Commit eb1cd6a2 authored by Davide Pala's avatar Davide Pala
Merge branch 'master' of gitlab.inria.fr:srokicki/Comet
Merging changes to header styles
parents 1d15e4f7 aa4057f5
Pipeline #207473 passed with stages
in 16 minutes and 31 seconds
...@@ -34,7 +34,7 @@ class CacheMemory : public MemoryInterface<INTERFACE_SIZE> { ...@@ -34,7 +34,7 @@ class CacheMemory : public MemoryInterface<INTERFACE_SIZE> {
static const int LOG_INTERFACE_SIZE = log2const<INTERFACE_SIZE>::value; static const int LOG_INTERFACE_SIZE = log2const<INTERFACE_SIZE>::value;
public: public:
MemoryInterface<INTERFACE_SIZE>* nextLevel; IncompleteMemory<INTERFACE_SIZE>* nextLevel;
ac_int<TAG_SIZE + LINE_SIZE * 8, false> cacheMemory[SET_SIZE][ASSOCIATIVITY]; ac_int<TAG_SIZE + LINE_SIZE * 8, false> cacheMemory[SET_SIZE][ASSOCIATIVITY];
ac_int<40, false> age[SET_SIZE][ASSOCIATIVITY]; ac_int<40, false> age[SET_SIZE][ASSOCIATIVITY];
...@@ -66,7 +66,7 @@ public: ...@@ -66,7 +66,7 @@ public:
// Stats // Stats
unsigned long numberAccess, numberMiss; unsigned long numberAccess, numberMiss;
CacheMemory(MemoryInterface<INTERFACE_SIZE>* nextLevel, bool v) CacheMemory(IncompleteMemory<INTERFACE_SIZE>* nextLevel, bool v)
this->nextLevel = nextLevel; this->nextLevel = nextLevel;
for (int oneSetElement = 0; oneSetElement < SET_SIZE; oneSetElement++) { for (int oneSetElement = 0; oneSetElement < SET_SIZE; oneSetElement++) {
...@@ -107,7 +107,8 @@ public: ...@@ -107,7 +107,8 @@ public:
dataOut = dataOutStore; dataOut = dataOutStore;
wasStore = false; wasStore = false;
cacheState = 0; cacheState = 0;
waitOut = 0;
return;
} else if (opType != NONE) { } else if (opType != NONE) {
ac_int<LINE_SIZE * 8 + TAG_SIZE, false> val1 = cacheMemory[place][0]; ac_int<LINE_SIZE * 8 + TAG_SIZE, false> val1 = cacheMemory[place][0];
This diff is collapsed.
...@@ -24,6 +24,20 @@ solution library add C28SOI_SC_12_CORE_LL_ccs -file /opt/DesignKit/catapult_lib/ ...@@ -24,6 +24,20 @@ solution library add C28SOI_SC_12_CORE_LL_ccs -file /opt/DesignKit/catapult_lib/
go libraries go libraries
directive set -CLOCKS {clk {-CLOCK_PERIOD 2 -CLOCK_EDGE rising -CLOCK_UNCERTAINTY 0.0 -CLOCK_HIGH_TIME 1.0 -RESET_SYNC_NAME rst -RESET_ASYNC_NAME arst_n -RESET_KIND sync -RESET_SYNC_ACTIVE high -RESET_ASYNC_ACTIVE low -ENABLE_ACTIVE high}} directive set -CLOCKS {clk {-CLOCK_PERIOD 2 -CLOCK_EDGE rising -CLOCK_UNCERTAINTY 0.0 -CLOCK_HIGH_TIME 1.0 -RESET_SYNC_NAME rst -RESET_ASYNC_NAME arst_n -RESET_KIND sync -RESET_SYNC_ACTIVE high -RESET_ASYNC_ACTIVE low -ENABLE_ACTIVE high}}
go assembly go assembly
directive set /doCore/core/imCache.cacheMemory:rsc -MAP_TO_MODULE ccs_sample_mem.ccs_ram_sync_singleport
directive set /doCore/core/imCache.age:rsc -MAP_TO_MODULE ccs_sample_mem.ccs_ram_sync_singleport
directive set /doCore/core/imCache.dataValid:rsc -MAP_TO_MODULE ccs_sample_mem.ccs_ram_sync_singleport
directive set /doCore/core/dmCache.cacheMemory:rsc -MAP_TO_MODULE ccs_sample_mem.ccs_ram_sync_singleport
directive set /doCore/core/dmCache.age:rsc -MAP_TO_MODULE ccs_sample_mem.ccs_ram_sync_singleport
directive set /doCore/core/dmCache.dataValid:rsc -MAP_TO_MODULE ccs_sample_mem.ccs_ram_sync_singleport
directive set /doCore/core/imCache.cacheMemory:rsc -INTERLEAVE 4
directive set /doCore/core/imCache.age:rsc -INTERLEAVE 4
directive set /doCore/core/imCache.dataValid:rsc -INTERLEAVE 4
directive set /doCore/core/dmCache.cacheMemory:rsc -INTERLEAVE 4
directive set /doCore/core/dmCache.age:rsc -INTERLEAVE 4
directive set /doCore/core/dmCache.dataValid:rsc -INTERLEAVE 4
