Commit b8bdfff3 authored by Augustin Degomme's avatar Augustin Degomme
Features :
- add a second thread to separate OTF file operations and trace operations : not as much parallelism as in Paje as file operations are more efficient for OTF (as for Paje parsing, flag MT_PARSING)
- multithreaded loading of serialized files : moves loading from the main thread to multiple threads, as for serialization.
- beginning of the work with MPI : work can now be distributed and several intervals loaded from several machines and displayed there.
How to use: the flag USE_MPI must be set, links  -lboost_mpi -lmpi -lmpi_cxx must be added in src.pro
mpicc and mpic++ have to be used instead of gcc and g++. This can be set manually in src/makefile, but will be reseted by the global makefile. Another solution is to add
unix{
QMAKESPEC = mpicc
QMAKE_CXX = mpic++
to the src.pro file.
To launch on a single machine :
mpirun -np nprocess vite path/to/file.vite2/configure
on several machines with separated screens and a machinefile to list them :
- allow ssh authentification without password (by key)
- allow display on each distant machine with "xhost +"
- have a split folder in a folder accessible with the same path for each machine (nfs or local)
- have vite in the path for each machine
- use mpirun -np nprocess -hostfile machinefile -mca orte_rsh_agent "ssh -X" -xDISPLAY=:0.0 vite -tInterval path/to/file.vite
This will split the given interval in nprocess parts and send them for display to the various nodes described, displaying on their local display
parent 7be547a8
...@@ -283,8 +283,8 @@ if [ $with_otf -ge 1 ]; then ...@@ -283,8 +283,8 @@ if [ $with_otf -ge 1 ]; then
exit; exit;
else else
defines="$defines WITH_OTF" defines="$defines WITH_OTF"
sources="$sources parser/ParserOTF.cpp parser/ParserEventOTF.cpp parser/ParserDefinitionOTF.cpp" sources="$sources parser/ParserOTF.cpp parser/ParserEventOTF.cpp parser/OTFTraceBuilderThread.cpp parser/ParserDefinitionOTF.cpp parser/mt_ParserOTF.cpp parser/mt_ParserEventOTF.cpp"
headers="$headers parser/ParserOTF.hpp parser/ParserEventOTF.hpp parser/ParserDefinitionOTF.hpp" headers="$headers parser/ParserOTF.hpp parser/ParserEventOTF.hpp parser/OTFTraceBuilderThread.hpp parser/ParserDefinitionOTF.hpp parser/mt_ParserOTF.hpp parser/mt_ParserEventOTF.hpp"
includepath="$includepath $otfincdir" includepath="$includepath $otfincdir"
libs="$libs -L$otflibdir $otflibdir/libotf.a" libs="$libs -L$otflibdir $otflibdir/libotf.a"
fi fi
...@@ -282,6 +282,8 @@ IF(VITE_ENABLE_OTF) ...@@ -282,6 +282,8 @@ IF(VITE_ENABLE_OTF)
parser/ParserDefinitionOTF.hpp parser/ParserDefinitionOTF.hpp
parser/ParserEventOTF.hpp parser/ParserEventOTF.hpp
parser/ParserOTF.hpp parser/ParserOTF.hpp
SET(VITE_SRCS SET(VITE_SRCS
...@@ -289,6 +291,8 @@ IF(VITE_ENABLE_OTF) ...@@ -289,6 +291,8 @@ IF(VITE_ENABLE_OTF)
parser/ParserDefinitionOTF.cpp parser/ParserDefinitionOTF.cpp
parser/ParserEventOTF.cpp parser/ParserEventOTF.cpp
parser/ParserOTF.cpp parser/ParserOTF.cpp
INCLUDE_DIRECTORIES(${OTF_INCLUDE_DIR}) INCLUDE_DIRECTORIES(${OTF_INCLUDE_DIR})
...@@ -86,6 +86,7 @@ bool Info::Splitter::load_splitted = false; ...@@ -86,6 +86,7 @@ bool Info::Splitter::load_splitted = false;
bool Info::Splitter::preview = false; bool Info::Splitter::preview = false;
std::string Info::Splitter::path ; std::string Info::Splitter::path ;
std::string Info::Splitter::filename ; std::string Info::Splitter::filename ;
std::string Info::Splitter::xml_filename ;
