Commit 43d8a2eb authored by AGULLO Emmanuel's avatar AGULLO Emmanuel
Fix maphys ctest to allow tests with more MPI processes than cores
Allow tests with more MPI processes than available CPU cores during the ctest
process, which otherwise is not allowed by default by OpenMPI.
parent 1e956ad3
...@@ -105,7 +105,14 @@ area (CPUs-GPUs, distributed nodes).") ...@@ -105,7 +105,14 @@ area (CPUs-GPUs, distributed nodes).")
'(#:configure-flags '("-DMAPHYS_BUILD_TESTS=ON" '(#:configure-flags '("-DMAPHYS_BUILD_TESTS=ON"
"-DMAPHYS_SDS_MUMPS=ON" "-DMAPHYS_SDS_MUMPS=ON"
"-DMAPHYS_SDS_PASTIX=ON") "-DMAPHYS_SDS_PASTIX=ON")
#:phases (modify-phases %standard-phases
(add-before 'check 'prepare-test-environment
(lambda _
;; Allow tests with more MPI processes than available CPU cores,
;; which is not allowed by default by OpenMPI
(setenv "OMPI_MCA_rmaps_base_oversubscribe" "1"))))))
(inputs `(("hwloc" ,hwloc "lib") (inputs `(("hwloc" ,hwloc "lib")
("openmpi" ,openmpi) ("openmpi" ,openmpi)
("ssh" ,openssh) ("ssh" ,openssh)
