Commit 7bda0d0d authored by Olivier Lagrasse's avatar Olivier Lagrasse
- Fix seg fault bug on startup for Linux x64.
- Moreover, restore possibility to open many traces at the same time.
parent 9aba6c07
...@@ -115,25 +115,28 @@ Core::Core(int argc, char ** argv){ ...@@ -115,25 +115,28 @@ Core::Core(int argc, char ** argv){
bool useGUI;/* if window interface can be displayed */ bool useGUI;/* if window interface can be displayed */
QString current_path; // QString current_path;
app = new QApplication(argc, argv);/* create the Qt application */ app = new QApplication(argc, argv);/* create the Qt application */
_run_env[0] = QDir::currentPath();
_run_env[1] = argv[0];
Message::set_interface(this);/* define which interface will receive messages */
useGUI = true;
// glutInit(&argc, argv);/* use for OpenGL text */ // glutInit(&argc, argv);/* use for OpenGL text */
/* Qt uses the default system encoding for QString (used when opening a file) */ /* Qt uses the default system encoding for QString (used when opening a file) */
QTextCodec::setCodecForCStrings(QTextCodec::codecForLocale()); QTextCodec::setCodecForCStrings(QTextCodec::codecForLocale());
useGUI = true;
if (!useGUI){
// cerr << "Core debug: " << QDir::currentPath().toStdString().c_str() << " " << argv[0] << endl;
if (!useGUI){
cerr << QObject::tr("Error: Graphical window cannot be displayed.").toStdString() << endl; cerr << QObject::tr("Error: Graphical window cannot be displayed.").toStdString() << endl;
exit(EXIT_FAILURE); exit(EXIT_FAILURE);
...@@ -146,6 +149,12 @@ Core::Core(int argc, char ** argv){ ...@@ -146,6 +149,12 @@ Core::Core(int argc, char ** argv){
_time_start = 0; _time_start = 0;
_time_end = 0; _time_end = 0;
_run_env[0] = new QString(QDir::currentPath().toStdString().c_str());
_run_env[1] = new QString(argv[0]);
_state = get_state(argc, argv); _state = get_state(argc, argv);
...@@ -168,6 +177,12 @@ Core::~Core(){ ...@@ -168,6 +177,12 @@ Core::~Core(){
if(_trace != NULL){ if(_trace != NULL){
delete _trace; delete _trace;
if (_run_env[0]!=NULL)
delete _run_env[0];
if (_run_env[1]!=NULL)
delete _run_env[1];
/* Qt desallocates _main_window and _render_opengl automatically */ /* Qt desallocates _main_window and _render_opengl automatically */
//free(_run_env[0]); //free(_run_env[0]);
...@@ -804,8 +819,8 @@ void Core::set_path_to_export(const string& path){ ...@@ -804,8 +819,8 @@ void Core::set_path_to_export(const string& path){
_path_to_export = path; _path_to_export = path;
const QString* Core::get_runenv() const{ const QString** Core::get_runenv() const{
return _run_env; return (const QString**)_run_env;
void Core::update_progress_bar(const int loaded){ void Core::update_progress_bar(const int loaded){
...@@ -277,7 +277,7 @@ protected: ...@@ -277,7 +277,7 @@ protected:
*\brief This attributes contains the launching current directory (_run_env[0]) and the first argument of the running command (_run_env[1]). *\brief This attributes contains the launching current directory (_run_env[0]) and the first argument of the running command (_run_env[1]).
QString _run_env[2]; QString* _run_env[2];
*\brief If a file must be opened, this attribute contains its path. *\brief If a file must be opened, this attribute contains its path.
...@@ -399,7 +399,7 @@ public: ...@@ -399,7 +399,7 @@ public:
* \brief Get the _run_env matrix. * \brief Get the _run_env matrix.
const QString* get_runenv() const; const QString** get_runenv() const;
...@@ -927,12 +927,14 @@ void Interface_graphic::open_trace(const QString &filename) { ...@@ -927,12 +927,14 @@ void Interface_graphic::open_trace(const QString &filename) {
QStringList arguments = (QStringList() << filename); QStringList arguments = (QStringList() << filename);
QString program; QString program;
const QString* run_env = _core->get_runenv(); const QString** run_env = _core->get_runenv();
QDir::setCurrent(run_env[0]); QDir::setCurrent(*run_env[0]);
QString run_cmd = run_env[1]; QString run_cmd = *run_env[1];
cout << __FILE__ << " " << __LINE__ << " : " << run_env[0]->toStdString() << " " << run_env[1]->toStdString() << endl;
if (run_cmd.startsWith(".")) if (run_cmd.startsWith("."))