Element_pos Info::Splitter::_x_min = 0.0; Element_pos Info::Splitter::_x_min = 0.0;
Element_pos Info::Splitter::_x_max = 0.0; Element_pos Info::Splitter::_x_max = 0.0;
...@@ -305,6 +305,10 @@ public: ...@@ -305,6 +305,10 @@ public:
static std::string filename; static std::string filename;
* \brief filename of the node selection file, used to select nodes to display in PArserSplitted
static std::string xml_filename;
* \brief min time we want to load * \brief min time we want to load
static Element_pos _x_min; static Element_pos _x_min;
...@@ -131,6 +131,11 @@ ...@@ -131,6 +131,11 @@
#endif #endif
#ifdef USE_MPI
#include <boost/mpi/environment.hpp>
#include <boost/mpi/communicator.hpp>
#endif
using namespace std; using namespace std;
#define message *Message::get_instance() << "(" << __FILE__ << " l." << __LINE__ << "): " #define message *Message::get_instance() << "(" << __FILE__ << " l." << __LINE__ << "): "
...@@ -171,6 +176,10 @@ Core::Core(int &argc, char ** argv){ ...@@ -171,6 +176,10 @@ Core::Core(int &argc, char ** argv){
_state = get_state(argc, argv); _state = get_state(argc, argv);
#ifdef USE_MPI
boost::mpi::environment env(argc, argv);
#endif
if (_state!= _STATE_EXPORT_FILE) if (_state!= _STATE_EXPORT_FILE)
app = new QApplication(argc, argv);/* create the Qt application */ app = new QApplication(argc, argv);/* create the Qt application */
else else
...@@ -298,8 +307,10 @@ bool Core::draw_trace(const string & filename, const int format) { ...@@ -298,8 +307,10 @@ bool Core::draw_trace(const string & filename, const int format) {
#if defined(USE_ITC) && defined(BOOST_SERIALIZE) #if defined(USE_ITC) && defined(BOOST_SERIALIZE)
Info::Splitter::path=QFileInfo(_file_opened.c_str()).dir().path().toStdString(); if(Info::Splitter::path.empty())Info::Splitter::path=QFileInfo(_file_opened.c_str()).dir().path().toStdString();
Info::Splitter::filename=QFileInfo(_file_opened.c_str()).baseName().toStdString(); if(Info::Splitter::filename.empty())Info::Splitter::filename=QFileInfo(_file_opened.c_str()).baseName().toStdString();
if(Info::Splitter::xml_filename.empty() && !_xml_config_file.empty())Info::Splitter::xml_filename=_xml_config_file;
if(Info::Splitter::split==true){ if(Info::Splitter::split==true){
std::stringstream str; std::stringstream str;
str<<Info::Splitter::path<<"/"<<Info::Splitter::filename; str<<Info::Splitter::path<<"/"<<Info::Splitter::filename;
...@@ -310,6 +321,46 @@ bool Core::draw_trace(const string & filename, const int format) { ...@@ -310,6 +321,46 @@ bool Core::draw_trace(const string & filename, const int format) {
#endif #endif
if((Info::Splitter::_x_max==0.0)&&(Info::Splitter::_x_min==0.0)){
#ifdef USE_MPI
if (_world.rank() == 0) {
double min = _time_start;
double max = 0;
if(_time_end == 0.) {
max = _trace->get_max_date().get_value();
else {
max =_time_end;
double interval = (max-min)/ _world.size();
for(int i=1;i<_world.size(); i++){
//send the new working interval for each node
// double out_msg[2]={min+i*interval,min+(i+1)*interval};
_world.send(i, 0,min+i*interval );
_world.send(i, 1,min+(i+1)*interval );
//0 displays the first interval
_time_start=min;
_time_end=min+interval;
} else {
double msg[2];
_world.recv(0, 0, msg[0]);
_world.recv(0, 1, msg[1]);
_time_start=msg[0];
_time_end=msg[1];
#endif
Info::Splitter::_x_min = _time_start; Info::Splitter::_x_min = _time_start;
if(_time_end == 0.) { if(_time_end == 0.) {
