Mise à jour terminée. Pour connaître les apports de la version 13.8.4 par rapport à notre ancienne version vous pouvez lire les "Release Notes" suivantes :
https://about.gitlab.com/releases/2021/02/11/security-release-gitlab-13-8-4-released/
https://about.gitlab.com/releases/2021/02/05/gitlab-13-8-3-released/
Commit a85bee46 authored by Mathieu Faverge's avatar Mathieu Faverge
Move plugins in root directory
parent 4705048c
...@@ -59,7 +59,7 @@ taudir="/usr" ...@@ -59,7 +59,7 @@ taudir="/usr"
tauincdir="$taudir/include" tauincdir="$taudir/include"
taulibdir="$taudir/lib" taulibdir="$taudir/lib"
qtcolordir="./externals/qtcolorpicker/" qtcolordir="../externals/qtcolorpicker/"
qtcolorincdir="$qtcolordir/src" qtcolorincdir="$qtcolordir/src"
qtcolorsrcdir="$qtcolordir/src" qtcolorsrcdir="$qtcolordir/src"
...@@ -340,7 +340,6 @@ EOF ...@@ -340,7 +340,6 @@ EOF
distclean: cleanall distclean: cleanall
EOF EOF
fi
cat >>"$makefile" <<EOF cat >>"$makefile" <<EOF
\$(RM) Makefile \$(RM) Makefile
\$(RM) src/Makefile \$(RM) src/Makefile
../plugins
\ No newline at end of file
#include <QWidget>
#include <QSlider>
#include <QPainter>
#include <QTextEdit>
#include <QHBoxLayout>
#include <QTreeWidgetItem>
#include <QStackedWidget>
#include <set>
#include <stack>
#include <fstream>
#include "plugin/Plugin.hpp"
#include "trace/EntityTypes.hpp"
#include "trace/Entitys.hpp"
#include "trace/Container.hpp"
#include "trace/EntityValue.hpp"
#include "trace/StateChange.hpp"
#include "trace/tree/BinaryTree.hpp"
#include "trace/tree/Node.hpp"
#include "common/Message.hpp"
#include <QApplication>
#include <QtGui>
class Distribution : public Plugin {
class LogEntry {
public:
Date start;
double duration;
LogEntry(Date _start, double _duration)
this->start = _start;
this->duration = _duration;
/* XXX could not this be nicer ? */
struct compar_date_sort {
bool operator()(LogEntry *e1, LogEntry *e2)
return (e1->start < e2->start);
} compar_date_sort_op;
struct compar_duration_sort {
return (e1->duration < e2->duration);
} compar_duration_sort_op;
void sort_by_duration(std::vector<LogEntry *> &le_list)
std::sort(le_list.begin(), le_list.end(), compar_duration_sort_op);
void sort_by_date(std::vector<LogEntry *> &le_list)
std::sort(le_list.begin(), le_list.end(), compar_date_sort_op);
private:
QTextEdit *_text_info;
QTreeWidget *_nodes_selected;
QTreeWidget *_state_names_selected;
QGraphicsScene *scene;
QGraphicsView *view;
QSlider *min_slider;
QSlider *max_slider;
/* all names found in the trace */
std::set<std::string> state_types_names;
void select_container_rec(QTreeWidgetItem * root_node, Container *current_container) const {
const std::list<Container *> *children = current_container->get_children();
// Add the root container names
QList<QTreeWidgetItem *> items;
QFlags<Qt::ItemFlag> flg = Qt::ItemIsUserCheckable | Qt::ItemIsSelectable | Qt::ItemIsEnabled | Qt::ItemIsTristate;
for (std::list<Container *>::const_iterator it = children->begin();
it != children->end();
it ++) {
// We create the node and we do the recursivity
std::string name = (*it)->get_name().to_string();
QStringList temp(QString::fromStdString(name));
QTreeWidgetItem *current_node = new QTreeWidgetItem((QTreeWidgetItem *)root_node, temp);
current_node->setFlags(flg);
current_node->setCheckState(0,Qt::Unchecked);
items.append(current_node);
select_container_rec(current_node, (*it));
void select_container() const {
const std::list<Container *> *root_containers = _trace->get_root_containers();
QFlags<Qt::ItemFlag> flg=Qt::ItemIsUserCheckable | Qt::ItemIsEnabled | Qt::ItemIsSelectable | Qt::ItemIsTristate;
