Commit 71a8168c authored by Mathieu Faverge's avatar Mathieu Faverge
Add gitlab analysis
parent b0e35db3
#!/bin/sh
if [ $# -gt 0 ]
then
BUILDDIR=$1
fi
BUILDDIR=${BUILDDIR-=build}
echo $PWD
rm -f filelist.txt
git ls-files | grep "\.[ch]pp" > filelist.txt
# Remove all CMakeFiles generated file
sed -i '/CMakeFiles/d' filelist.txt
# Remove all external file
sed -i '/^external/d' filelist.txt
# Remove all .cmake files
sed -i '/.cmake/d' filelist.txt
# Remove all .in files
sed -i '/.in$/d' filelist.txt
# Remove all clang files
sed -i '/^\.clang/d' filelist.txt
# Remove installed files
sed -i '/^install.*/d' filelist.txt
grep '\.cpp$' filelist.txt > filelist-c.txt
image: hpclib/hiepacs
stages:
- build
- sonar
build_vite:
stage: build
artifacts:
expire_in: 42 minutes
untracked: true
script:
- git submodule update --init --recursive
- mkdir build
- cd build
- cmake .. -DCMAKE_INSTALL_PREFIX=${PWD}/../install -DBUILD_SHARED_LIBS=ON -DCMAKE_VERBOSE_MAKEFILE=ON -DCMAKE_C_FLAGS="-O0 -g -fPIC --coverage -Wall -fdiagnostics-show-option -fno-inline" -DCMAKE_EXE_LINKER_FLAGS="--coverage" -DCMAKE_EXPORT_COMPILE_COMMANDS=ON
- make -j 4 | tee ../vite-build.log
- make install | tee -a ../vite-build.log
only:
- branches
- master@solverstack/vite
sonar_vite:
stage: sonar
dependencies:
- build_vite
artifacts:
expire_in: 1 week
paths:
- vite-cppcheck.xml
- vite-rats.xml
- sonar.log
script:
- ./analysis.sh
only:
......@@ -104,6 +104,7 @@ if (USE_QT5)
else(USE_QT5) # Try Qt4
set(CMAKE_AUTOMOC ON)
find_package(Qt4 COMPONENTS QtCore QtGui QtXml REQUIRED)
set(QT_USE_QTUITOOLS ON)
set(QT_USE_QTOPENGL ON)
......@@ -111,6 +112,7 @@ else(USE_QT5) # Try Qt4
endif(USE_QT5)
set( OpenGL_GL_PREFERENCE LEGACY )
find_package(OpenGL)
#find_package(GLU)
## This file should be placed in the root directory of your project.
## Then modify the CMakeLists.txt file in the root directory of your
## project to incorporate the testing dashboard.
## # The following are required to uses Dart and the Cdash dashboard
## ENABLE_TESTING()
## INCLUDE(CTest)
set(CTEST_PROJECT_NAME "ViTE")
set(CTEST_NIGHTLY_START_TIME "00:00:00 GMT")
set(CTEST_DROP_METHOD "http")
set(CTEST_DROP_SITE "cdash.inria.fr")
set(CTEST_DROP_LOCATION "/CDash/submit.php?project=vite")
set(CTEST_DROP_SITE_CDASH TRUE)
# BUILDNAME variable construction
# This variable will be used to set the build name which will appear
# on the ViTE dashboard http://cdash.inria.fr/CDash/
# Start with the short system name, e.g. "Linux", "FreeBSD" or "Windows"
if(NOT BUILDNAME)
set(BUILDNAME "${CMAKE_SYSTEM_NAME}")
# Add i386 or amd64
if(CMAKE_SIZEOF_VOID_P EQUAL 8)
set(BUILDNAME "${BUILDNAME}-amd64")
else()
set(BUILDNAME "${BUILDNAME}-i386")
endif()
# Add compiler name
get_filename_component(CMAKE_C_COMPILER_NAME ${CMAKE_C_COMPILER} NAME)
set(BUILDNAME "${BUILDNAME}-${CMAKE_C_COMPILER_NAME}")
