Commit 3c4bc158 authored by AUMAGE Olivier's avatar AUMAGE Olivier
materiel en premier
parent 8182b8b4
...@@ -60,6 +60,17 @@ module load openblas/v0.2.8_gnu48 ...@@ -60,6 +60,17 @@ module load openblas/v0.2.8_gnu48
</tt> </tt>
<div class="section">
<h3>Tutorial Material</h3>
<p>
All files needed for the lab works are available on the machine in the
directory <tt>/mnt/n7fs/ens/tp_abuttari/TP_StarPU/material</tt>.
A Tar archive is also available here: <a href="./material.tar"><tt>material.tar</tt></a>.
</p>
</div>
<p> <p>
The following variables need to be set to use StarPU. The following variables need to be set to use StarPU.
</p> </p>
...@@ -132,17 +143,6 @@ appropriate. ...@@ -132,17 +143,6 @@ appropriate.
</p> </p>
</div> </div>
<p>
</p>
</div>
</div> </div>
<div class="section"> <div class="section">
