GitLab
Support
Community forum
Keyboard shortcuts
vidjil
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
vidjil
vidjil
03a00166
03a00166
HERBERT Ryan
nginx configurations switched to full https
21cd44e7
2
2 changed files
56 additions
90 deletions
+56
-90
packaging/server/conf/nginx_web2py
+31
-45
server/nginx_install.sh
+25
-45
03a00166
@@ -2,6 +2,37 @@ server {
listen 80;
server_name $hostname;
server {
listen 443 default_server ssl;
ssl_certificate /etc/nginx/ssl/web2py.crt;
ssl_certificate_key /etc/nginx/ssl/web2py.key;
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:10m;
ssl_session_timeout 10m;
ssl_ciphers ECDHE-RSA-AES256-SHA:DHE-RSA-AES256-SHA:DHE-DSS-AES256-SHA:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA;
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
keepalive_timeout 70;
location / {
#uwsgi_pass 127.0.0.1:9001;
uwsgi_pass unix:///tmp/web2py.socket;
include uwsgi_params;
uwsgi_param UWSGI_SCHEME $scheme;
uwsgi_param SERVER_SOFTWARE nginx/$nginx_version;
###remove the comments to turn on if you want gzip compression of your pages
# include /etc/nginx/conf.d/web2py/gzip.conf;
### end gzip section
proxy_read_timeout 600;
client_max_body_size 20G;
## if you serve static files through https, copy here the section
## from the previous server instance to manage static files
location /browser {
root /var/www;
expires 1h;
@@ -35,20 +66,6 @@ server {
location / {
@@ -63,35 +80,4 @@ server {
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
server {
location / {
03a00166
@@ -62,8 +62,32 @@ gzip_types text/plain text/css application/json application/x-javascript text/xm
# Create configuration file /etc/nginx/sites-available/web2py
echo
"server {
listen
80
listen
server_name
hostname;
location / {
scheme;
nginx_version;
location /browser {
root
$CWD
@@ -94,20 +118,6 @@ echo "server {
# include /etc/nginx/conf.d/web2py/gzip_static.conf;
location / {
scheme;
nginx_version;
@@ -122,36 +132,6 @@ echo "server {
document_root
server {
server_name
hostname;
location / {
scheme;
nginx_version;
ln
-s
/etc/nginx/sites-available/web2py /etc/nginx/sites-enabled/web2py
