Commit ceaceb7a authored by Olivier Lagrasse's avatar Olivier Lagrasse
Quick commit for Mateo :p
parent d27a255d
...@@ -123,7 +123,6 @@ doc: ...@@ -123,7 +123,6 @@ doc:
@echo " " @echo " "
clean: clean:
make -C \$(OTFLIB_DIR) clean
cd ./src && make clean cd ./src && make clean
\$(RM) log.txt \$(RM) log.txt
@echo " " @echo " "
...@@ -132,6 +131,7 @@ clean: ...@@ -132,6 +131,7 @@ clean:
cleanall: clean cleanall: clean
make -C \$(DOCUMENTATION)/user_manual cleanall make -C \$(DOCUMENTATION)/user_manual cleanall
make -C \$(DOCUMENTATION)/technical_manual cleanall make -C \$(DOCUMENTATION)/technical_manual cleanall
@(cd bin/ && \$(RM) vite) @(cd bin/ && \$(RM) vite)
...@@ -86,6 +86,13 @@ public: ...@@ -86,6 +86,13 @@ public:
const static QByteArray DEFAULT_STATE; const static QByteArray DEFAULT_STATE;
* \brief Sub structure to store render information.
struct Render{
#endif #endif
...@@ -65,7 +65,7 @@ const int Hook_event::_ctrl_zoom_factor = 3; ...@@ -65,7 +65,7 @@ const int Hook_event::_ctrl_zoom_factor = 3;
void Hook_event::updateRender(){ void Hook_event::updateRender(){
_render_instance->update(); _render_instance->updateGL();
...@@ -286,7 +286,7 @@ public: ...@@ -286,7 +286,7 @@ public:
inline void start_draw_arrows(){ inline void start_draw_arrows(){
drawing_instance->start_draw_arrows(); drawing_instance->start_draw_arrows();
drawing_instance->set_color(1, 1, 0); drawing_instance->set_color(1, 1, 1);
...@@ -165,14 +165,12 @@ void Render_opengl::resizeGL(int width, int height) { ...@@ -165,14 +165,12 @@ void Render_opengl::resizeGL(int width, int height) {
void Render_opengl::paintGL(){
/*void Render_opengl::paintGL(){
// paintEvent(NULL); // paintEvent(NULL);
cout << __FILE__ << " " << __LINE__ << endl; // cout << __FILE__ << " " << __LINE__ << endl;
void Render_opengl::paintEvent(QPaintEvent *)
resizeGL(Render_opengl::QGLWidget::width(), Render_opengl::QGLWidget::height()); resizeGL(Render_opengl::QGLWidget::width(), Render_opengl::QGLWidget::height());
Render_opengl::QGLWidget::setFocus(Qt::ActiveWindowFocusReason);/* give the focus to the render area for mouse and keyboard events */ Render_opengl::QGLWidget::setFocus(Qt::ActiveWindowFocusReason);/* give the focus to the render area for mouse and keyboard events */
...@@ -374,13 +372,13 @@ void Render_opengl::resizeGL(int width, int height) { ...@@ -374,13 +372,13 @@ void Render_opengl::resizeGL(int width, int height) {
QFont font("Arial", 15); /* QFont font("Arial", 15);
font.setStyle(QFont::StyleOblique); font.setStyle(QFont::StyleOblique);
painter.setFont(font); painter.setFont(font);
painter.setOpacity(0.5); painter.setOpacity(0.5);
painter.drawText(Info::Screen::width-320, Info::Screen::height-10, "Rendering mode - work in progress"); painter.drawText(Info::Screen::width-320, Info::Screen::height-10, "Rendering mode - work in progress");
painter.end(); painter.end();
...@@ -562,9 +560,9 @@ GLuint Render_opengl::draw_wait() { ...@@ -562,9 +560,9 @@ GLuint Render_opengl::draw_wait() {
if (_wait_timer == NULL){ if (_wait_timer == NULL){
_wait_angle = 0.0f; _wait_angle = 0.0f;
_wait_timer = new QTimer(this); // _wait_timer = new QTimer(this);
connect(_wait_timer, SIGNAL(timeout()), _render_instance, SLOT(updateGL())); //connect(_wait_timer, SIGNAL(timeout()), _render_instance, SLOT(updateGL()));
_wait_timer->start(_wait_spf); //_wait_timer->start(_wait_spf);