for (std::list<Container *>::const_iterator it = root_containers->begin(); it != root_containers->end(); it++) {
QTreeWidgetItem *current_node = new QTreeWidgetItem((QTreeWidgetItem *)0, temp);
// Recursivity to add the children names
select_container_rec(current_node, *it);
(*(items.begin()))->setExpanded(true);
_nodes_selected->insertTopLevelItems(0, items);
void browse_statechange_tree(Node<StateChange> *node, QString &text, std::string &container_name, std::ofstream &stream,
std::set<std::string> &selected_state_types_names, std::vector<LogEntry *> &found_states) const {
if (!node)
return;
/* handle the node */
const State *st = node->get_element()->get_left_state();
if (st)
const std::string name = st->get_value()->get_name().to_string();
/* does the name appear in the set of selected names ? */
std::set<std::string>::const_iterator it = selected_state_types_names.find(name);
if (it != selected_state_types_names.end())
double length = st->get_duration();
Date start = st->get_start_time();
stream << container_name;
stream << "\t";
stream << name;
stream << "\t";
stream << start.to_string();
stream << "\t";
stream << length;
stream << "\n";
LogEntry *le = new LogEntry(start, length);
found_states.push_back(le);
/* handle its left child */
browse_statechange_tree(node->get_left_child(), text, container_name, stream, selected_state_types_names, found_states);
/* handle its right child */
browse_statechange_tree(node->get_right_child(), text, container_name, stream, selected_state_types_names, found_states);
std::string get_container_complete_name(const Container * container) const {
std::string str;
if (container->get_parent())
str = get_container_complete_name(container->get_parent());
str.append("_");
else
str = "";
std::string name = container->get_name().to_string();
str.append(name);
return str;
int handle_container(Container * &container,
QString &text,
std::string name = get_container_complete_name(container);
text += QString::fromStdString(name);
Node<StateChange> *root_node = container->get_states()->get_root();
browse_statechange_tree(root_node, text, name, stream, selected_state_types_names, found_states);
int localcnt = container->get_state_number();
text += QString(" count: %1<br/>").arg(localcnt);
return localcnt;
void get_statechange_distribution(QString &text) const {
/* count */
int count = 0;
text += "<h2>States:</h2>";
std::ofstream SaveFile("distribution.txt");
/* the names that were selected by the application */
std::set<std::string> selected_state_types_names;
find_selected_state_types_names(selected_state_types_names);
/* A vector to store the entries that matched user contraints */
std::vector<LogEntry *> found_states;
/* Only handle the containers that the user have selected */
QTreeWidgetItemIterator it(_nodes_selected);
while (*it) {
(*it)->setFlags ((*it)->flags () | Qt::ItemIsUserCheckable);
if ((*it)->checkState(0))
Container *cont = _trace->search_container((*it)->text(0).toStdString());
std::string name = get_container_complete_name(cont);
//printf("Container %s was selected\n", name.c_str());
count += handle_container(cont, text, SaveFile, selected_state_types_names, found_states);
++it;
/* XXX i need C++ courses ;) */
LogEntry dummy(0, 0);
dummy.sort_by_duration(found_states);
/* TODO really take the min and the max ... */
double min_quantile = 0.01 * (double)min_slider->value();
double max_quantile = 0.01 * (double)max_slider->value();
printf("quantiles : min %lf max %lf\n", min_quantile, max_quantile);
compute_histogram_duration(found_states, min_quantile, max_quantile, 25);