...@@ -318,6 +369,9 @@ bool Core::draw_trace(const string & filename, const int format) { ...@@ -318,6 +369,9 @@ bool Core::draw_trace(const string & filename, const int format) {
else { else {
Info::Splitter::_x_max =_time_end; Info::Splitter::_x_max =_time_end;
#endif #endif
...@@ -353,16 +407,7 @@ bool Core::draw_trace(const string & filename, const int format) { ...@@ -353,16 +407,7 @@ bool Core::draw_trace(const string & filename, const int format) {
// if(finish_trace_after_parse) { // if(finish_trace_after_parse) {
// unsigned long long before = getCurrentTime(); // unsigned long long before = getCurrentTime();
if(Info::Splitter::load_splitted==true){
if(Info::Splitter::_x_max == 0)Info::Splitter::preview = true; //we are in the preview mode
if(Info::Splitter::preview==true)_trace->loadPreview();
else {
Interval* i= new Interval(Info::Splitter::_x_min,Info::Splitter::_x_max);
_trace->updateTrace(i);
}else{
#endif
...@@ -387,12 +432,12 @@ bool Core::draw_trace(const string & filename, const int format) { ...@@ -387,12 +432,12 @@ bool Core::draw_trace(const string & filename, const int format) {
*Message::get_instance() << QObject::tr("Splitting was asked but neither USE_ITC nor BOOST_SERIALIZE flags were set ").toStdString() << Message::ende; *Message::get_instance() << QObject::tr("Splitting was asked but neither USE_ITC nor BOOST_SERIALIZE flags were set ").toStdString() << Message::ende;
#endif #endif
#if defined(USE_ITC) && defined(BOOST_SERIALIZE) //#if defined(USE_ITC) && defined(BOOST_SERIALIZE)
finished.wait(&mutex); finished.wait(&mutex);
#endif // #endif
parsing_finished=true; parsing_finished=true;
cout << QObject::tr("Loading of the trace : ").toStdString() << loaded << "%" ; cout << QObject::tr("Loading of the trace : ").toStdString() << loaded << "%" ;
...@@ -67,6 +67,10 @@ class QCoreApplication; ...@@ -67,6 +67,10 @@ class QCoreApplication;
class QString; class QString;
#include <interface/Interface_graphic.hpp> #include <interface/Interface_graphic.hpp>
#include <QObject> #include <QObject>
#ifdef USE_MPI
#endif
//#include "render/Render.hpp" //#include "render/Render.hpp"
//#include "interface/Interface.hpp" //#include "interface/Interface.hpp"
...@@ -286,6 +290,11 @@ protected: ...@@ -286,6 +290,11 @@ protected:
#endif #endif
//Render<Render_opengl>* _render_opengl; //Render<Render_opengl>* _render_opengl;
#ifdef USE_MPI
boost::mpi::communicator _world;
#endif
* \brief Contains the SVG render instance. * \brief Contains the SVG render instance.
...@@ -616,9 +616,15 @@ void Interface_graphic::on_export_file_triggered(){ ...@@ -616,9 +616,15 @@ void Interface_graphic::on_export_file_triggered(){
void Interface_graphic::on_reload_triggered() { void Interface_graphic::on_reload_triggered() {
if(_is_rendering_trace) { if(_is_rendering_trace) {
Element_pos zoom[2]={Info::Splitter::_x_min,Info::Splitter::_x_max};
_core->launch_action(Core::_STATE_RELEASE_RENDER_AREA); _core->launch_action(Core::_STATE_RELEASE_RENDER_AREA);
_core->draw_trace(_trace_path, Core::_DRAW_OPENGL); _core->draw_trace(_trace_path, Core::_DRAW_OPENGL);
if(Info::Splitter::_x_max!=0.0)_core->launch_action(Core:: _STATE_ZOOM_IN_AN_INTERVAL, &zoom);
_core->launch_action(Core:: _STATE_RENDER_UPDATE); _core->launch_action(Core:: _STATE_RENDER_UPDATE);
//update the interval selection display //update the interval selection display
if(_ui_interval_selection!=NULL)_ui_interval_selection->update_values(); if(_ui_interval_selection!=NULL)_ui_interval_selection->update_values();
This diff is collapsed.
