Commit 633e8755 authored by Thibault Soucarre's avatar Thibault Soucarre
text_container added
parent eda5ea1b
...@@ -251,6 +251,8 @@ IF(VITE_ENABLE_VBO) ...@@ -251,6 +251,8 @@ IF(VITE_ENABLE_VBO)
render/vbo.hpp render/vbo.hpp
render/Shader.hpp render/Shader.hpp
render/Render_alternate.hpp render/Render_alternate.hpp
render/text2D.hpp
render/texture.hpp
SET(VITE_SRCS SET(VITE_SRCS
...@@ -258,6 +260,8 @@ IF(VITE_ENABLE_VBO) ...@@ -258,6 +260,8 @@ IF(VITE_ENABLE_VBO)
render/vbo.cpp render/vbo.cpp
render/Shader.cpp render/Shader.cpp
render/Render_alternate.cpp render/Render_alternate.cpp
render/text2D.cpp
render/texture.cpp
ENDIF(VITE_ENABLE_VBO) ENDIF(VITE_ENABLE_VBO)
...@@ -67,7 +67,7 @@ struct Container_text_{ ...@@ -67,7 +67,7 @@ struct Container_text_{
* \brief Coordinates. * \brief Coordinates.
Element_pos x, y; Element_pos x, y, size;
* \brief Text. * \brief Text.
...@@ -238,7 +238,7 @@ public: ...@@ -238,7 +238,7 @@ public:
_container_texts[i].x *= (Info::Render::width/Info::Container::x_max)*_x_scale_container_state; _container_texts[i].x *= (Info::Render::width/Info::Container::x_max)*_x_scale_container_state;
_container_texts[i].y = trace_to_render_y(_container_texts[i].y);// + _render_height-_ruler_height)*coeff_trace_render_y(); _container_texts[i].y = trace_to_render_y(_container_texts[i].y);// + _render_height-_ruler_height)*coeff_trace_render_y();
drawing_instance->draw_text(_container_texts[i].x, _container_texts[i].y, _z_container+1, _container_texts[i].value); drawing_instance->draw_text(_container_texts[i].x, _container_texts[i].y, /*_z_container+1*/_containers[i].w * (Info::Render::width/Info::Container::x_max)*_x_scale_container_state, _container_texts[i].value);
drawing_instance->end_draw_containers(); drawing_instance->end_draw_containers();
...@@ -68,6 +68,7 @@ ...@@ -68,6 +68,7 @@
#include "render/Render_alternate.hpp" #include "render/Render_alternate.hpp"
#include "render/GanttDiagram.hpp" #include "render/GanttDiagram.hpp"
#include "render/Shader.hpp" #include "render/Shader.hpp"
#include "render/text2D.hpp"
#include "core/Core.hpp" #include "core/Core.hpp"
#include "render/vbo.hpp" #include "render/vbo.hpp"
...@@ -104,6 +105,7 @@ Render_alternate::Render_alternate(Core* core, QWidget *parent, const QGLFormat& ...@@ -104,6 +105,7 @@ Render_alternate::Render_alternate(Core* core, QWidget *parent, const QGLFormat&
Render_alternate::~Render_alternate(){ Render_alternate::~Render_alternate(){
cleanupText2D();
...@@ -135,6 +137,7 @@ void Render_alternate::initializeGL() { ...@@ -135,6 +137,7 @@ void Render_alternate::initializeGL() {
std::cout << "init ok" << std::endl; std::cout << "init ok" << std::endl;
_modelview = glm::scale(_modelview, glm::vec3(1,-1,1)); _modelview = glm::scale(_modelview, glm::vec3(1,-1,1));
_modelview = glm::translate(_modelview, glm::vec3(0,-Info::Render::height, 0)); _modelview = glm::translate(_modelview, glm::vec3(0,-Info::Render::height, 0));
initText2D("Holstein.DDS");
void Render_alternate::resizeGL(int width, int height) { void Render_alternate::resizeGL(int width, int height) {
...@@ -184,7 +187,7 @@ void Render_alternate::paintGL(){ ...@@ -184,7 +187,7 @@ void Render_alternate::paintGL(){
/* drawing containers*/ /* drawing containers*/
_containers.lock(); _containers.lock();