text += QString("Total count: %1").arg(count);
SaveFile.close();
/* Fill name_set with the names of the state contained in sub-tree node */
void get_state_names_list(std::set<std::string> &name_set, Node<StateChange> *node)
if (!node)
return;
const State *left_st = node->get_element()->get_left_state();
if (left_st)
const std::string name = left_st->get_value()->get_name().to_string();
name_set.insert(name);
const State *right_st = node->get_element()->get_right_state();
if (right_st)
const std::string name = right_st->get_value()->get_name().to_string();
get_state_names_list(name_set, node->get_left_child());
get_state_names_list(name_set, node->get_right_child());
void select_state_types(void)
/* For all containers, get the list of state names */
std::list <Container *> container_list;
_trace->get_all_containers(container_list);
for(std::list<Container *>::const_iterator it = container_list.begin();
it != container_list.end(); ++ it)
BinaryTree<StateChange> *states;
states = (*it)->get_states();
if(states && states->get_root()) {
get_state_names_list(state_types_names, states->get_root());
/* Add a tick box per name of event */
for(std::set<std::string>::const_iterator it = state_types_names.begin();
it != state_types_names.end(); it++)
QStringList temp(QString::fromStdString(*it));
_state_names_selected->insertTopLevelItems(0, items);
void find_selected_state_types_names(std::set<std::string> &selected_state_types_names) const {
/* Go through the tick box list to find which are the names that have been selected */
QTreeWidgetItemIterator it(_state_names_selected);
while (*it) {
std::string name = (*it)->text(0).toStdString();
selected_state_types_names.insert(name);
//printf("Name %s was selected\n", name.c_str());
++it;
double compute_quantile_duration(std::vector<LogEntry *>le_list, float alpha) const {
float sizef = (float)(le_list.size() - 1);
if (alpha > 1.0)
alpha = 1.0;
if (alpha < 0.0)
alpha = 0.0;
float indf = alpha*sizef;
unsigned ind = floor(indf);
LogEntry *le = le_list[ind];
return le->duration;
void compute_histogram_duration(std::vector<LogEntry *>le_list,
float min_quantile, float max_quantile, unsigned nbreaks) const
if (le_list.size() == 0)
return;
/* Select values in [min_val ; max_val[ */
double min_val = compute_quantile_duration(le_list, min_quantile);
double max_val = compute_quantile_duration(le_list, max_quantile);
if (max_val - min_val == 0.0)
printf("Cannot display histogram: not enough different values\n");
return;
unsigned i;
unsigned cnt[nbreaks];
unsigned total_cnt = 0;
unsigned max_cnt = 0;
/* start from a blank histogram */
for (i = 0; i < nbreaks; i++)
cnt[i] = 0;
for (i = 0; i < le_list.size(); i++)
double val = le_list[i]->duration;
if ((val >= min_val) && (val < max_val))
/* in which bin does the value go ? */
unsigned bin = floor((nbreaks*(val - min_val))/(max_val - min_val));
cnt[bin]++;
total_cnt++;
if (total_cnt == 0)
return;
if (max_cnt < cnt[i])
max_cnt = cnt[i];
double start = (i * (max_val - min_val))/nbreaks + min_val;
double end = ((i+1) * (max_val - min_val))/nbreaks + min_val;
printf("BIN[%d] = %d / %d - [ %lf, %lf [\n", i, cnt[i], total_cnt, start, end);
/* Start from a blank canva */
scene->clear();
/* Display the histogram now */
int height = 200;
int width = 100;
int offsety = 100;
scene->addItem(new QGraphicsLineItem(0, 0+offsety, 0, -height+offsety, NULL, scene));
scene->addItem(new QGraphicsLineItem(0, 0+offsety, width, 0+offsety, NULL, scene));
int xstart = floor(((double)width * i)/nbreaks);
int xend = floor(((double)width * (i+1))/nbreaks);