program = run_env[0]+(run_cmd.remove(0,1)); program = *run_env[0]+(run_cmd.remove(0,1));
else else
program = run_cmd; program = run_cmd;
...@@ -340,6 +340,9 @@ public: ...@@ -340,6 +340,9 @@ public:
* This function stores all the information of the event to display it each time the render area need to be updated. * This function stores all the information of the event to display it each time the render area need to be updated.
inline void draw_event(Element_pos time, Element_pos height, Element_pos container_height){ inline void draw_event(Element_pos time, Element_pos height, Element_pos container_height){
/* For SVG */
Element_pos radius;/* the circle radius */ Element_pos radius;/* the circle radius */
time = trace_to_render_x(time); time = trace_to_render_x(time);
...@@ -350,6 +353,9 @@ public: ...@@ -350,6 +353,9 @@ public:
drawing_instance->draw_circle(time, height, _z_event, radius); drawing_instance->draw_circle(time, height, _z_event, radius);
drawing_instance->draw_line(time, height, drawing_instance->draw_line(time, height,
time, height+container_height, _z_event); time, height+container_height, _z_event);
/* For OpenGL */
drawing_instance->draw_event(time, height, container_height);
...@@ -76,6 +76,10 @@ static bool _draw_arrow;/* Yes, it is global, but also it is static. In fact, it ...@@ -76,6 +76,10 @@ static bool _draw_arrow;/* Yes, it is global, but also it is static. In fact, it
the Render_opengl class. */ the Render_opengl class. */
static bool _draw_circle;/* Yes, it is global, but also it is static. In fact, it is used to
check the circle drawing state. It is not an attribute of
const int Render_opengl::DRAWING_TIMER_DEFAULT = 10; const int Render_opengl::DRAWING_TIMER_DEFAULT = 10;
...@@ -137,7 +141,7 @@ void Render_opengl::initializeGL() { ...@@ -137,7 +141,7 @@ void Render_opengl::initializeGL() {
glClearStencil(0); glClearStencil(0);
_wait_list = draw_wait(); _wait_list = draw_wait();
void Render_opengl::resizeGL(int width, int height) { void Render_opengl::resizeGL(int width, int height) {
...@@ -162,7 +166,6 @@ void Render_opengl::resizeGL(int width, int height) { ...@@ -162,7 +166,6 @@ void Render_opengl::resizeGL(int width, int height) {
glMatrixMode(GL_MODELVIEW); glMatrixMode(GL_MODELVIEW);
void Render_opengl::paintGL(){ void Render_opengl::paintGL(){
...@@ -770,7 +773,7 @@ void Render_opengl::draw_triangle(Element_pos , Element_pos , ...@@ -770,7 +773,7 @@ void Render_opengl::draw_triangle(Element_pos , Element_pos ,
void Render_opengl::draw_line(Element_pos x1, Element_pos y1, Element_pos x2, Element_pos y2, Element_pos z){ void Render_opengl::draw_line(Element_pos x1, Element_pos y1, Element_pos x2, Element_pos y2, Element_pos z){
if (_draw_ruler || _draw_arrow) return;/* do not draw line for ruler or for arrow */ if (_draw_ruler || _draw_arrow || _draw_circle) return;/* do not draw line for ruler or for arrow or for circle */
const Element_pos offset_x = -_default_entity_x_translate; const Element_pos offset_x = -_default_entity_x_translate;
...@@ -787,7 +790,7 @@ void Render_opengl::draw_line(Element_pos x1, Element_pos y1, Element_pos x2, El ...@@ -787,7 +790,7 @@ void Render_opengl::draw_line(Element_pos x1, Element_pos y1, Element_pos x2, El
void Render_opengl::draw_circle(Element_pos x, Element_pos y, Element_pos z, Element_pos r){ void Render_opengl::draw_circle(Element_pos x, Element_pos y, Element_pos z, Element_pos r){
Circle_ buf; /* Circle_ buf;