directive set /doCore/globalStall:rsc -MAP_TO_MODULE {[DirectInput]} directive set /doCore/globalStall:rsc -MAP_TO_MODULE {[DirectInput]}
directive set /doCore/core/core.regFile:rsc -MAP_TO_MODULE {[Register]} directive set /doCore/core/core.regFile:rsc -MAP_TO_MODULE {[Register]}
directive set /doCore/core/while -PIPELINE_INIT_INTERVAL 1 directive set /doCore/core/while -PIPELINE_INIT_INTERVAL 1
...@@ -24,6 +24,18 @@ solution library add Xilinx_FIFO ...@@ -24,6 +24,18 @@ solution library add Xilinx_FIFO
directive set -CLOCKS {clk {-CLOCK_PERIOD 10.0 -CLOCK_EDGE rising -CLOCK_UNCERTAINTY 0.0 -CLOCK_HIGH_TIME 5.0 -RESET_SYNC_NAME rst -RESET_ASYNC_NAME arst_n -RESET_KIND sync -RESET_SYNC_ACTIVE high -RESET_ASYNC_ACTIVE low -ENABLE_ACTIVE high}} directive set -CLOCKS {clk {-CLOCK_PERIOD 10.0 -CLOCK_EDGE rising -CLOCK_UNCERTAINTY 0.0 -CLOCK_HIGH_TIME 5.0 -RESET_SYNC_NAME rst -RESET_ASYNC_NAME arst_n -RESET_KIND sync -RESET_SYNC_ACTIVE high -RESET_ASYNC_ACTIVE low -ENABLE_ACTIVE high}}
directive set /doCore/core/imCache.cacheMemory:rsc -MAP_TO_MODULE Xilinx_RAMS.BLOCK_SPRAM_RBW
directive set /doCore/core/imCache.age:rsc -MAP_TO_MODULE Xilinx_RAMS.BLOCK_SPRAM_RBW
directive set /doCore/core/imCache.dataValid:rsc -MAP_TO_MODULE Xilinx_RAMS.BLOCK_SPRAM_RBW
directive set /doCore/core/dmCache.cacheMemory:rsc -MAP_TO_MODULE Xilinx_RAMS.BLOCK_SPRAM_RBW
directive set /doCore/core/dmCache.age:rsc -MAP_TO_MODULE Xilinx_RAMS.BLOCK_SPRAM_RBW
directive set /doCore/core/dmCache.dataValid:rsc -MAP_TO_MODULE Xilinx_RAMS.BLOCK_SPRAM_RBW
directive set /doCore/imData:rsc -MAP_TO_MODULE Xilinx_RAMS.BLOCK_SPRAM_NOCHANGE directive set /doCore/imData:rsc -MAP_TO_MODULE Xilinx_RAMS.BLOCK_SPRAM_NOCHANGE
directive set /doCore/dmData:rsc -MAP_TO_MODULE Xilinx_RAMS.BLOCK_SPRAM_NOCHANGE directive set /doCore/dmData:rsc -MAP_TO_MODULE Xilinx_RAMS.BLOCK_SPRAM_NOCHANGE
...@@ -24,11 +24,11 @@ BasicSimulator::BasicSimulator(std::string binaryFile, std::vector<std::string> ...@@ -24,11 +24,11 @@ BasicSimulator::BasicSimulator(std::string binaryFile, std::vector<std::string>
mem.reserve(DRAM_SIZE >> 2); mem.reserve(DRAM_SIZE >> 2);
core.im = new SimpleMemory<4>(mem.data()); //core.im = new SimpleMemory<4>(mem.data());
core.dm = new SimpleMemory<4>(mem.data()); //core.dm = new SimpleMemory<4>(mem.data());
// core.im = new CacheMemory<4, 16, 64>(new SimpleMemory<4>(mem.data()), false); core.im = new CacheMemory<4, 16, 64>(new IncompleteMemory<4>(mem.data()), false);
// core.dm = new CacheMemory<4, 16, 64>(new SimpleMemory<4>(mem.data()), false); core.dm = new CacheMemory<4, 16, 64>(new IncompleteMemory<4>(mem.data()), false);
openFiles(inFile, outFile, tFile, sFile); openFiles(inFile, outFile, tFile, sFile);
...@@ -167,6 +167,7 @@ void BasicSimulator::stb(ac_int<32, false> addr, ac_int<8, true> value) ...@@ -167,6 +167,7 @@ void BasicSimulator::stb(ac_int<32, false> addr, ac_int<8, true> value)
ac_int<32, false> wordRes = 0; ac_int<32, false> wordRes = 0;
bool stall = true; bool stall = true;
bool releaseIDM = false;
while (stall) while (stall)
core.dm->process(addr, BYTE, STORE, value, wordRes, stall); core.dm->process(addr, BYTE, STORE, value, wordRes, stall);
...@@ -203,6 +204,7 @@ ac_int<8, true> BasicSimulator::ldb(ac_int<32, false> addr) ...@@ -203,6 +204,7 @@ ac_int<8, true> BasicSimulator::ldb(ac_int<32, false> addr)
result = mem[addr >> 2].slc<8>(((int)addr.slc<2>(0)) << 3); result = mem[addr >> 2].slc<8>(((int)addr.slc<2>(0)) << 3);
