Commit 03abd35c authored by Mathieu Giraud's avatar Mathieu Giraud
core/windowExtractor.{h,cpp}: only_labeled_windows, keeps only windows from windows_label
Hey, could windows labels (-l) be used for another thing ?
parent 9c8e4913
...@@ -9,7 +9,7 @@ WindowExtractor::WindowExtractor(): out_segmented(NULL), out_unsegmented(NULL), ...@@ -9,7 +9,7 @@ WindowExtractor::WindowExtractor(): out_segmented(NULL), out_unsegmented(NULL),
WindowsStorage *WindowExtractor::extract(OnlineFasta *reads, MultiGermline *multigermline, WindowsStorage *WindowExtractor::extract(OnlineFasta *reads, MultiGermline *multigermline,
size_t w, size_t w,
map<string, string> &windows_labels, map<string, string> &windows_labels, bool only_labeled_windows,
int stop_after, int only_nth_read, bool keep_unsegmented_as_clone, int stop_after, int only_nth_read, bool keep_unsegmented_as_clone,
double nb_expected, int nb_reads_for_evalue) { double nb_expected, int nb_reads_for_evalue) {
init_stats(); init_stats();
...@@ -57,6 +57,10 @@ WindowsStorage *WindowExtractor::extract(OnlineFasta *reads, MultiGermline *mult ...@@ -57,6 +57,10 @@ WindowsStorage *WindowExtractor::extract(OnlineFasta *reads, MultiGermline *mult
stats[seg->getSegmentationStatus()].insert(read_length); stats[seg->getSegmentationStatus()].insert(read_length);
if (seg->isSegmented()) { if (seg->isSegmented()) {
// Filter
if (!only_labeled_windows || (windows_labels.find(junc) != windows_labels.end()))
// Store the window // Store the window
windowsStorage->add(junc, reads->getSequence(), seg->getSegmentationStatus(), seg->segmented_germline); windowsStorage->add(junc, reads->getSequence(), seg->getSegmentationStatus(), seg->segmented_germline);
...@@ -39,6 +39,7 @@ class WindowExtractor { ...@@ -39,6 +39,7 @@ class WindowExtractor {
* @param multigermline: the multigermline * @param multigermline: the multigermline
* @param w: length of the window * @param w: length of the window
* @param windows_labels: Windows that must be kept and registered as such. * @param windows_labels: Windows that must be kept and registered as such.
* @param only_labeled_windows: remember only windows from windows_labels
* @param nb_expected: maximal e-value of the segmentation * @param nb_expected: maximal e-value of the segmentation
* @param nb_reads_for_evalue: number of reads, used for e-value computation. Can be approximate or faked. * @param nb_reads_for_evalue: number of reads, used for e-value computation. Can be approximate or faked.
* @return a pointer to a WindowsStorage that will contain all the windows. * @return a pointer to a WindowsStorage that will contain all the windows.
...@@ -48,7 +49,7 @@ class WindowExtractor { ...@@ -48,7 +49,7 @@ class WindowExtractor {
WindowsStorage *extract(OnlineFasta *reads, MultiGermline *multigermline, WindowsStorage *extract(OnlineFasta *reads, MultiGermline *multigermline,
size_t w, size_t w,
map<string, string> &windows_labels, map<string, string> &windows_labels, bool only_labeled_windows=false,
int stop_after=-1, int only_nth_reads=1, bool keep_unsegmented_as_clone=false, int stop_after=-1, int only_nth_reads=1, bool keep_unsegmented_as_clone=false,
double nb_expected = THRESHOLD_NB_EXPECTED, int nb_reads_for_evalue = 1); double nb_expected = THRESHOLD_NB_EXPECTED, int nb_reads_for_evalue = 1);
...@@ -331,6 +331,7 @@ int main (int argc, char **argv) ...@@ -331,6 +331,7 @@ int main (int argc, char **argv)
string forced_edges = "" ; string forced_edges = "" ;
string windows_labels_file = "" ; string windows_labels_file = "" ;
bool only_labeled_windows = false ;
char c ; char c ;
...@@ -954,7 +955,9 @@ int main (int argc, char **argv) ...@@ -954,7 +955,9 @@ int main (int argc, char **argv)
we.setAffectsOutput(out_affects); we.setAffectsOutput(out_affects);
WindowsStorage *windowsStorage = we.extract(reads, multigermline, w, windows_labels, max_reads_processed, only_nth_read, keep_unsegmented_as_clone, WindowsStorage *windowsStorage = we.extract(reads, multigermline, w,
windows_labels, only_labeled_windows,
expected_value, nb_reads_for_evalue); expected_value, nb_reads_for_evalue);
windowsStorage->setIdToAll(); windowsStorage->setIdToAll();
size_t nb_total_reads = we.getNbReads(); size_t nb_total_reads = we.getNbReads();
