Commit 5627e8b5 authored by Arthur Redondy's avatar Arthur Redondy
mis a jour du menu aide + suppression de l'ancien makefile
parent f3e6d01e
# * \brief The ViTE main makefile.
# * Commands are : \
# * make all : compiles the released version.
# * make doc : create the documentation with Doxygen.
# * make debugs : compiles with debug informations.
# * make clean : deletes generated files.
DIR_PARSER = parser
DIR_INTERFACE = interface
DIR_TRACE = trace/src
all:
# @(cd $(DIR_TRACE) && make)
# @(cd $(DIR_PARSER) && make)
make -C $(DIR_INTERFACE)
@echo " "
@echo "Compilation completed! File created in 'bin' folder."
@echo " "
doc:
doxygen Doxyfile
@echo " "
@echo "Documentation generated successfully !"
@echo "Please open index.html in 'html' folder for a web documentation, or use 'make' in the 'latex' folder for a pdf documentation."
@echo " "
debugs:
make debugs -C $(DIR_INTERFACE)
# @(cd $(DIR_INTERFACE) && make debugs)
make debug -C $(DIR_PARSER)
# @(cd $(DIR_PARSER) && make debug)
@echo " "
@echo "Compilation completed! (debug)"
@echo " "
clean:
make -i -f Makefile wash # The washing is launched to ignore errors.
@echo " "
@echo "Cleaned!"
@echo " "
# Must be called with option -i, otherwise an error occured in the first instructions, the followings won't be executed.
wash:
make clean -C $(DIR_INTERFACE)
make clean -C $(DIR_TRACE)
make clean -C $(DIR_PARSER)
cd bin && $(RM) *
...@@ -45,8 +45,10 @@ Help::Help() : QWidget() { ...@@ -45,8 +45,10 @@ Help::Help() : QWidget() {
"<dd>menu <em>View</em> then <em>Fullscreen</em> (shortcut: F11)</dd>" "<dd>menu <em>View</em> then <em>Fullscreen</em> (shortcut: F11)</dd>"
"<dt><strong>Display/Hide the warnings and errors</strong></dt>" "<dt><strong>Display/Hide the warnings and errors</strong></dt>"
"<dd>menu <em>View</em> then <em>No warning</em></dd>" "<dd>menu <em>View</em> then <em>No warning</em></dd>"
"<dt><strong>Display/Hide the arrows and the events</strong></dt>" "<dt><strong>Display/Hide the arrows</strong></dt>"
"<dd>menu <em>View</em> then <em>No arrows and events</em></dd>" "<dd>menu <em>View</em> then <em>No arrows</em></dd>"
"<dt><strong>Display/Hide the events</strong></dt>"
"<dd>menu <em>View</em> then <em>No events</em></dd>"
"</dl>" "</dl>"
"<h2>Menu <em>Help</em></h2>" "<h2>Menu <em>Help</em></h2>"
"<dl>" "<dl>"