core.dm->process(addr, BYTE_U, LOAD, 0, wordRes, stall); core.dm->process(addr, BYTE_U, LOAD, 0, wordRes, stall);
...@@ -554,8 +554,7 @@ void doCycle(struct Core& core, // Core containing all values ...@@ -554,8 +554,7 @@ void doCycle(struct Core& core, // Core containing all values
// declare temporary register file // declare temporary register file
ac_int<32, false> nextInst; ac_int<32, false> nextInst;
if (!localStall && !core.stallDm) core.im->process(core.pc, WORD, (!localStall && !core.stallDm) ? LOAD : NONE, 0, nextInst, core.stallIm);
core.im->process(core.pc, WORD, LOAD, 0, nextInst, core.stallIm);
fetch(core.pc, ftoDC_temp, nextInst); fetch(core.pc, ftoDC_temp, nextInst);
decode(core.ftoDC, dctoEx_temp, core.regFile); decode(core.ftoDC, dctoEx_temp, core.regFile);
...@@ -570,34 +569,35 @@ void doCycle(struct Core& core, // Core containing all values ...@@ -570,34 +569,35 @@ void doCycle(struct Core& core, // Core containing all values
memtoWB_temp.rd, memtoWB_temp.useRd, wbOut_temp.rd, wbOut_temp.useRd, core.stallSignals, memtoWB_temp.rd, memtoWB_temp.useRd, wbOut_temp.rd, wbOut_temp.useRd, core.stallSignals,
forwardRegisters); forwardRegisters);
if (!core.stallSignals[STALL_MEMORY] && !localStall && memtoWB_temp.we && !core.stallIm) { memMask mask;
// TODO: carry the data size to memToWb
memMask mask; switch (core.extoMem.funct3) {
// TODO: carry the data size to memToWb case 0:
switch (core.extoMem.funct3) { mask = BYTE;
case 0: break;
mask = BYTE; case 1:
break; mask = HALF;
case 1: break;
mask = HALF; case 2:
break; mask = WORD;
case 2: break;
mask = WORD; case 4:
break; mask = BYTE_U;
case 4: break;
mask = BYTE_U; case 5:
break; mask = HALF_U;
case 5: break;
mask = HALF_U; // Should NEVER happen
break; default:
// Should NEVER happen mask = WORD;
default: break;
mask = WORD;
break;
core.dm->process(memtoWB_temp.address, mask, memtoWB_temp.isLoad ? LOAD : (memtoWB_temp.isStore ? STORE : NONE),
memtoWB_temp.valueToWrite, memtoWB_temp.result, core.stallDm);
memOpType opType = (!core.stallSignals[STALL_MEMORY] && !localStall && memtoWB_temp.we && !core.stallIm && memtoWB_temp.isLoad) ? LOAD
: (!core.stallSignals[STALL_MEMORY] && !localStall && memtoWB_temp.we && !core.stallIm && memtoWB_temp.isStore ? STORE : NONE);
core.dm->process(memtoWB_temp.address, mask, opType, memtoWB_temp.valueToWrite, memtoWB_temp.result, core.stallDm);
// commit the changes to the pipeline register // commit the changes to the pipeline register
if (!core.stallSignals[STALL_FETCH] && !localStall && !core.stallIm && !core.stallDm) { if (!core.stallSignals[STALL_FETCH] && !localStall && !core.stallIm && !core.stallDm) {
core.ftoDC = ftoDC_temp; core.ftoDC = ftoDC_temp;
...@@ -663,10 +663,11 @@ void doCore(bool globalStall, ac_int<32, false> imData[1 << 24], ac_int<32, fals ...@@ -663,10 +663,11 @@ void doCore(bool globalStall, ac_int<32, false> imData[1 << 24], ac_int<32, fals
IncompleteMemory<4> imInterface = IncompleteMemory<4>(imData); IncompleteMemory<4> imInterface = IncompleteMemory<4>(imData);
IncompleteMemory<4> dmInterface = IncompleteMemory<4>(dmData); IncompleteMemory<4> dmInterface = IncompleteMemory<4>(dmData);
// CacheMemory<4, 16, 64> dmCache = CacheMemory<4, 16, 64>(&dmInterface, false); CacheMemory<4, 16, 64> dmCache = CacheMemory<4, 16, 64>(&dmInterface, false);
CacheMemory<4, 16, 64> imCache = CacheMemory<4, 16, 64>(&imInterface, false);
core.im = &imInterface; core.im = &imCache;
core.dm = &dmInterface; core.dm = &dmCache;
core.pc = 0; core.pc = 0;
while (1) { while (1) {
