Commit 03fd3d22 authored by marc's avatar marc Committed by Mathieu Giraud
fuse.py: replace OR remove the obsolete similarity matrix
parent 109ba56e
...@@ -46,7 +46,7 @@ from collections import defaultdict ...@@ -46,7 +46,7 @@ from collections import defaultdict
FUSE_VERSION = "vidjil fuse" FUSE_VERSION = "vidjil fuse"
TOOL_SIMILARITY = "../algo/tools/similarity" TOOL_SIMILARITY = "../algo/tools/similarity"
SIMILARITY_LIMIT = 1000 SIMILARITY_LIMIT = 500
GERMLINES_ORDER = ['TRA', 'TRB', 'TRG', 'TRD', 'DD', 'IGH', 'DHJH', 'IJK', 'IJL'] GERMLINES_ORDER = ['TRA', 'TRB', 'TRG', 'TRD', 'DD', 'IGH', 'DHJH', 'IJK', 'IJL']
...@@ -752,7 +752,8 @@ def main(): ...@@ -752,7 +752,8 @@ def main():
jlist_fused.d["similarity"] = json.loads(out) jlist_fused.d["similarity"] = json.loads(out)
except OSError: except OSError:
print("! failed: %s" % TOOL_SIMILARITY) print("! failed: %s" % TOOL_SIMILARITY)
else :
jlist_fused.d["similarity"] = [];
print("### Save merged file") print("### Save merged file")
jlist_fused.save_json(args.output) jlist_fused.save_json(args.output)
