GitLab
Support
Community forum
Keyboard shortcuts
vite
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Analytics
Analytics
Value Stream
solverstack
vite
e7434a41
e7434a41
Thibault Soucarre
add counters
338e0166
2
2 changed files
23 additions
12 deletions
+23
-12
src/render/Render_alternate.cpp
+10
src/trace/DrawTrace.hpp
+13
-12
e7434a41
@@ -199,6 +199,16 @@ void Render_alternate::paintGL(){
glUniformMatrix4fv
glGetUniformLocation
_shader
getProgramID
"projection"
GL_FALSE
glm
value_ptr
_projection
glDrawArrays
GL_QUADS
_states
getNbVertex
_states
unlock
//_modelview = tmp;
/*drawing counters*/
_counters
lock
//_modelview = glm::translate(_modelview, glm::vec3(0.0, _ruler_y + _ruler_height - _y_state_translate, _z_container));
//_modelview = glm::scale(_modelview, glm::vec3(_x_scale_container_state/0.20, _y_state_scale, 1.0));
//glUniformMatrix4fv(glGetUniformLocation(_shader.getProgramID(), "modelview"), 1, GL_FALSE, glm::value_ptr(_modelview));
//glUniformMatrix4fv(glGetUniformLocation(_shader.getProgramID(), "projection"), 1, GL_FALSE, glm::value_ptr(_projection));
glDrawArrays
GL_LINES
_counters
getNbVertex
_counters
unlock
_modelview
tmp
/*drawing links*/
e7434a41
@@ -287,7 +287,7 @@ public:
i
// Use the fact that if a container is selected, then it implies that all his ancestors are
if
is_in_set
i
container
y
browse_container
draw_object
i
0.
y
_container_width
0.
container
y
browse_container
draw_object
i
0.
y
_container_width
0.
container
_container_v_space
/* end browse_container_tree */
@@ -315,6 +315,7 @@ public:
i
h
browse_container
draw_object
i
x
_container_width
_container_h_space
y
h
_container_width
0.
set_container
_container_v_space
// h -= _container_v_space;
/*if(is_in_set(*i,set_container))
size += browse_container(draw_object, (*i), position+size, depth+1,set_container);*/
@@ -333,18 +334,16 @@ public:
// Store the position to draw links
_container_positions
container
y
_container_sizes
container
h
// Use one line for each variable
if
container
get_variable_number
_variable_containers
push_back
container
h
_container_height
_container_v_space
container
get_variable_number
container
y
_container_sizes
container
h
h
_container_v_space
if
h
_container_height
// Minimum size
h
_container_height
@@ -352,6 +351,8 @@ public:
if
container
get_links
empty
_link_containers
push_back
container
h
_container_v_space
// Draw this container
draw_container
draw_object
x
y
w
h
container
get_name
to_string
@@ -529,8 +530,8 @@ public:
double
first_value
0.
double
second_value
0.
draw_object
draw_text_value
long
int
var
0.0
position
_container_height
_container_v_space
_container_v_space
2
0.5
_container_height
//draw_object->draw_text_value((long int)var,0.0, (position+1)*(_container_height+_container_v_space) - _container_v_space/2 - 0.5*_container_height);
draw_object
draw_text_value
long
int
var
0.0
position
0.5
_container_height
_container_v_space
2
_var_positions
var
position
draw_variable_value
draw_object
0.0
0.0
position
for
std
list
std
pair
Date
Double
const_iterator
value
variable_values
begin
@@ -546,7 +547,7 @@ public:
draw_variable_value
draw_object
0.0
0.0
position
position
// One line was used
position
_container_height
_container_v_space
/* end for */
//end for
@@ -563,8 +564,8 @@ public:
* \param position Line where the variable is drawn
template
class
T
inline
void
draw_variable_value
T
draw_object
double
time
double
value
int
position
Element_pos
y
position
_container_height
_container_v_space
_container_v_space
2
inline
void
draw_variable_value
T
draw_object
double
time
double
value
Element_pos
position
Element_pos
y
position
_container_height
_container_v_space
_container_v_space
2
value
_container_height
draw_object
draw_counter
time
y