//_modelview = glm::translate(_modelview, glm::vec3(0.0f, _ruler_y + _ruler_height -_y_state_translate, _z_container)); //_modelview = glm::translate(_modelview, glm::vec3(0.0f, _ruler_y + _ruler_height -_y_state_translate, _z_container));
//_modelview = glm::scale(_modelview, glm::vec3(_x_scale_container_state/0.20, _y_state_scale, 1.0)); _modelview = glm::scale(_modelview, glm::vec3(_x_scale_container_state/0.20, _y_state_scale, 1.0));
glUniformMatrix4fv(glGetUniformLocation(_shader.getProgramID(), "modelview"), 1, GL_FALSE, glm::value_ptr(_modelview)); glUniformMatrix4fv(glGetUniformLocation(_shader.getProgramID(), "modelview"), 1, GL_FALSE, glm::value_ptr(_modelview));
glUniformMatrix4fv(glGetUniformLocation(_shader.getProgramID(), "projection"), 1, GL_FALSE, glm::value_ptr(_projection)); glUniformMatrix4fv(glGetUniformLocation(_shader.getProgramID(), "projection"), 1, GL_FALSE, glm::value_ptr(_projection));
glDrawArrays(GL_QUADS, 0, _containers.getNbVertex()); glDrawArrays(GL_QUADS, 0, _containers.getNbVertex());
...@@ -229,10 +232,23 @@ void Render_alternate::paintGL(){ ...@@ -229,10 +232,23 @@ void Render_alternate::paintGL(){
//restore matrix //restore matrix
_modelview = tmp; _modelview = tmp;
// _containers.display(_modelview); // _containers.display(_modelview);
//rendu //rendu
//deselect shader //deselect shader
glUseProgram(0); glUseProgram(0);
//_modelview = glm::translate(_modelview, glm::vec3(0.0, -100*Info::Render::height, 0.0));
//_modelview = glm::scale(_modelview, glm::vec3(1000,100,1));
for(int i=0; i<_texts.size(); i++){
glm::vec4 current(_texts[i].x, _texts[i].y, 0.0, 1.0);
//we get coordinates beetween (-1 ; 1)
current = _projection * _modelview * current;
//conversion to (0,800) and (0,600) corresponding to the size of the texture used
current[0] = current[0] * 400 + 400;
current[1] = current[1] * 300 + 300;
printText2D(_texts[i].value.c_str(), current[0], current[1], _texts[i].size, _projection, _modelview);
_modelview = tmp;
// Render_alternate::QGLWidget::setFocus(Qt::ActiveWindowFocusReason);/* give the focus to the render area for mouse and keyboard events */ // Render_alternate::QGLWidget::setFocus(Qt::ActiveWindowFocusReason);/* give the focus to the render area for mouse and keyboard events */
...@@ -664,16 +680,15 @@ void Render_alternate::set_color(float r, float g, float b){ ...@@ -664,16 +680,15 @@ void Render_alternate::set_color(float r, float g, float b){
_b = b; _b = b;
void Render_alternate::draw_text(const Element_pos x, const Element_pos y, const Element_pos, const std::string s){ void Render_alternate::draw_text(const Element_pos x, const Element_pos y, const Element_pos size, const std::string s){
if (_draw_ruler) return;/* do not draw text for ruler */ if (_draw_ruler) return;/* do not draw text for ruler */
const Element_pos offset_y = -_ruler_y - _ruler_height;
Container_text_ buf; Container_text_ buf;
buf.x = x;
buf.x = x; buf.y = y + offset_y; //render_to_trace_y(y);/* Cancel previous transformation. */
buf.y = render_to_trace_y(y);/* Cancel previous transformation. */ buf.value = s;
buf.value = s; buf.size = size;
_texts.push_back(buf);
//_texts.push_back(buf);
...@@ -692,8 +707,8 @@ void Render_alternate::draw_quad(Element_pos x, Element_pos y, Element_pos z, El ...@@ -692,8 +707,8 @@ void Render_alternate::draw_quad(Element_pos x, Element_pos y, Element_pos z, El
else if(_draw_states){ else if(_draw_states){
offset_x = -_default_entity_x_translate; offset_x = -_default_entity_x_translate;