** This file is part of the ViTE project.
** This software is governed by the CeCILL-A license under French law
** and abiding by the rules of distribution of free software. You can
** use, modify and/or redistribute the software under the terms of the
** CeCILL-A license as circulated by CEA, CNRS and INRIA at the following
** URL: "http://www.cecill.info".
** As a counterpart to the access to the source code and rights to copy,
** modify and redistribute granted by the license, users are provided
** only with a limited warranty and the software's author, the holder of
** the economic rights, and the successive licensors have only limited
** liability.
** In this respect, the user's attention is drawn to the risks associated
** with loading, using, modifying and/or developing or reproducing the
** software by the user in light of its specific status of free software,
** that may mean that it is complicated to manipulate, and that also
** therefore means that it is reserved for developers and experienced
** professionals having in-depth computer knowledge. Users are therefore
** encouraged to load and test the software's suitability as regards
** their requirements in conditions enabling the security of their
** systems and/or data to be ensured and, more generally, to use and
** operate it in the same conditions as regards security.
** The fact that you are presently reading this means that you have had
** knowledge of the CeCILL-A license and that you accept its terms.
** ViTE developers are (for version 0.* to 1.0):
** - COULOMB Kevin
** - FAVERGE Mathieu
** - JAZEIX Johnny
** - LAGRASSE Olivier
** - MARCOUEILLE Jule
** - NOISETTE Pascal
** - REDONDY Arthur
** - VUCHENER Clément
*\file ParserEventOTF.hpp
*\brief This file contains the event parser used by the ParserOTF.
#ifndef OTFTraceBuilderThread_HPP
#define OTFTraceBuilderThread_HPP
#include <sstream>
#include <string>
#include <map>
#include <queue>
#include <list>
#include <otf.h>
#include "common/Errors.hpp"
#include "trace/values/Values.hpp"
#include "trace/EntityValue.hpp"
#include "trace/EntityTypes.hpp"
#include "trace/Entitys.hpp"
#include "trace/Trace.hpp"
#include "parser/ParserDefinitionOTF.hpp"
#include <QWaitCondition>
#include <QSemaphore>
#include <QObject>
#include <QMutex>
#include <QThread>
* \struct Marker
* \brief Contains the definition of a marker
struct Marker {
* \brief Name of the marker
std::string _name;
* \brief stream where is defined this marker
uint32_t _stream;
* \brief type of the marker
uint32_t _type;
typedef struct OTF_Trace_builder_struct{
int _id;
int (*func)(OTF_Trace_builder_struct*);
void *trace;
uint64_t time;
uint32_t process;
uint32_t process2;
uint64_t value;
const char *text;
uint32_t group;
uint32_t type;
uint32_t length;
uint32_t source;
OTF_Trace_builder_struct(){ }
}OTF_Trace_builder_struct;
//class to handle the real work in a second thread
class OTFTraceBuilderThread: public QObject{
Q_OBJECT
private:
QWaitCondition* _cond;
bool _is_finished;
QSemaphore * _freeSlots;
QMutex* _mutex;
static std::map <const String, Container *, String::less_than> _containers;
static std::map<uint32_t, Marker > _marker;
public:
/* static int handler_begin_process(void *trace, uint64_t time, uint32_t process);
static int handler_end_process (void *trace, uint64_t time, uint32_t process);
static int handler_enter (void *trace, uint64_t time, uint32_t function, uint32_t process, uint32_t process2);
static int handler_leave (void *trace, uint64_t time, uint32_t function, uint32_t process, uint32_t process2);
static int handler_counter(void *trace, uint64_t time, uint32_t process, uint32_t process2, uint64_t value);
static int handler_defmarker(void *trace, uint32_t process, uint32_t token, const char *name, uint32_t type);
static int handler_marker(void *trace, uint64_t time, uint32_t process, uint32_t token, const char *text);
static int handler_send_message (void *trace, uint64_t time, uint32_t process, uint32_t receiver, uint32_t group, uint32_t type, uint32_t length, uint32_t source);
static int handler_receive_message (void *trace, uint64_t time, uint32_t process, uint32_t sendProc, uint32_t group, uint32_t type, uint32_t length, uint32_t source);
static int handler_begin_process(OTF_Trace_builder_struct* tb_struct);
static int handler_end_process (OTF_Trace_builder_struct* tb_struct);
static int handler_enter (OTF_Trace_builder_struct* tb_struct);
