GitLab
Support
Community forum
Keyboard shortcuts
vite
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Analytics
Analytics
Value Stream
solverstack
vite
699ec1e4
699ec1e4
Mathieu Faverge
Apply patch 2 from issue
#13
0e9d8bdd
23
23 changed files
213 additions
234 deletions
+213
-234
src/common/Message.cpp
+1
-3
src/interface/Interval_select.cpp
+1
-2
src/interface/Node_select.cpp
+1
-2
src/interface/Settings_window.cpp
+1
-2
src/interface/qxtpimpl.h
+189
-189
src/interface/qxtspanslider.cpp
+1
-3
src/interface/viteqtreewidget.cpp
+1
-2
src/parser/PajeParser/PajeFileManager.hpp
+1
-1
src/parser/PajeParser/ParserVite.cpp
+2
-2
src/parser/Parser.hpp
+1
-1
src/render/GanttDiagram.hpp
+2
-4
src/render/Geometry.cpp
+1
-2
src/render/Hook_event.cpp
+1
-2
src/render/Ruler.hpp
+1
-1
src/render/render_stats_svg.cpp
+1
-2
src/statistics/DrawCounter.hpp
+1
-2
src/statistics/DrawHDiagram.hpp
+1
-2
src/statistics/DrawStats.hpp
+1
-2
src/statistics/DrawVDiagram.hpp
+1
-2
src/trace/DrawTrace.hpp
+1
-2
src/trace/State.cpp
src/trace/State.cpp
+1
-2
src/trace/StateChange.cpp
+1
-3
src/trace/values/Value.hpp
+1
-1
699ec1e4
@@ -91,9 +91,7 @@ const Message::end_information_t Message::endi;
const
Message
end_selection_information_t
Message
endsi
#endif
Message
Message
Message
Message
default
Message
Message
get_instance
if
_message
699ec1e4
@@ -90,8 +90,7 @@ Interval_select::Interval_select(Interface_graphic * console,QWidget *parent) :
_applied
false
Interval_select
Interval_select
Interval_select
Interval_select
default
Trace
Interval_select
get_trace
return
_trace
699ec1e4
@@ -87,8 +87,7 @@ Node_select::Node_select(Interface_graphic * console,QWidget *parent) : QWidget(
QMetaObject
connectSlotsByName
nullptr
Node_select
Node_select
Node_select
Node_select
default
void
Node_select
set_initial_container_names
699ec1e4
@@ -526,8 +526,7 @@ Settings_window::Settings_window(Core *c, QWidget *parent)
tabWidget
insertTab
3
_tab_links
"Links"
Settings_window
Settings_window
Settings_window
Settings_window
default
void
Settings_window
on_tabWidget_currentChanged
int
699ec1e4
** Copyright (C) Adam Higerd <coda@bobandgeorge.com>. Some rights reserved.
** This file is part of the QxtCore module of the
** Qt eXTension library <http://libqxt.sourceforge.net>
** This library is free software; you can redistribute it and/or
** modify it under the terms of the GNU Lesser General Public
** License as published by the Free Software Foundation; either
** version 2.1 of the License, or any later version.
** This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
** WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
** There is aditional information in the LICENSE file of libqxt.
** If you did not receive a copy of the file try to download it or
** contact the libqxt Management
\class QxtPimpl QxtPimpl
\ingroup core
\brief Hide private details of a class
Application code generally doesn't have to be concerned about hiding its
implementation details, but when writing library code it is important to
maintain a constant interface, both source and binary. Maintaining a constant
source interface is easy enough, but keeping the binary interface constant
means moving implementation details into a private class. The PIMPL, or
d-pointer, idiom is a common method of implementing this separation. QxtPimpl
offers a convenient way to connect the public and private sides of your class.
\section start Getting Started
Before you declare the public class, you need to make a forward declaration
of the private class. The private class must have the same name as the public
class, followed by the word Private. For example, a class named MyTest would
declare the private class with:
\code
class MyTestPrivate;
\endcode
\subsection pub The Public Class
Generally, you shouldn't keep any data members in the public class without a
good reason. Functions that are part of the public interface should be declared
in the public class, and functions that need to be available to subclasses (for
calling or overriding) should be in the protected section of the public class.