const Element_pos offset_y = -_ruler_y - _ruler_height; const Element_pos offset_y = -_ruler_y - _ruler_height;
...@@ -796,7 +799,7 @@ void Render_opengl::draw_circle(Element_pos x, Element_pos y, Element_pos z, Ele ...@@ -796,7 +799,7 @@ void Render_opengl::draw_circle(Element_pos x, Element_pos y, Element_pos z, Ele
buf.z = z; buf.z = z;
buf.r = r; buf.r = r;
_circles.push_back(buf); _circles.push_back(buf);*/
...@@ -805,6 +808,7 @@ void Render_opengl::start_draw(){ ...@@ -805,6 +808,7 @@ void Render_opengl::start_draw(){
_draw_ruler = false; _draw_ruler = false;
_draw_container = false; _draw_container = false;
_draw_arrow = false; _draw_arrow = false;
_draw_circle = false;
...@@ -868,7 +872,16 @@ void Render_opengl::end_draw_arrows(){ ...@@ -868,7 +872,16 @@ void Render_opengl::end_draw_arrows(){
void Render_opengl::draw_event(const Element_pos , const Element_pos , const Element_pos ){ void Render_opengl::draw_event(const Element_pos time, const Element_pos height, const Element_pos container_height){
Circle_ buf;
buf.time = time + offset_x;
buf.height = height + offset_y;
buf.container_height = container_height + offset_y;
void Render_opengl::start_draw_counter(){ void Render_opengl::start_draw_counter(){
...@@ -992,22 +1005,32 @@ void Render_opengl::draw_stored_circles(){ ...@@ -992,22 +1005,32 @@ void Render_opengl::draw_stored_circles(){
const int step = 20;/* 20 polygons for the circle */ const int step = 20;/* 20 polygons for the circle */
const float angle = M_PI/2.0f; const float angle = M_PI/2.0f;
const float delta_angle = 2*M_PI/step; const float delta_angle = 2*M_PI/step;
const float radius = 0.3f;
set_color(1, 1, 1); set_color(1, 1, 1);
const unsigned int size = _circles.size(); const unsigned int size = _circles.size();
for (unsigned int i=0 ; i<size ; i++){ for (unsigned int i=0 ; i<size ; i++){
/* Draw the circle */
glBegin(GL_POLYGON); glBegin(GL_POLYGON);
glColor3d(_red, _green, _blue); glColor3d(_red, _green, _blue);
for(int i = 0 ; i < step ; i ++){ for(int i = 0 ; i < step ; i ++){
glVertex3d(_circles[i].x + cos(angle+delta_angle*i)*_circles[i].r , glVertex3d(_circles[i].time + cos(angle+delta_angle*i)*radius ,
_circles[i].y + sin(angle+delta_angle*i)*_circles[i].r , _circles[i].height + sin(angle+delta_angle*i)*radius ,
_circles[i].z); _z_event);
glEnd(); glEnd();
/* Draw the line */
glBegin(GL_LINES);
glVertex2d(_circles[i].time, _circles[i].height);
glVertex2d(_circles[i].time, _circles[i].height+_circles[i].container_height);
glEnd();
...@@ -75,7 +75,7 @@ struct Circle_{ ...@@ -75,7 +75,7 @@ struct Circle_{
* \brief Coordinates and radius. * \brief Coordinates and radius.
Element_pos x, y, z, r; Element_pos time, height, container_height;
...@@ -159,7 +159,7 @@ void Render_stats_opengl::paintGL(){ ...@@ -159,7 +159,7 @@ void Render_stats_opengl::paintGL(){
buf_x = *it_pos + _translated_x; buf_x = *it_pos + _translated_x;
it_pos ++; it_pos ++;
buf_y = *it_pos + _translated_y; buf_y = *it_pos - _translated_y;
buf_txt = *it_txt; buf_txt = *it_txt;
...@@ -220,7 +220,7 @@ inline void Render_stats_opengl::start_draw(){ ...@@ -220,7 +220,7 @@ inline void Render_stats_opengl::start_draw(){
_stats_beginned_drawed = true; _stats_beginned_drawed = true;
_rect_list = glGenLists(1); _rect_list = glGenLists(1);
if(_rect_list == 0) { if(_rect_list == 0) {
fprintf(stderr, "error while initialising _rect_list for stats\n"); std::cerr << "error while initialising _rect_list for stats\n" << std::endl;
glNewList(_rect_list, GL_COMPILE); glNewList(_rect_list, GL_COMPILE);
