Commit a441f0af authored by calocedre TAC's avatar calocedre TAC
Merge branch 'add-ci' into 'master'
Add ci
See merge request !3
parents 72729a16 3d9e27d2
Pipeline #226142 passed with stages
in 3 minutes and 13 seconds
image: maven:3.6-jdk-11
stages:
- build
- deploy
build_template:
stage: build
tags:
- ci
script:
- cd java
- mvn package
artifacts:
paths:
- java/target/*.jar
deploy_template:
stage: deploy
tags:
- ci
script:
- cd java
- mvn $MAVEN_CLI_OPTS -DskipTests=true -DnexusReleasesUrl=$CI_SERVER_URL/api/v4/projects/$CI_PROJECT_ID/packages/maven -DnexusSnapshotsUrl=$CI_SERVER_URL/api/v4/projects/$CI_PROJECT_ID/packages/maven -s ../.gitlab-ci/ci_settings.xml deploy
only:
- master
- tags
\ No newline at end of file
<settings xmlns="http://maven.apache.org/SETTINGS/1.1.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/SETTINGS/1.1.0 http://maven.apache.org/xsd/settings-1.1.0.xsd">
<servers>
<server>
<id>gitlab-maven</id>
<configuration>
<httpHeaders>
<property>
<name>Job-Token</name>
<value>${env.CI_JOB_TOKEN}</value>
</property>
</httpHeaders>
</configuration>
</server>
</servers>
</settings>
...@@ -99,4 +99,21 @@ ...@@ -99,4 +99,21 @@
</plugin> </plugin>
</plugins> </plugins>
</build> </build>
<repositories>
<repository>
<url>${env.CI_SERVER_URL}/api/v4/projects/${env.CI_PROJECT_ID}/packages/maven</url>
</repository>
</repositories>
<distributionManagement>
<repository>
</repository>
<snapshotRepository>
</snapshotRepository>
</distributionManagement>
</project> </project>
