Commit 3361c597 authored by Bergamote Orange's avatar Bergamote Orange
clea-batch.sh script file update with safeguards on log file
parent 2f30bd88
......@@ -60,7 +60,7 @@
<appender-ref ref="RollingFile" />
</logger>
<!-- at TRACE level -->
<!-- at ERROR level -->
<logger name="error" level="error" additivity="false">
<appender-ref ref="RollingErrorFile" />
</logger>
......@@ -3,6 +3,13 @@
PROGNAM=$(basename $0)
die() { echo "[$PROGNAM] $*" 1>&2 ; exit 1; }
# redirect logs to log file
test -f "${CLEA_BATCH_LOG_FILE_PATH}/${CLEA_BATCH_LOG_FILE_NAME}.log" || die "log file: ${CLEA_BATCH_LOG_FILE_PATH}/${CLEA_BATCH_LOG_FILE_NAME}.log does not exist"
test -f "${CLEA_BATCH_LOG_FILE_PATH}/${CLEA_BATCH_LOG_FILE_NAME}.error.log" || die "error log file: ${CLEA_BATCH_LOG_FILE_PATH}/${CLEA_BATCH_LOG_FILE_NAME}.error.log does not exist"
exec >> "${CLEA_BATCH_LOG_FILE_PATH}/${CLEA_BATCH_LOG_FILE_NAME}.log"
exec 2>> "${CLEA_BATCH_LOG_FILE_PATH}/${CLEA_BATCH_LOG_FILE_NAME}.error.log"
WORKDIR=${CLEA_BATCH_CLUSTER_OUTPUT_PATH:-/tmp/v1}
BUCKET=${BUCKET:-}
......@@ -20,7 +27,7 @@ if ! java -jar clea-batch.jar $@ ; then
fi
echo "[$PROGNAM] Coying files...."
echo "[$PROGNAM] Copying files...."
# Test that output folder exists, computing NBFILES fails if folder doesn't exist
</logger>
</logger>
</logger>
</logger>
......@@ -6,8 +6,8 @@ services:
build: ../clea-ws-rest/
environment:
SPRING_PROFILES_ACTIVE: dev,docker
CLEA_WS_REST_LOG_FILE_PATH: -/logs
CLEA_WS_REST_LOG_FILE_NAME: -clea-ws-rest
CLEA_WS_REST_LOG_FILE_PATH: /logs
CLEA_WS_REST_LOG_FILE_NAME: clea-ws-rest
depends_on:
- kafka
ports:
......@@ -22,8 +22,8 @@ services:
environment:
SPRING_JPA_HIBERNATE_DDL_AUTO: none
CLEA_VENUE_CONSUMER_LOG_FILE_PATH: -/logs
CLEA_VENUE_CONSUMER_LOG_FILE_NAME: -clea-venue-consumer
CLEA_VENUE_CONSUMER_LOG_FILE_PATH: /logs
CLEA_VENUE_CONSUMER_LOG_FILE_NAME: clea-venue-consumer
depends_on:
- postgres
- kafka
......@@ -39,8 +39,8 @@ services:
environment:
SPRING_PROFILES_ACTIVE: docker
BUCKET: clea-batch
CLEA_BATCH_LOG_FILE_PATH: -/logs
CLEA_BATCHLOG_FILE_NAME: -clea-batch
CLEA_BATCH_LOG_FILE_PATH: /logs
CLEA_BATCH_LOG_FILE_NAME: clea-batch
ports:
- "15000:15000"
depends_on:
