
parent 32ee38d5
...@@ -282,12 +282,13 @@ KmerSegmenter::~KmerSegmenter() { ...@@ -282,12 +282,13 @@ KmerSegmenter::~KmerSegmenter() {
delete kaa; delete kaa;
KmerMultiSegmenter::KmerMultiSegmenter(Sequence seq, MultiGermline *multigermline, ostream *out_unsegmented) KmerMultiSegmenter::KmerMultiSegmenter(Sequence seq, MultiGermline *multigermline, ostream *out_unsegmented, double threshold)
int best_score_seg = 0 ; // Best score, segmented sequences int best_score_seg = 0 ; // Best score, segmented sequences
int best_score_unseg = 0 ; // Best score, unsegmented sequences int best_score_unseg = 0 ; // Best score, unsegmented sequences
the_kseg = NULL; the_kseg = NULL;
multi_germline = multigermline; multi_germline = multigermline;
threshold_nb_expected = threshold;
// Iterate over the germlines // Iterate over the germlines
for (list<Germline*>::const_iterator it = multigermline->germlines.begin(); it != multigermline->germlines.end(); ++it) for (list<Germline*>::const_iterator it = multigermline->germlines.begin(); it != multigermline->germlines.end(); ++it)
...@@ -345,7 +346,19 @@ KmerMultiSegmenter::KmerMultiSegmenter(Sequence seq, MultiGermline *multigermlin ...@@ -345,7 +346,19 @@ KmerMultiSegmenter::KmerMultiSegmenter(Sequence seq, MultiGermline *multigermlin
} else { } else {
delete kseg; delete kseg;
} // end for (Germlines) } // end for (Germlines)
if (the_kseg->isSegmented() && getNbExpected() > threshold_nb_expected)
the_kseg->setSegmentationStatus(UNSEG_NOISY);
double KmerMultiSegmenter::getNbExpected() const {
int max = the_kseg->score;
double proba = 0;
int n = the_kseg->getSequence().sequence.size() - the_kseg->getKmerAffectAnalyser()->getIndex().getS();
for (int i = max; i< n; i++) {
proba += nChoosek(n, i) * pow(the_kseg->getKmerAffectAnalyser()->getIndex().getIndexLoad(), i);
return multi_germline->germlines.size() * proba;
KmerMultiSegmenter::~KmerMultiSegmenter() { KmerMultiSegmenter::~KmerMultiSegmenter() {
...@@ -28,6 +28,8 @@ ...@@ -28,6 +28,8 @@
#define JSON_REMEMBER_BEST 4 /* The number of V/D/J predictions to keep */ #define JSON_REMEMBER_BEST 4 /* The number of V/D/J predictions to keep */
#define THRESHOLD_NB_EXPECTED 1E-6 /* Threshold of the accepted expected value for number of found k-mers */
using namespace std; using namespace std;
enum SEGMENTED { DONT_KNOW, SEG_PLUS, SEG_MINUS, UNSEG_TOO_SHORT, UNSEG_STRAND_NOT_CONSISTENT, enum SEGMENTED { DONT_KNOW, SEG_PLUS, SEG_MINUS, UNSEG_TOO_SHORT, UNSEG_STRAND_NOT_CONSISTENT,
...@@ -189,12 +191,23 @@ class KmerSegmenter : public Segmenter ...@@ -189,12 +191,23 @@ class KmerSegmenter : public Segmenter
class KmerMultiSegmenter class KmerMultiSegmenter
private:
double threshold_nb_expected;
public: public:
* @param seq: An object read from a FASTA/FASTQ file * @param seq: An object read from a FASTA/FASTQ file
* @param multigermline: the multigermline * @param multigermline: the multigerm
* @param threshold: threshold of randomly expected segmentation
double threshold = THRESHOLD_NB_EXPECTED);
* @return true iff the best score is sufficiently different from the scores
* of the other segmenters.
KmerMultiSegmenter(Sequence seq, MultiGermline *multigermline, ostream *out_unsegmented); double getNbExpected() const;
~KmerMultiSegmenter(); ~KmerMultiSegmenter();
KmerSegmenter *the_kseg; KmerSegmenter *the_kseg;