To connect the private class to the public class, include the
QXT_DECLARE_PRIVATE macro in the private section of the public class. In the
example above, the private class is connected as follows:
\code
private:
QXT_DECLARE_PRIVATE(MyTest);
\endcode
Additionally, you must include the QXT_INIT_PRIVATE macro in the public class's
constructor. Continuing with the MyTest example, your constructor might look
like this:
\code
MyTest::MyTest() {
// initialization
QXT_INIT_PRIVATE(MyTest);
\endcode
\subsection priv The Private Class
As mentioned above, data members should usually be kept in the private class.
This allows the memory layout of the private class to change without breaking
binary compatibility for the public class. Functions that exist only as
implementation details, or functions that need access to private data members,
should be implemented here.
To define the private class, inherit from the template QxtPrivate class, and
include the QXT_DECLARE_PUBLIC macro in its public section. The template
parameter should be the name of the public class. For example:
\code
class MyTestPrivate : public QxtPrivate<MyTest> {
public:
MyTestPrivate();
QXT_DECLARE_PUBLIC(MyTest);
\endcode
\section cross Accessing Private Members
Use the qxt_d() function (actually a function-like object) from functions in
the public class to access the private class. Similarly, functions in the
private class can invoke functions in the public class by using the qxt_p()
function (this one's actually a function).
For example, assume that MyTest has methods named getFoobar and doBaz(),
and MyTestPrivate has a member named foobar and a method named doQuux().
The code might resemble this example:
\code
int MyTest::getFoobar() {
return qxt_d().foobar;
void MyTestPrivate::doQuux() {
qxt_p().doBaz(foobar);
\endcode
#ifndef QXTPIMPL_H
#define QXTPIMPL_H
/*! \relates QxtPimpl
* Declares that a public class has a related private class.
* This shuold be put in the private section of the public class. The parameter is the name of the public class.
#define QXT_DECLARE_PRIVATE(PUB) friend class PUB##Private; QxtPrivateInterface<PUB, PUB##Private> qxt_d;
* Declares that a private class has a related public class.
* This may be put anywhere in the declaration of the private class. The parameter is the name of the public class.
#define QXT_DECLARE_PUBLIC(PUB) friend class PUB;
* Initializes resources owned by the private class.
* This should be called from the public class's constructor,
* before qxt_d() is used for the first time. The parameter is the name of the public class.
#define QXT_INIT_PRIVATE(PUB) qxt_d.setPublic(this);
#ifdef QXT_DOXYGEN_RUN
* Returns a reference to the private class.
* This function is only available in a class using \a QXT_DECLARE_PRIVATE.
QxtPrivate
PUB
qxt_d
* Returns a const reference to the private class.
* This overload will be automatically used in const functions.
const
QxtPrivate
PUB
qxt_d
* Returns a reference to the public class.
* This function is only available in a class using \a QXT_DECLARE_PUBLIC.
PUB
qxt_p
* Returns a const reference to the public class.
const
PUB
qxt_p
#endif
#ifndef QXT_DOXYGEN_RUN
template
typename
PUB
class
QxtPrivate
public:
virtual
QxtPrivate
inline
void
QXT_setPublic
PUB
pub
qxt_p_ptr
pub
protected:
inline
PUB
qxt_p
return
qxt_p_ptr
inline
const
PUB
qxt_p
const
return
qxt_p_ptr
private:
PUB
qxt_p_ptr
template
typename
PUB
typename
PVT
class
QxtPrivateInterface
friend
class
QxtPrivate
PUB
public:
QxtPrivateInterface
pvt
new
PVT
QxtPrivateInterface
delete
pvt
inline
void
setPublic
PUB
pub
pvt
QXT_setPublic
pub
inline
PVT
operator
return
static_cast
PVT
pvt
inline
const
PVT
operator
const
return
static_cast
PVT
pvt
private:
QxtPrivate
PUB
pvt
#endif
#endif
\ No newline at end of file
\ingroup core
\code
\endcode
\code
private:
\endcode
like this:
\code
MyTest::MyTest() {
// initialization
\endcode
\code
public:
MyTestPrivate();
\endcode
\code
\endcode
#ifndef QXTPIMPL_H
#define QXTPIMPL_H
QxtPrivate
PUB
qxt_d
const
QxtPrivate
PUB
qxt_d
PUB
qxt_p
const
PUB
qxt_p
#endif
template
typename
PUB
class
QxtPrivate
public:
virtual
QxtPrivate
default
inline
void
QXT_setPublic
PUB
pub
qxt_p_ptr
pub
protected:
inline
PUB
qxt_p
return
qxt_p_ptr
inline
const
PUB
qxt_p
const
return
qxt_p_ptr
private:
PUB
qxt_p_ptr
template
typename
PUB
typename
PVT
class
QxtPrivateInterface
friend
class
QxtPrivate
PUB
public:
QxtPrivateInterface
pvt
new
PVT
QxtPrivateInterface
delete
pvt
inline
void
setPublic
PUB
pub
pvt
QXT_setPublic
pub
inline
PVT
operator
return
static_cast
PVT
pvt
inline
const
PVT
operator
const
return
static_cast
PVT
pvt
private:
QxtPrivate
PUB
pvt
#endif
#endif
699ec1e4
@@ -416,9 +416,7 @@ QxtSpanSlider::QxtSpanSlider(Qt::Orientation orientation, QWidget* parent) : QSl
Destructs the span slider.