_states.add(x+offset_x , y+offset_y , _r, _g, _b); _states.add(x+offset_x , y+offset_y , _r, _g, _b);
_states.add(x+offset_x+w, y+offset_y , _r, _g, _b); _states.add(x+offset_x+w, y+offset_y , _r/2, _g/2, _b/2);
_states.add(x+offset_x+w, y+offset_y+h, _r, _g, _b); _states.add(x+offset_x+w, y+offset_y+h, _r/2, _g/2, _b/2);
_states.add(x+offset_x , y+offset_y+h, _r, _g, _b); _states.add(x+offset_x , y+offset_y+h, _r, _g, _b);
...@@ -125,7 +125,7 @@ protected: ...@@ -125,7 +125,7 @@ protected:
// GLuint _wait_list; // GLuint _wait_list;
//std::vector<Container_text_> _texts; std::vector<Container_text_> _texts;
//std::vector<Arrow_> _arrows; //std::vector<Arrow_> _arrows;
//std::vector<Event_> _circles; //std::vector<Event_> _circles;
Vbo _containers; Vbo _containers;
#include <vector>
#include <cstring>
#include <GL/glew.h>
#define GLM_FORCE_RADIANS
#include <glm/glm.hpp>
#include <glm/gtc/matrix_transform.hpp>
#include <glm/gtc/type_ptr.hpp>
using namespace glm;
#include "Shader.hpp"
#include "texture.hpp"
#include "text2D.hpp"
unsigned int Text2DTextureID;
unsigned int Text2DVertexBufferID;
unsigned int Text2DUVBufferID;
Shader* _shader;
unsigned int Text2DUniformID;
void initText2D(const char * texturePath){
// Initialize texture
Text2DTextureID = loadDDS(texturePath);
// Initialize VBO
glGenBuffers(1, &Text2DVertexBufferID);
glGenBuffers(1, &Text2DUVBufferID);
// Initialize Shader
_shader = new Shader("TextVertexShader.vertexshader", "TextVertexShader.fragmentshader");
_shader->charger();
// Initialize uniforms' IDs
Text2DUniformID = glGetUniformLocation( _shader->getProgramID(), "myTextureSampler" );
void printText2D(const char * text, int x, int y, int size, glm::mat4 projection, glm::mat4 modelview){
unsigned int length = strlen(text);
// Fill buffers
std::vector<glm::vec2> vertices;
std::vector<glm::vec2> UVs;
for ( unsigned int i=0 ; i<length ; i++ ){
glm::vec2 vertex_up_left = glm::vec2( x+i*size , y+size );
glm::vec2 vertex_up_right = glm::vec2( x+i*size+size, y+size );
glm::vec2 vertex_down_right = glm::vec2( x+i*size+size, y );
glm::vec2 vertex_down_left = glm::vec2( x+i*size , y );
vertices.push_back(vertex_up_left );
vertices.push_back(vertex_down_left );
vertices.push_back(vertex_up_right );
vertices.push_back(vertex_down_right);
vertices.push_back(vertex_up_right);
vertices.push_back(vertex_down_left);
char character = text[i];
float uv_x = (character%16)/16.0f;
float uv_y = (character/16)/16.0f;
glm::vec2 uv_up_left = glm::vec2( uv_x , uv_y );
glm::vec2 uv_up_right = glm::vec2( uv_x+1.0f/16.0f, uv_y );
glm::vec2 uv_down_right = glm::vec2( uv_x+1.0f/16.0f, (uv_y + 1.0f/16.0f) );
glm::vec2 uv_down_left = glm::vec2( uv_x , (uv_y + 1.0f/16.0f) );
UVs.push_back(uv_up_left );
UVs.push_back(uv_down_left );
UVs.push_back(uv_up_right );
UVs.push_back(uv_down_right);
UVs.push_back(uv_up_right);
UVs.push_back(uv_down_left);
glBindBuffer(GL_ARRAY_BUFFER, Text2DVertexBufferID);
glBufferData(GL_ARRAY_BUFFER, vertices.size() * sizeof(glm::vec2), &vertices[0], GL_STATIC_DRAW);
glBindBuffer(GL_ARRAY_BUFFER, Text2DUVBufferID);
glBufferData(GL_ARRAY_BUFFER, UVs.size() * sizeof(glm::vec2), &UVs[0], GL_STATIC_DRAW);
// Bind shader
glUseProgram(_shader->getProgramID());
// Bind texture
glActiveTexture(GL_TEXTURE0);
glBindTexture(GL_TEXTURE_2D, Text2DTextureID);
// Set our "myTextureSampler" sampler to user Texture Unit 0
