Commit 97513620 authored by RILLING Louis's avatar RILLING Louis
tansiv-client / capi: Better document vsg_recv()
parent ad5baf4f
Pipeline #179519 failed with stages
in 11 minutes and 22 seconds
...@@ -155,8 +155,9 @@ pub unsafe extern fn vsg_send(context: *const Context, dst: libc::in_addr_t, msg ...@@ -155,8 +155,9 @@ pub unsafe extern fn vsg_send(context: *const Context, dst: libc::in_addr_t, msg
/// Picks the next message in the receive queue, stores its payload in `msg[0..*msglen]` and /// Picks the next message in the receive queue, stores its payload in `msg[0..*msglen]` and
/// optionnally returns sender and destination addresses in `*psrc` and `*pdst` respectively. The /// optionnally returns sender and destination addresses in `*psrc` and `*pdst` respectively.
/// actual length of the received payload is stored in `*msglen`. /// `*msglen` initially contains the size of the buffer pointed to by `msg`. When `vsg_recv`
/// returns with success, `*msglen` contains the actual length of the received payload.
/// # Safety /// # Safety
...@@ -164,6 +165,9 @@ pub unsafe extern fn vsg_send(context: *const Context, dst: libc::in_addr_t, msg ...@@ -164,6 +165,9 @@ pub unsafe extern fn vsg_send(context: *const Context, dst: libc::in_addr_t, msg
/// * `psrc` and `pdst` can be `NULL`, in which case the correponding addresses will not be returned. /// * `psrc` and `pdst` can be `NULL`, in which case the correponding addresses will not be returned.
/// * If `msglen` is not `NULL`, `msg` must point to a valid memory range of at least `*msglen`
/// bytes. This memory range does not need to be initialized.
/// * If `msglen` is `NULL` or `*msglen` is `0`, only 0-length messages can be received. Note that /// * If `msglen` is `NULL` or `*msglen` is `0`, only 0-length messages can be received. Note that
/// in that case it is allowed that `msg` is `NULL` too. /// in that case it is allowed that `msg` is `NULL` too.
