Commit 03c7ab4d authored by Marc Duez's avatar Marc Duez
config.py : debug > 'user_xx' role for a user group don't neccesary match the user id
parent a0ada2db
...@@ -103,12 +103,22 @@ def delete(): ...@@ -103,12 +103,22 @@ def delete():
def permission(): def permission():
if (auth.has_permission('admin', 'patient', request.vars["id"]) ): if (auth.has_permission('admin', 'patient', request.vars["id"]) ):
query = db( db.auth_group.role != 'admin' ).select() query = db( (db.auth_group.role != 'admin') ).select()
query2 = db( (db.auth_group.role != 'admin') &
(db.auth_membership.group_id == db.auth_group.id) &
(db.auth_membership.user_id == db.auth_user.id)
).select()
usermap = {}
for row in query2 :
if row.auth_group.role[:5] == "user_" :
usermap[row.auth_group.role] = row.auth_user.id
for row in query : for row in query :
row.owner = row.role row.owner = row.role
if row.owner[:5] == "user_" : if row.owner[:5] == "user_" :
id = int(row.owner[5:]) id = usermap[row.owner]
row.owner = db.auth_user[id].first_name + " " + db.auth_user[id].last_name row.owner = db.auth_user[id].first_name + " " + db.auth_user[id].last_name
row.admin = False row.admin = False
