GitLab
Support
Community forum
Keyboard shortcuts
vite
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Analytics
Analytics
Value Stream
solverstack
vite
b0e35db3
b0e35db3
Mathieu Faverge
A little more cleanup
5e4b2574
88 additions
87 deletions
+88
-87
src/parser/OTF2Parser/ParserDefinitionOTF2.cpp
+88
-87
b0e35db3
** This file is part of the ViTE project.
** This software is governed by the CeCILL-A license under French law
** and abiding by the rules of distribution of free software. You can
** use, modify and/or redistribute the software under the terms of the
** CeCILL-A license as circulated by CEA, CNRS and INRIA at the following
** URL: "http://www.cecill.info".
** As a counterpart to the access to the source code and rights to copy,
** modify and redistribute granted by the license, users are provided
** only with a limited warranty and the software's author, the holder of
** the economic rights, and the successive licensors have only limited
** liability.
** liability.
** In this respect, the user's attention is drawn to the risks associated
** with loading, using, modifying and/or developing or reproducing the
** software by the user in light of its specific status of free software,
** that may mean that it is complicated to manipulate, and that also
** therefore means that it is reserved for developers and experienced
** professionals having in-depth computer knowledge. Users are therefore
** encouraged to load and test the software's suitability as regards
** their requirements in conditions enabling the security of their
** systems and/or data to be ensured and, more generally, to use and
** operate it in the same conditions as regards security.
** The fact that you are presently reading this means that you have had
** knowledge of the CeCILL-A license and that you accept its terms.
** ViTE developers are (for version 0.* to 1.0):
** - COULOMB Kevin
** - COULOMB Kevin
** - FAVERGE Mathieu
** - JAZEIX Johnny
** - JAZEIX Johnny
** - LAGRASSE Olivier
** - MARCOUEILLE Jule
** - NOISETTE Pascal
** - REDONDY Arthur
** - REDONDY Arthur
** - VUCHENER Clément
* @file ParserDefinitionOTF2.cpp
* @author François Trahay
* @author Lagrasse Olivier
* @author Johnny Jazeix
* @author Mathieu Faverge
@@ -165,8 +165,8 @@ double ParserDefinitionOTF2::get_timestamp(OTF2_TimeStamp ts) {
OTF2_CallbackCode
handler_DefString
void
userData
OTF2_CallbackCode
handler_DefString
void
userData
OTF2_StringRef
id
OTF2_StringRef
id
const
char
value
const
char
value
_strings
id
value
_strings
id
value
return
OTF2_CALLBACK_SUCCESS
return
@@ -201,10 +201,10 @@ OTF2_CallbackCode ParserDefinitionOTF2::handler_DefSystemTreeNode(void
OTF2_CallbackCode
handler_DefLocationGroup
void
userdata
OTF2_CallbackCode
void
userdata
OTF2_LocationGroupRef
location_group_identifier
OTF2_StringRef
name
OTF2_StringRef
name
OTF2_LocationGroupType
type
type
OTF2_SystemTreeNodeRef
system_tree_parent
system_tree_parent
OTF2_LocationGroup
temp
new
OTF2_LocationGroup
OTF2_LocationGroup
temp
new
OTF2_LocationGroup
temp
_group_id
temp
_group_id
temp
_name_id
name
temp
_name_id
name
@@ -230,11 +230,11 @@ OTF2_CallbackCode ParserDefinitionOTF2::handler_DefLocationGroup(void */*userdat
OTF2_CallbackCode
handler_DefLocation
void
userData
OTF2_CallbackCode
handler_DefLocation
void
userData
OTF2_LocationRef
locationIdentifier
OTF2_LocationRef
locationIdentifier
OTF2_StringRef
name_id
OTF2_StringRef
name_id
OTF2_LocationType
location_type
OTF2_LocationType
location_type
uint64_t
numberOfEvents
uint64_t
numberOfEvents
locationGroup
locationGroup
OTF2_Reader
reader
OTF2_Reader
userData
OTF2_Reader
reader
OTF2_Reader
userData
OTF2_EvtReader
evt_reader
OTF2_Reader_GetEvtReader
reader
locationIdentifier
OTF2_EvtReader
evt_reader
reader
locationIdentifier
OTF2_DefReader
def_reader
OTF2_Reader_GetDefReader
reader
locationIdentifier
OTF2_DefReader
def_reader
reader
locationIdentifier
@@ -252,10 +252,10 @@ OTF2_CallbackCode ParserDefinitionOTF2::handler_DefLocation(void *userData,
if
location_group
NULL
if
location_group
NULL
location_group
_location
locationIdentifier