QxtSpanSlider
QxtSpanSlider
QxtSpanSlider
QxtSpanSlider
default
\property QxtSpanSlider::handleMovementMode
699ec1e4
@@ -12,8 +12,7 @@ viteQTreeWidget::viteQTreeWidget(QWidget *parent)
viteQTreeWidget
viteQTreeWidget
viteQTreeWidget
viteQTreeWidget
default
void
viteQTreeWidget
dropEvent
QDropEvent
e
699ec1e4
@@ -85,7 +85,7 @@ typedef struct PajeLine {
int
_nbtks
char
_tokens
PajeLine
PajeLine
default
PajeLine_t
699ec1e4
@@ -69,9 +69,9 @@
using
namespace
std
ParserVite
ParserVite
ParserVite
ParserVite
default
ParserVite
ParserVite
const
std
string
filename
Parser
filename
ParserVite
ParserVite
ParserVite
ParserVite
default
void
ParserVite
parse
Trace
trace
bool
finish_trace_after_parse
699ec1e4
@@ -78,7 +78,7 @@ public:
Parser
Parser
const
std
string
filename
virtual
Parser
virtual
Parser
default
* \fn parse(const std::string &filename, Trace &trace, bool finish_trace_after_parse = true)
699ec1e4
@@ -99,8 +99,7 @@ private:
* \brief The default constructor is in private scope to prevent Render instanciation without
* provide a drawing instance.
GanttDiagram
GanttDiagram
default
public:
@@ -120,8 +119,7 @@ public:
* \brief The destructor
virtual
GanttDiagram
virtual
GanttDiagram
default
699ec1e4
@@ -85,8 +85,7 @@ Geometry::Geometry(){
Geometry
Geometry
Geometry
Geometry
default
699ec1e4
@@ -179,8 +179,7 @@ Hook_event::Hook_event(Render* render_instance, Core* core, QWidget *parent, con
Hook_event
Hook_event
Hook_event
Hook_event
default
699ec1e4
@@ -61,7 +61,7 @@ private:
* \brief The default constructor. In private scope to prevent instance.
Ruler
Ruler
default
699ec1e4
@@ -62,8 +62,7 @@ Render_stats_svg::Render_stats_svg(string filename){
_y_max
Render_stats_svg
Render_stats_svg
Render_stats_svg
Render_stats_svg
default
void
Render_stats_svg
set_total_height
Element_pos
h
699ec1e4
@@ -90,8 +90,7 @@ public:
virtual
DrawCounter
virtual
DrawCounter
default
699ec1e4
@@ -86,8 +86,7 @@ public:
virtual
DrawHDiagram
virtual
DrawHDiagram
default
699ec1e4
@@ -155,8 +155,7 @@ public:
virtual
DrawStats
virtual
DrawStats
default
699ec1e4
@@ -67,8 +67,7 @@ public:
virtual
DrawVDiagram
virtual
DrawVDiagram
default
699ec1e4
@@ -172,8 +172,7 @@ public:
virtual
DrawTrace
virtual
DrawTrace
default
src/trace/State.cpp
699ec1e4
@@ -58,8 +58,7 @@ State::State(Date start, Date end, StateType *type, Container *container, Entity
State
State
State
State
default
Date
State
get_start_time
const
return
_start
699ec1e4
@@ -53,9 +53,7 @@
using
namespace
std
StateChange
StateChange
StateChange
StateChange
default
StateChange
StateChange
Date
time
_time
time
699ec1e4
@@ -64,7 +64,7 @@ protected:
public:
virtual
Value
virtual
Value
default