return object; return object;
...@@ -670,7 +668,6 @@ void Render_opengl::call_ruler(){ ...@@ -670,7 +668,6 @@ void Render_opengl::call_ruler(){
// Info::Render::_ui_render_max_value->setText(buf_txt.str().c_str()); // Info::Render::_ui_render_max_value->setText(buf_txt.str().c_str());
set_color(1, 1, 0);
for (Element_pos i = Info::Render::_x_min_visible ; i < Info::Render::_x_max_visible ; i+=graduation_diff){ for (Element_pos i = Info::Render::_x_min_visible ; i < Info::Render::_x_max_visible ; i+=graduation_diff){
const Element_pos grad_div_by_5 = graduation_diff/5; const Element_pos grad_div_by_5 = graduation_diff/5;
for (Element_pos j = (i+grad_div_by_5) ; j<(i+graduation_diff) ; j+= grad_div_by_5){ for (Element_pos j = (i+grad_div_by_5) ; j<(i+graduation_diff) ; j+= grad_div_by_5){
...@@ -681,7 +678,7 @@ void Render_opengl::call_ruler(){ ...@@ -681,7 +678,7 @@ void Render_opengl::call_ruler(){
draw_line( trace_to_render_x(i) + offset_x, offset_y , draw_line( trace_to_render_x(i) + offset_x, offset_y ,
trace_to_render_x(i) + offset_x, 4+offset_y, _z_ruler); trace_to_render_x(i) + offset_x, 4+offset_y, _z_ruler);
// buf_txt.str("");/* flush the buffer */ // buf_txt.str("");/* flush the buffer */
//buf_txt << Ruler::get_variable_part(i, coeff_prefix, 2); //buf_txt << Ruler::get_variable_part(i, coeff_prefix, 2);
/* Draw text with GLUT */ /* Draw text with GLUT */
...@@ -709,6 +706,16 @@ void Render_opengl::call_ruler(){ ...@@ -709,6 +706,16 @@ void Render_opengl::call_ruler(){
glBegin(GL_QUADS);
glColor4d(0, 0, 1, 1);
glVertex3d(trace_to_render_x(Info::Render::_x_min_visible) , 0, -2 );
glVertex3d(trace_to_render_x(Info::Render::_x_min_visible) , 5, -2 );
glVertex3d(trace_to_render_x(Info::Render::_x_max_visible) , 5, -2 );
glVertex3d(trace_to_render_x(Info::Render::_x_max_visible) , 0, -2 );
glEnd();
//painter.setPen(Qt::NoPen); //painter.setPen(Qt::NoPen);
//painter.setBrush(QColor(125, 125, 150)); //painter.setBrush(QColor(125, 125, 150));
...@@ -924,7 +931,7 @@ void Render_opengl::draw_stored_arrows(){ ...@@ -924,7 +931,7 @@ void Render_opengl::draw_stored_arrows(){
Element_pos start_time, end_time, start_height, end_height; Element_pos start_time, end_time, start_height, end_height;
Element_pos scaled_start_time, scaled_end_time, scaled_start_height, scaled_end_height; Element_pos scaled_start_time, scaled_end_time, scaled_start_height, scaled_end_height;
set_color(1, 1, 0); set_color(1, 1, 1);
for (unsigned int i=0 ; i<_arrows.size() ; i++){ for (unsigned int i=0 ; i<_arrows.size() ; i++){
...@@ -988,7 +995,7 @@ void Render_opengl::draw_stored_circles(){ ...@@ -988,7 +995,7 @@ void Render_opengl::draw_stored_circles(){
const float angle = M_PI/2.0f; const float angle = M_PI/2.0f;
const float delta_angle = 2*M_PI/step; const float delta_angle = 2*M_PI/step;
for (unsigned int i=0 ; i<_circles.size() ; i++){ for (unsigned int i=0 ; i<_circles.size() ; i++){
...@@ -218,7 +218,7 @@ public: ...@@ -218,7 +218,7 @@ public:
* \brief Call by the system each time the render area need to be updated. * \brief Call by the system each time the render area need to be updated.
// void paintGL(); void paintGL();
...@@ -537,7 +537,6 @@ public: ...@@ -537,7 +537,6 @@ public:
void draw_stored_circles(); void draw_stored_circles();
void draw_stored_texts(); void draw_stored_texts();
void paintEvent(QPaintEvent *);
