GitLab
Support
Community forum
Keyboard shortcuts
vidjil
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
vidjil
vidjil
0933247d
0933247d
Ryan Herbert
Committed by
Mikaël Salson
Nov 20, 2020
SampleSetList update unit tests
fc95ea04
7 additions
12 deletions
+7
-12
server/web2py/applications/vidjil/tests/unit/models/SampleSetList.py
...py/applications/vidjil/tests/unit/models/SampleSetList.py
+7
-12
0933247d
@@ -19,37 +19,32 @@ class SamplesetlistModel(unittest.TestCase):
factory
ModelFactory
factory
ModelFactory
helper
factory
get_instance
type
'patient'
helper
factory
get_instance
type
'patient'
slist
SampleSetList
helper
slist
SampleSetList
helper
self
assertTrue
len
slist
element_ids
"The sample set list was not expected to be empty"
self
assertTrue
len
slist
def
testCreatorNames
self
def
testCreatorNames
self
factory
ModelFactory
factory
ModelFactory
helper
factory
get_instance
type
'patient'
helper
factory
get_instance
type
'patient'
slist
SampleSetList
helper
slist
SampleSetList
helper
slist
load_creator_names
values
slist
result
values
slist
get_values
first
values
first
values
name
first
creator
name
helper
get_creator
first
self
assertFalse
name
"load_creator_names failed to retrieve a username"
self
assertFalse
name
def
testPermittedGroups
self
def
testPermittedGroups
self
factory
ModelFactory
factory
ModelFactory
helper
factory
get_instance
type
'patient'
helper
factory
get_instance
type
'patient'
slist
SampleSetList
helper
slist
SampleSetList
helper
slist
load_permitted_groups
value
slist
result
value
slist
get_values
groups
helper
get_groups
value
groups
value
groups
group_list
value
group_list
self
assertFalse
groups
"load_permitted_groups didn't load ay groups"
self
assertFalse
groups
self
assertFalse
group_list
"load_permitted_groups found groups although the group_list is empty"
def
testAnonPermissions
self
def
testAnonPermissions
self
factory
ModelFactory
factory
ModelFactory
helper
factory
get_instance
type
'patient'
helper
factory
get_instance
type
'patient'
slist
SampleSetList
helper
slist
SampleSetList
helper
slist
load_anon_permissions
value
slist
result
value
slist
get_values
self
assertFalse
value
anon_allowed
"Anon was allowed, when it was not expected to be"
self
assertFalse
value
has_permission
