Commit b9871ca4 authored by Cypres TAC's avatar Cypres TAC
Update .gitlab-ci.yml file
parent 879e5a09
Pipeline #226592 passed with stages
in 3 minutes and 15 seconds
...@@ -32,7 +32,7 @@ deploy: ...@@ -32,7 +32,7 @@ deploy:
tags: tags:
- ci - ci
script: script:
- cd java - cd CLEA-lib/java
- mvn $MAVEN_CLI_OPTS -DskipTests=true -DnexusReleasesUrl=$CI_SERVER_URL/api/v4/projects/$CI_PROJECT_ID/packages/maven -DnexusSnapshotsUrl=$CI_SERVER_URL/api/v4/projects/$CI_PROJECT_ID/packages/maven -s ../../.gitlab-ci/ci_settings.xml deploy - mvn $MAVEN_CLI_OPTS -DskipTests=true -DnexusReleasesUrl=$CI_SERVER_URL/api/v4/projects/$CI_PROJECT_ID/packages/maven -DnexusSnapshotsUrl=$CI_SERVER_URL/api/v4/projects/$CI_PROJECT_ID/packages/maven -s ../../.gitlab-ci/ci_settings.xml deploy
only: only:
- master - master
