Commit c81031c7 authored by Johnny Jazeix's avatar Johnny Jazeix
tag of 1.1 is r1005 and not r999
parent d5c6b9a5
...@@ -49,17 +49,38 @@ UNAME_SYSTEM=`(uname -s) 2>/dev/null` || UNAME_SYSTEM=unknown ...@@ -49,17 +49,38 @@ UNAME_SYSTEM=`(uname -s) 2>/dev/null` || UNAME_SYSTEM=unknown
makefile="Makefile" makefile="Makefile"
with_otf=0 with_otf=0
config_specified=0
# where will we concatenate options like macros, libs... # where will we concatenate options like macros, libs...
compilation_src_pro="src.pro" compilation_src_pro="src.pro"
# For qmake # For qmake
config="\"CONFIG+="
defines="\"DEFINES+=" defines="\"DEFINES+="
libs="\"LIBS+=" libs="\"LIBS+="
includes="\"INCLUDES+=" includes="\"INCLUDES+="
sources="\"SOURCES+=" sources="\"SOURCES+="
headers="\"HEADERS+=" headers="\"HEADERS+="
echo ""
echo "-------------------------------"
echo ""
echo " Visual Trace Explorer"
echo " - configuration -"
echo ""
echo ""
echo " type './configure -h' for help "
echo ""
echo ""
echo " Default mode is:"
echo " * RELEASE mode"
echo ""
echo ""
echo ""
usage() usage()
echo "ViTE configuration shell-script" echo "ViTE configuration shell-script"
...@@ -67,11 +88,20 @@ usage() ...@@ -67,11 +88,20 @@ usage()
echo " ./configure [ options ]" echo " ./configure [ options ]"
echo echo
echo "Options:" echo "Options:"
echo " --help" echo " -h, --help"
echo " -h print this page" echo " print this page"
echo echo ""
echo " --enable_spinning_logo makes the rabbit to turn when no trace is loaded" echo " --release"
echo " --enable_otf enables the otf support. The otf release used by default is in the src/general directory" echo " compiles in release mode (by default)"
echo ""
echo " --debug"
echo " compiles in debug mode"
echo ""
echo " --enable_spinning_logo"
echo " makes the rabbit to turn when no trace is loaded"
echo ""
echo " --enable_otf"
echo " enables the otf support. The otf release used by default is in the src/general directory"
## Will be added later ## Will be added later
# echo " --otf_include_dir=<path> set the otf directory path" # echo " --otf_include_dir=<path> set the otf directory path"
# echo " --otf_library_dir=<path> set the otf library path (<path>/libotf.a)" # echo " --otf_library_dir=<path> set the otf library path (<path>/libotf.a)"
...@@ -98,22 +128,34 @@ while [ 0 -lt $# ]; do ...@@ -98,22 +128,34 @@ while [ 0 -lt $# ]; do
--enable_spinning_logo) # good openGL spinning rabbit :) --enable_spinning_logo) # good openGL spinning rabbit :)
defines="$defines SPINNING_LOGO" defines="$defines SPINNING_LOGO"
--release)
config_specified=1;
config="$config release"
--debug)
config_specified=1;
config="$config debug"
echo "invalid option : $OPT"; echo "invalid option : $OPT";
exit 0; exit 0;
esac esac
done done
#end the qmake options #end the qmake options
if [ $config_specified == 1 ]; then
config="$config\"";
else
config="$config release\"";
fi
defines="$defines\""; defines="$defines\"";
libs="$libs\""; libs="$libs\"";
includes="$includes\""; includes="$includes\"";
sources="$sources\""; sources="$sources\"";
headers="$headers\""; headers="$headers\"";
compilation_src_pro="$defines $libs $includes $sources $headers"; compilation_src_pro="$defines $config $libs $includes $sources $headers";
# find a make command # find a make command
if [ -z "$MAKE" ]; then if [ -z "$MAKE" ]; then
...@@ -71,12 +71,12 @@ ...@@ -71,12 +71,12 @@
* \def VITE_VERSION * \def VITE_VERSION
* \brief the ViTE version (string) * \brief the ViTE version (string)
#define VITE_VERSION "1.1-alpha1" #define VITE_VERSION "1.1"
* \def VITE_DATE * \def VITE_DATE
* \brief the ViTE release date (string) * \brief the ViTE release date (string)
#define VITE_DATE "December 2009" #define VITE_DATE "January 2010"
* \def VITE_WEBSITE * \def VITE_WEBSITE
* \brief the ViTE website (string) * \brief the ViTE website (string)
...@@ -46,7 +46,7 @@ ...@@ -46,7 +46,7 @@
#RESOURCES= vite.qrc #RESOURCES= vite.qrc
OBJECTS_DIR=../bin OBJECTS_DIR=../bin
DESTDIR=../bin DESTDIR=../bin
CONFIG+=uitools debug CONFIG+=uitools
QT+=opengl QT+=opengl
TEMPLATE = app TEMPLATE = app
TARGET = vite TARGET = vite