int yend = floor(((double)height*cnt[i])/max_cnt);
QGraphicsRectItem *rect = new QGraphicsRectItem(xstart, -yend+offsety, xend - xstart, yend, NULL);
QColor col(0, 0, 255, 127);
rect->setBrush(QColor(255, 0, 0, 255));
rect->brush();
scene->addItem(rect);
public:
Distribution() {
QHBoxLayout *horizontalLayout = new QHBoxLayout(this);
_text_info = new QTextEdit();
horizontalLayout->addWidget(_text_info);
//QStackedWidget *stackedWidget = new QStackedWidget;
scene = new QGraphicsScene(0, 0, 100, 100, this);
view = new QGraphicsView(scene);
horizontalLayout->addWidget(view);
_nodes_selected = new QTreeWidget();
_state_names_selected = new QTreeWidget();
horizontalLayout->addWidget(_nodes_selected);
horizontalLayout->addWidget(_state_names_selected);
min_slider = new QSlider();
min_slider->setFocusPolicy(Qt::StrongFocus);
min_slider->setTickPosition(QSlider::TicksBothSides);
min_slider->setTickInterval(10);
min_slider->setRange(0, 100);
min_slider->setSingleStep(1);
min_slider->setObjectName("totp");
min_slider->setValue(5);
horizontalLayout->addWidget(min_slider);
max_slider = new QSlider();
max_slider->setFocusPolicy(Qt::StrongFocus);
max_slider->setTickPosition(QSlider::TicksBothSides);
max_slider->setTickInterval(10);
max_slider->setRange(0, 100);
max_slider->setSingleStep(1);
max_slider->setValue(95);
horizontalLayout->addWidget(max_slider);
void init() {
//_text_info->clear();
select_container();
select_state_types();
void clear() {
void set_arguments(std::map<std::string /*argname*/, QVariant */*argValue*/>) {}
std::string get_name() {
return "Distribution";
public slots:
void execute() {
QString text ("<center><h1> Distribution </h1></center>");
get_statechange_distribution(text);
_text_info->setHtml(text);
extern "C" {
Plugin *create() { return new Distribution(); }
TEMPLATE = lib
CONFIG += plugin
TARGET = Distribution
DEPENDPATH += ..
INCLUDEPATH += ..
DESTDIR = ~/.vite
OBJECTS_DIR = ../../bin
SOURCES = Distribution.cpp \
trace/Trace.cpp \
trace/values/Date.cpp \
trace/values/Name.cpp \
trace/values/Double.cpp \
trace/values/String.cpp \
trace/ContainerType.cpp \
trace/EntityType.cpp \
trace/VariableType.cpp \
trace/EventType.cpp \
trace/LinkType.cpp \
trace/StateType.cpp \
trace/Container.cpp \
trace/Entity.cpp \
trace/EntityValue.cpp \
trace/Variable.cpp \
trace/State.cpp \
trace/StateChange.cpp \
trace/Link.cpp \
trace/Event.cpp \
statistics/Statistic.cpp \
common/Tools.cpp \
common/Info.cpp \
common/Message.cpp
#include <set>
#include <stack>
#include "plugins_dir/trace_infos.hpp"
using namespace std;
Trace_infos::Trace_infos() {
Trace_infos::~Trace_infos() {
void Trace_infos::set_container_infos(QString &text) const {
/* count */
text += "<h2>Containers:</h2>";
text += QString("count: %1").arg(container_list.size());
void Trace_infos::set_states_infos(QString &text) const {
set<string> state_list;
for(list<Container *>::const_iterator it = container_list.begin();
++ it) {
get_states_name_rec(states->get_root(), state_list);
text += QString("count: %1").arg(state_list.size());
void Trace_infos::get_states_name_rec(Node<StateChange> *parent, set<string> &state_list) const {
if(!parent)
return;
const StateChange *top_state = parent->get_element();
const State *left_state = top_state->get_left_state();
const State *right_state = top_state->get_right_state();
if(left_state && left_state->get_value()) {
state_list.insert(left_state->get_value()->get_name().to_string());
//cout << left_state->get_value()->get_name().to_string() << endl;
get_states_name_rec(parent->get_left_child(), state_list);