# Add the build type, e.g. "Debug, Release..."
if(CMAKE_BUILD_TYPE)
set(BUILDNAME "${BUILDNAME}-${CMAKE_BUILD_TYPE}")
endif(CMAKE_BUILD_TYPE)
# Specific options of Pastix
if(USE_QT5)
set(BUILDNAME "${BUILDNAME}-Qt5")
else()
set(BUILDNAME "${BUILDNAME}-Qt4")
endif()
if(VITE_ENABLE_TAU)
set(BUILDNAME "${BUILDNAME}-Tau")
endif(VITE_ENABLE_TAU)
if(VITE_ENABLE_OTF)
set(BUILDNAME "${BUILDNAME}-OTF")
endif(VITE_ENABLE_OTF)
if(VITE_ENABLE_OTF2)
set(BUILDNAME "${BUILDNAME}-OTF2")
endif(VITE_ENABLE_OTF2)
endif()
#!/bin/bash
# Performs an analysis of Vite source code:
# - we consider to be in Vite's source code root
# - we consider having the coverage file vite.lcov in the root directory
# - we consider having cppcheck, rats, sonar-scanner programs available in the environment
# filter sources:
# - consider generated files in ${BUILDDIR}
# - exclude base *z* files to avoid duplication
# - exclude cblas.h and lapacke-.h because not really part of vite and make cppcheck analysis too long
if [ $# -gt 0 ]
then
BUILDDIR=$1
fi
BUILDDIR=${BUILDDIR:-build}
./.gitlab-ci-filelist.sh $BUILDDIR
# Undefine this because not relevant in our configuration
#export UNDEFINITIONS="-UWIN32 -UWIN64 -U_MSC_EXTENSIONS -U_MSC_VER -U__SUNPRO_C -U__SUNPRO_CC -U__sun -Usun -U__cplusplus"
# run cppcheck analysis
cppcheck -v -f --language=c++ --platform=unix64 --enable=all --xml --xml-version=2 --suppress=missingInclude ${UNDEFINITIONS} --file-list=./filelist-c.txt 2> vite-cppcheck.xml
# run rats analysis
rats -w 3 --xml `cat filelist.txt` > vite-rats.xml
# Set the default for the project key
SONARQUBE_PROJECTKEY=${SONARQUBE_PROJECTKEY:-hiepacs:vite:gitlab:master}
# create the sonarqube config file
cat > sonar-project.properties << EOF
sonar.host.url=https://sonarqube.bordeaux.inria.fr/sonarqube
sonar.login=$SONARQUBE_LOGIN
sonar.links.homepage=https://gitlab.inria.fr/solverstack/vite
sonar.links.scm=https://gitlab.inria.fr/solverstack/vite.git
sonar.links.ci=https://gitlab.inria.fr/solverstack/vite/pipelines
sonar.links.issue=https://gitlab.inria.fr/solverstack/vite/issues
sonar.projectKey=$SONARQUBE_PROJECTKEY
sonar.projectDescription=Parallel Sparse direct Solver
sonar.projectVersion=master
sonar.language=c++
sonar.sources=src, tests, plugins
sonar.inclusions=`cat filelist.txt | xargs echo | sed 's/ /, /g'`
sonar.sourceEncoding=UTF-8
sonar.cxx.errorRecoveryEnabled=true
sonar.cxx.compiler.charset=UTF-8
sonar.cxx.compiler.parser=GCC
sonar.cxx.compiler.regex=^(.*):(\\d+):\\d+: warning: (.*)\\[(.*)\\]$
sonar.cxx.compiler.reportPath=vite-build.log
#sonar.cxx.coverage.reportPath=vite-coverage.xml
sonar.cxx.cppcheck.reportPath=vite-cppcheck.xml
sonar.cxx.rats.reportPath=vite-rats.xml
sonar.cxx.jsonCompilationDatabase=build/compile_commands.json
EOF
# run sonar analysis + publish on sonarqube-dev
sonar-scanner -X > sonar.log
File mode changed from 100755 to 100644
......@@ -394,34 +394,24 @@ IF(VITE_ENABLE_SERIALIZATION)
ENDIF(VITE_ENABLE_SERIALIZATION)
# QT5
IF(USE_QT5)
# QT5
QT5_WRAP_UI(VITE_UIS_H ${VITE_UIS})
QT5_WRAP_CPP(VITE_MOC ${VITE_UIS_H} ${VITE_MOC_HDRS})
QT5_ADD_RESOURCES(VITE_RCC_SRCS ${VITE_RCCS})
ELSE(USE_QT5)
# QT4
ELSE(USE_QT5)
QT4_AUTOMOC(${VITE_SRCS})
FOREACH(_hdrs_file ${VITE_HDRS})
GET_FILENAME_COMPONENT(_abs_file ${_hdrs_file} ABSOLUTE)
FILE(READ ${_abs_file} _contents)
STRING(REGEX MATCHALL "Q_OBJECT" _match "${_contents}")
IF(_match)
SET(VITE_MOC_HDRS ${VITE_MOC_HDRS} ${_hdrs_file})
ENDIF(_match)
ENDFOREACH(_hdrs_file ${VITE_HDRS})
QT4_WRAP_UI(VITE_UIS_H ${VITE_UIS})
QT4_WRAP_CPP(VITE_MOC ${VITE_UIS_H} ${VITE_MOC_HDRS})
QT4_ADD_RESOURCES(VITE_RCC_SRCS ${VITE_RCCS})
ENDIF(USE_QT5)
INCLUDE_DIRECTORIES(
${CMAKE_CURRENT_BINARY_DIR}/common