glUniform1i(Text2DUniformID, 0);
glUniformMatrix4fv(glGetUniformLocation(_shader->getProgramID(), "modelview"), 1, GL_FALSE, glm::value_ptr(modelview));
glUniformMatrix4fv(glGetUniformLocation(_shader->getProgramID(), "projection"), 1, GL_FALSE, glm::value_ptr(projection));
// 1rst attribute buffer : vertices
glEnableVertexAttribArray(0);
glVertexAttribPointer(0, 2, GL_FLOAT, GL_FALSE, 0, (void*)0 );
// 2nd attribute buffer : UVs
glEnableVertexAttribArray(1);
glVertexAttribPointer(1, 2, GL_FLOAT, GL_FALSE, 0, (void*)0 );
glEnable(GL_BLEND);
glBlendFunc(GL_SRC_ALPHA, GL_ONE_MINUS_SRC_ALPHA);
// Draw call
glDrawArrays(GL_TRIANGLES, 0, vertices.size() );
glDisable(GL_BLEND);
glDisableVertexAttribArray(0);
glDisableVertexAttribArray(1);
void cleanupText2D(){
// Delete buffers
glDeleteBuffers(1, &Text2DVertexBufferID);
glDeleteBuffers(1, &Text2DUVBufferID);
// Delete texture
glDeleteTextures(1, &Text2DTextureID);
// Delete shader
glDeleteProgram(_shader->getProgramID());
#ifndef TEXT2D_HPP
#define TEXT2D_HPP
void initText2D(const char * texturePath);
void printText2D(const char * text, int x, int y, int size, glm::mat4, glm::mat4);
void cleanupText2D();
#endif
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
//#include <glfw3.h>
/*GLuint loadBMP_custom(const char * imagepath){
printf("Reading image %s\n", imagepath);
// Data read from the header of the BMP file
unsigned char header[54];
unsigned int dataPos;
unsigned int imageSize;
unsigned int width, height;
// Actual RGB data
unsigned char * data;
// Open the file
FILE * file = fopen(imagepath,"rb");
if (!file) {printf("%s could not be opened. Are you in the right directory ? Don't forget to read the FAQ !\n", imagepath); getchar(); return 0;}
// Read the header, i.e. the 54 first bytes
// If less than 54 bytes are read, problem
if ( fread(header, 1, 54, file)!=54 ){
printf("Not a correct BMP file\n");
return 0;
// A BMP files always begins with "BM"
if ( header[0]!='B' || header[1]!='M' ){
return 0;
// Make sure this is a 24bpp file
if ( *(int*)&(header[0x1E])!=0 ) {printf("Not a correct BMP file\n"); return 0;}
if ( *(int*)&(header[0x1C])!=24 ) {printf("Not a correct BMP file\n"); return 0;}
// Read the information about the image
dataPos = *(int*)&(header[0x0A]);
imageSize = *(int*)&(header[0x22]);
width = *(int*)&(header[0x12]);
height = *(int*)&(header[0x16]);
// Some BMP files are misformatted, guess missing information
if (imageSize==0) imageSize=width*height*3; // 3 : one byte for each Red, Green and Blue component
if (dataPos==0) dataPos=54; // The BMP header is done that way
// Create a buffer
data = new unsigned char [imageSize];
// Read the actual data from the file into the buffer
fread(data,1,imageSize,file);
// Everything is in memory now, the file wan be closed
fclose (file);
// Create one OpenGL texture
GLuint textureID;
glGenTextures(1, &textureID);
// "Bind" the newly created texture : all future texture functions will modify this texture
glBindTexture(GL_TEXTURE_2D, textureID);
// Give the image to OpenGL
glTexImage2D(GL_TEXTURE_2D, 0,GL_RGB, width, height, 0, GL_BGR, GL_UNSIGNED_BYTE, data);
// OpenGL has now copied the data. Free our own version
delete [] data;
// Poor filtering, or ...
//glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
//glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
// ... nice trilinear filtering.