static int handler_leave (OTF_Trace_builder_struct* tb_struct);
static int handler_counter(OTF_Trace_builder_struct* tb_struct);
static int handler_defmarker(OTF_Trace_builder_struct* tb_struct);
static int handler_marker(OTF_Trace_builder_struct* tb_struct);
static int handler_send_message (OTF_Trace_builder_struct* tb_struct);
static int handler_receive_message (OTF_Trace_builder_struct* tb_struct);
public slots:
void build_trace(int n, OTF_Trace_builder_struct* tb_struct);
void build_finished();
public:
* \fn ParserEventOTF()
* \brief constructor
OTFTraceBuilderThread(QWaitCondition* cond, QSemaphore * freeSlots, QMutex* mutex);
* \fn ~ParserEventOTF()
~OTFTraceBuilderThread();
#endif
...@@ -55,14 +55,21 @@ ...@@ -55,14 +55,21 @@
#include "common/Message.hpp" #include "common/Message.hpp"
#include "parser/Parser.hpp" #include "parser/Parser.hpp"
#include "parser/ParserPaje.hpp"
#ifdef MT_PARSING #ifdef MT_PARSING
#include "parser/mt_ParserPaje.hpp" #include "parser/mt_ParserPaje.hpp"
#else
#endif #endif
#include "parser/ParserVite.hpp" #include "parser/ParserVite.hpp"
#ifdef WITH_OTF #ifdef WITH_OTF
#include <otf.h> #include <otf.h>
#include "parser/ParserOTF.hpp" #ifdef MT_PARSING
#include "parser/mt_ParserOTF.hpp"
#else
#endif
#endif //WITH_OTF #endif //WITH_OTF
#ifdef WITH_TAU #ifdef WITH_TAU
...@@ -100,7 +107,11 @@ bool ParserFactory::create(Parser **parser, ...@@ -100,7 +107,11 @@ bool ParserFactory::create(Parser **parser,
else if(ext == ".otf") { else if(ext == ".otf") {
#ifdef MT_PARSING
*parser = new mt_ParserOTF(filename);
#else
*parser = new ParserOTF(filename); *parser = new ParserOTF(filename);
#endif
#else #else
*Message::get_instance() << "OTF parser was not compiled. Use parser Paje by default" << Message::endw; *Message::get_instance() << "OTF parser was not compiled. Use parser Paje by default" << Message::endw;
return false; return false;
...@@ -124,7 +135,11 @@ bool ParserFactory::create(Parser **parser, ...@@ -124,7 +135,11 @@ bool ParserFactory::create(Parser **parser,
if(*parser == NULL) { if(*parser == NULL) {
#ifdef MT_PARSING
*parser = new mt_ParserPaje(filename);
#else
*parser = new ParserPaje(filename); *parser = new ParserPaje(filename);
#endif
return true; return true;
...@@ -11,6 +11,7 @@ ...@@ -11,6 +11,7 @@
#include "common/common.hpp" #include "common/common.hpp"
#include "common/Errors.hpp" #include "common/Errors.hpp"
#include "common/Info.hpp" #include "common/Info.hpp"
...@@ -29,6 +30,7 @@ ...@@ -29,6 +30,7 @@
#include "trace/Serializer_types.hpp" #include "trace/Serializer_types.hpp"
#include "trace/Serializer_structs.hpp" #include "trace/Serializer_structs.hpp"
#include "trace/Serializer_container.hpp" #include "trace/Serializer_container.hpp"
#include "trace/SerializerDispatcher.hpp"
#include "trace/values/Values.hpp" #include "trace/values/Values.hpp"
#include "trace/tree/Interval.hpp" #include "trace/tree/Interval.hpp"
...@@ -40,12 +42,13 @@ ...@@ -40,12 +42,13 @@
#include "parser/ParserSplitted.hpp" #include "parser/ParserSplitted.hpp"
ParserSplitted::ParserSplitted(){} ParserSplitted::ParserSplitted(): _loaded_itc(0), _nb_itc(0){}
ParserSplitted::ParserSplitted(const string &filename): Parser(filename){ ParserSplitted::ParserSplitted(const string &filename): Parser(filename), _loaded_itc(0), _nb_itc(0){
...@@ -63,7 +66,9 @@ Info::Splitter::load_splitted=true; ...@@ -63,7 +66,9 @@ Info::Splitter::load_splitted=true;
//dump containers //dump containers
// char* filename=(char*)malloc(128*sizeof(char)); // char* filename=(char*)malloc(128*sizeof(char));
// sprintf(filename,"%s/%s.vite", Info::Splitter::path, ); // sprintf(filename,"%s/%s.vite", Info::Splitter::path, );
Serializer<Container>::Instance().clear();
Serializer<ContainerType>::Instance().clear();
Serializer<EntityType>::Instance().clear();
std::list<ContainerType*> conts_types; std::list<ContainerType*> conts_types;
std::list<Container*> conts; std::list<Container*> conts;
...@@ -88,9 +93,20 @@ Info::Splitter::load_splitted=true; ...@@ -88,9 +93,20 @@ Info::Splitter::load_splitted=true;
//ia >> test; //ia >> test;
// restore the schedule from the archive // restore the schedule from the archive
ia >> conts; ia >> conts;
// (trace.get_root_containers())->insert((trace.get_root_containers())->begin(), conts.begin(),conts.end() );
trace.set_root_containers(conts); trace.set_root_containers(conts);