temp
location_group
_location
locationIdentifier
temp
_location
locationIdentifier
temp
_location
locationIdentifier
temp
#if DEBUG
#if DEBUG
cout
"DefLocation(id="
locationIdentifier
", name="
temp
_id_string
", parent="
cout
"DefLocation(id="
locationIdentifier
", name="
temp
_id_string
", parent="
if
location_group
if
location_group
cout
location_group
_id_string
cout
location_group
_id_string
else
else
@@ -266,16 +266,16 @@ OTF2_CallbackCode ParserDefinitionOTF2::handler_DefLocation(void *userData,
OTF2_CallbackCode
handler_DefState
void
userData
OTF2_CallbackCode
handler_DefState
void
userData
OTF2_RegionRef
self
OTF2_RegionRef
self
OTF2_StringRef
name
OTF2_StringRef
name
OTF2_StringRef
canonicalName
OTF2_StringRef
canonicalName
OTF2_StringRef
description
OTF2_StringRef
description
OTF2_RegionRole
regionRole
OTF2_RegionRole
regionRole
OTF2_Paradigm
paradigm
OTF2_Paradigm
paradigm
OTF2_RegionFlag
regionFlags
OTF2_RegionFlag
regionFlags
OTF2_StringRef
sourceFile
OTF2_StringRef
sourceFile
uint32_t
beginLineNumber
uint32_t
beginLineNumber
uint32_t
endLineNumber
uint32_t
endLineNumber
OTF2_Function
temp
name
canonicalName
description
regionRole
paradigm
regionFlags
sourceFile
beginLineNumber
endLineNumber
OTF2_Function
temp
name
canonicalName
description
regionRole
paradigm
regionFlags
sourceFile
beginLineNumber
endLineNumber
_functions
self
temp
_functions
self
temp
@@ -327,17 +327,18 @@ OTF2_CallbackCode ParserDefinitionOTF2::handler_DefMetricMember( void*
OTF2_Type
valueType
OTF2_Type
valueType
OTF2_Base
base
OTF2_Base
base
int64_t
exponent
int64_t
exponent
OTF2_StringRef
unit
OTF2_StringRef
unit
OTF2_MetricMember
temp
OTF2_MetricMember
temp
temp
_id
self
temp
_id
self
temp
_name
name
temp
_name
name
temp
_description
description
temp
_description
description
temp
_metricType
metricType
temp
_metricType
metricType
temp
_metricMode
metricMode
temp
_metricMode
metricMode
temp
_valueType
valueType
temp
_valueType
valueType
temp
_base
base
temp
_base
base
temp
_exponent
exponent
temp
_exponent
exponent
temp
_unit
unit
temp
_unit
unit
_metric_member
self
temp
_metric_member
self
temp
@@ -349,12 +350,12 @@ OTF2_CallbackCode ParserDefinitionOTF2::handler_DefMetricClass( void*
uint8_t
numberOfMetrics
uint8_t
numberOfMetrics
const
OTF2_MetricMemberRef
metricMembers
const
metricMembers
OTF2_MetricOccurrence
metricOccurrence
metricOccurrence
OTF2_RecorderKind
recorderKind
OTF2_RecorderKind
recorderKind
OTF2_MetricClass
temp
OTF2_MetricClass
temp
temp
_id
self
temp
_id
self
temp
_metricOccurrence
metricOccurrence
temp
_metricOccurrence
metricOccurrence
temp
_recorderKind
recorderKind
temp
_recorderKind
recorderKind
for
int
i
i
numberOfMetrics
i
for
int
i
i
numberOfMetrics
i
temp
_metricMembers
push_back
metricMembers
i
temp
_metricMembers
push_back
metricMembers
i
@@ -369,16 +370,16 @@ OTF2_CallbackCode ParserDefinitionOTF2::handler_DefMetricInstance( void*
OTF2_MetricRef
metricClass
OTF2_MetricRef
metricClass
OTF2_LocationRef
recorder
OTF2_LocationRef
recorder
OTF2_MetricScope
metricScope
OTF2_MetricScope
metricScope
uint64_t
scope
uint64_t
scope
cout
__FUNCTION__
" not implemented
\n
cout
__FUNCTION__
" not implemented
\n
return
return
OTF2_CallbackCode
handler_DefMetricClassRecorder
void
userData
OTF2_CallbackCode
void
userData
OTF2_MetricRef
metric
OTF2_MetricRef
metric
OTF2_LocationRef
recorder
OTF2_LocationRef
recorder
cout
__FUNCTION__
" not implemented
\n
cout
__FUNCTION__
" not implemented
\n
return
return
@@ -583,10 +584,10 @@ void ParserDefinitionOTF2::create_metric_member(Trace *t, OTF2_MetricMember m) {
std
map
OTF2_LocationRef
OTF2_Location
const_iterator
it_l
std
map
OTF2_LocationRef
OTF2_Location
const_iterator
it_l
it_l
_location
begin
it_l
_location
begin
if
it_l
_location
if
it_l
_location
OTF2_Location
n
it_l
second
OTF2_Location
n
it_l
second
if
n
if
n
temp_container_type
t
search_container_type
String
get_string_by_id
n
_name_id
temp_container_type
t
String
get_string_by_id
n
_name_id
if
temp_container_type
if
temp_container_type
temp_container_type
t
String
"0"
temp_container_type
t
String
"0"