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR_MIPMAP_LINEAR);
glGenerateMipmap(GL_TEXTURE_2D);
// Return the ID of the texture we just created
return textureID;
// Since GLFW 3, glfwLoadTexture2D() has been removed. You have to use another texture loading library,
// or do it yourself (just like loadBMP_custom and loadDDS)
//GLuint loadTGA_glfw(const char * imagepath){
// // Create one OpenGL texture
// GLuint textureID;
// glGenTextures(1, &textureID);
// // "Bind" the newly created texture : all future texture functions will modify this texture
// glBindTexture(GL_TEXTURE_2D, textureID);
// // Read the file, call glTexImage2D with the right parameters
// glfwLoadTexture2D(imagepath, 0);
// // Nice trilinear filtering.
// glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT);
// glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT);
// glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_LINEAR);
// glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_LINEAR_MIPMAP_LINEAR);
// glGenerateMipmap(GL_TEXTURE_2D);
// // Return the ID of the texture we just created
// return textureID;
#define FOURCC_DXT1 0x31545844 // Equivalent to "DXT1" in ASCII
#define FOURCC_DXT3 0x33545844 // Equivalent to "DXT3" in ASCII
#define FOURCC_DXT5 0x35545844 // Equivalent to "DXT5" in ASCII
GLuint loadDDS(const char * imagepath){
unsigned char header[124];
FILE *fp;
/* try to open the file */
fp = fopen(imagepath, "rb");
if (fp == NULL){
return 0;
/* verify the type of file */
char filecode[4];
fread(filecode, 1, 4, fp);
if (strncmp(filecode, "DDS ", 4) != 0) {
fclose(fp);
return 0;
/* get the surface desc */
fread(&header, 124, 1, fp);
unsigned int height = *(unsigned int*)&(header[8 ]);
unsigned int width = *(unsigned int*)&(header[12]);
unsigned int linearSize = *(unsigned int*)&(header[16]);
unsigned int mipMapCount = *(unsigned int*)&(header[24]);
unsigned int fourCC = *(unsigned int*)&(header[80]);
unsigned char * buffer;
unsigned int bufsize;
/* how big is it going to be including all mipmaps? */
bufsize = mipMapCount > 1 ? linearSize * 2 : linearSize;
buffer = (unsigned char*)malloc(bufsize * sizeof(unsigned char));
fread(buffer, 1, bufsize, fp);
/* close the file pointer */
fclose(fp);
unsigned int components = (fourCC == FOURCC_DXT1) ? 3 : 4;
unsigned int format;
switch(fourCC)
case FOURCC_DXT1:
format = GL_COMPRESSED_RGBA_S3TC_DXT1_EXT;
break;
case FOURCC_DXT3:
format = GL_COMPRESSED_RGBA_S3TC_DXT3_EXT;
break;
case FOURCC_DXT5:
format = GL_COMPRESSED_RGBA_S3TC_DXT5_EXT;
break;
default:
free(buffer);
return 0;
GLuint textureID;
glPixelStorei(GL_UNPACK_ALIGNMENT,1);
unsigned int blockSize = (format == GL_COMPRESSED_RGBA_S3TC_DXT1_EXT) ? 8 : 16;
unsigned int offset = 0;
/* load the mipmaps */
for (unsigned int level = 0; level < mipMapCount && (width || height); ++level)
unsigned int size = ((width+3)/4)*((height+3)/4)*blockSize;
glCompressedTexImage2D(GL_TEXTURE_2D, level, format, width, height,
0, size, buffer + offset);
offset += size;
width /= 2;
height /= 2;
// Deal with Non-Power-Of-Two textures. This code is not included in the webpage to reduce clutter.
if(width < 1) width = 1;
if(height < 1) height = 1;
free(buffer);
return textureID;
#ifndef TEXTURE_HPP
#define TEXTURE_HPP
// Load a .BMP file using our custom loader
//GLuint loadBMP_custom(const char * imagepath);
//// Since GLFW 3, glfwLoadTexture2D() has been removed. You have to use another texture loading library,
//// or do it yourself (just like loadBMP_custom and loadDDS)
//// Load a .TGA file using GLFW's own loader
//GLuint loadTGA_glfw(const char * imagepath);
// Load a .DDS file using GLFW's own loader
GLuint loadDDS(const char * imagepath);
#endif
