Commit bdba6e92 authored by Mathieu Faverge's avatar Mathieu Faverge
Cleanup(spaces)
parent dfa9db84
...@@ -18,10 +18,10 @@ static inline int32_t imax(int32_t a, int32_t b) ...@@ -18,10 +18,10 @@ static inline int32_t imax(int32_t a, int32_t b)
/* Macros */ /* Macros */
#define memFree(ptr) free((void*)(ptr)) #define memFree(ptr) free((void*)(ptr))
#define memFree_null(ptr) do \ #define memFree_null(ptr) do \
memFree( ptr ); \ memFree( ptr ); \
(ptr) = nullptr; \ (ptr) = nullptr; \
} while(0) } while(0)
void symbol_matrix_init(symbol_matrix_t* matrix) void symbol_matrix_init(symbol_matrix_t* matrix)
...@@ -15,13 +15,13 @@ typedef struct symbol_cblk_s ...@@ -15,13 +15,13 @@ typedef struct symbol_cblk_s
typedef struct symbol_blok_s typedef struct symbol_blok_s
int32_t m_frownum; // First row index int32_t m_frownum; // First row index
int32_t m_lrownum; // Last row index (inclusive) int32_t m_lrownum; // Last row index (inclusive)
int32_t m_lcblknm; // Local column blok int32_t m_lcblknm; // Local column blok
int32_t m_fcblknm; // Facing column blok int32_t m_fcblknm; // Facing column blok
uint32_t m_localization; // Localization uint32_t m_localization; // Localization
int32_t m_flags; int32_t m_flags;
float m_color; float m_color;
} symbol_blok_t; } symbol_blok_t;
