Commit 2e30bf2f authored by Mathieu Faverge's avatar Mathieu Faverge
First version of Horizontal diagramm, legend needs to be completed, and first...
First version of Horizontal diagramm, legend needs to be completed, and first drawing method should be exported in an other class
parent 5598d54f
...@@ -83,8 +83,13 @@ ...@@ -83,8 +83,13 @@
</property> </property>
</widget> </widget>
</item> </item>
<item row="2" column="1" > <item row="3" column="1" >
<widget class="QComboBox" name="_kind_of_diagram_box" > <widget class="QComboBox" name="_kind_of_diagram_box" >
<item>
<property name="text" >
<string>Horizontal Histogram</string>
</property>
</item>
<item> <item>
<property name="text" > <property name="text" >
<string>Histogram</string> <string>Histogram</string>
...@@ -90,6 +90,14 @@ public: ...@@ -90,6 +90,14 @@ public:
void draw_horizontal_line(const Element_pos x, const Element_pos y, const Element_pos size_x); void draw_horizontal_line(const Element_pos x, const Element_pos y, const Element_pos size_x);
* \brief Draw a line.
* \param x the x position of the text.
* \param y the y position of the text.
* \param value the string value of the text.
void draw_vertical_line(const Element_pos x, const Element_pos y, const Element_pos size_x);
void draw_axis(const Element_pos x, const Element_pos y, const Element_pos size_x, const Element_pos size_y); void draw_axis(const Element_pos x, const Element_pos y, const Element_pos size_x, const Element_pos size_y);
* \brief Draw a rectangle. * \brief Draw a rectangle.
...@@ -147,6 +155,16 @@ inline void Render_stats_opengl::draw_horizontal_line(const Element_pos x, const ...@@ -147,6 +155,16 @@ inline void Render_stats_opengl::draw_horizontal_line(const Element_pos x, const
glEnd(); glEnd();
inline void Render_stats_opengl::draw_vertical_line(const Element_pos x, const Element_pos y, const Element_pos size_y){
glBegin(GL_LINES);
glColor3ub(0, 0, 0);
glVertex2i(x, y);
glVertex2i(x, y+size_y);
glEnd();
inline void Render_stats_opengl::draw_axis(const Element_pos x, const Element_pos y, const Element_pos size_x, const Element_pos size_y){ inline void Render_stats_opengl::draw_axis(const Element_pos x, const Element_pos y, const Element_pos size_x, const Element_pos size_y){
glBegin(GL_LINES); glBegin(GL_LINES);
*\file DrawStats.hpp
#ifndef DRAW_HDIAGRAM_HPP
#define DRAW_HDIAGRAM_HPP
#include <string>
#include <vector>
#include <map>
#include "../message/Message.hpp"
#include "../trace/Trace.hpp"
#include "../trace/tree/Interval.hpp"
#include "Statistic.hpp"
#include "DrawStats.hpp"
template<class T>
class DrawHDiagram : public DrawStats<T> {
protected:
double _startx;
double _starty;
double _graph_width;
double _draw_width;
double _draw_height;
double _legend_width;
double _legend_height;
public:
* \brief The default constructor
DrawHDiagram() {
_startx = _START_HISTOGRAM_X_DEFAULT;
_starty = 200.0f;
this->_size_for_one_container = _HEIGHT_FOR_ONE_CONTAINER_DEFAULT;
this->_percentage_height_default = (this->_size_for_one_container - _START_HISTOGRAM_Y_DEFAULT) / 100.;
this->_pos_x_container_name = _POS_X_CONTAINER_NAME;
this->_pos_y_container_name = _POS_Y_CONTAINER_NAME;
/* Size for rectangles in the legend */
this->_width_for_rect_legend = 20.;
this->_height_for_rect_legend = 15.;
* \brief The destructor
virtual ~DrawHDiagram() {
* \fn build(T* draw_object, Trace* trace)
* \brief The trace building function.
* \param draw_object the kind of object which will be drawn (OpenGL, SVG...).
* \param trace the trace data.
void build(T* draw_object, std::vector<Container *> containers_to_print) {
int nbcont;
draw_object->clear();
_draw_height = draw_object->height();
_draw_width = draw_object->width();
_legend_height = draw_object->height();
_legend_width = draw_object->width();
_graph_width = _draw_width - _startx - 30.;
this->_containers_to_print = containers_to_print;
nbcont = this->_containers_to_print.size();
draw_object->start_draw();
draw_object->set_total_height((nbcont+1)*_WIDTH_HISTOGRAM_DEFAULT
+ 10.);
draw_object->set_total_width(draw_object->width());
draw_object->draw_axis(_startx,
_starty - (nbcont-1)*_WIDTH_HISTOGRAM_DEFAULT,
_graph_width + 10.,
(nbcont+1)*_WIDTH_HISTOGRAM_DEFAULT);
draw_object->draw_horizontal_line(_startx,
_starty + _WIDTH_HISTOGRAM_DEFAULT,
_graph_width + 10.);
for (int i=25; i < 101; i+=25)
// Draw Up Scale
draw_object->draw_vertical_line(_startx + i*_graph_width/100.,
_starty + _WIDTH_HISTOGRAM_DEFAULT - 2.5,
5.);
draw_object->draw_text(_startx + i*_graph_width/100 - 10.,
_starty + _WIDTH_HISTOGRAM_DEFAULT + 15.,
QString::number(i, 'd', 1).toStdString()+"%");
// Dra Down Scale
_starty - (nbcont-1)*_WIDTH_HISTOGRAM_DEFAULT - 2.5,
5.);
_starty - (nbcont-1)*_WIDTH_HISTOGRAM_DEFAULT - 15.,
for(int i = 0 ; i < nbcont ; i ++) {
draw_diagram(draw_object, i);
draw_legend(draw_object,
_POS_X_LEGEND_DEFAULT + _startx,
_POS_Y_LEGEND_DEFAULT + _starty - (nbcont+3)*_WIDTH_HISTOGRAM_DEFAULT);
end_draw(draw_object);
void draw_diagram(T* draw_object, const int container_id) {
Statistic *stat_temp;
std::map<const EntityValue*, stats*> temp_states;
double duration;
int pos_x, pos_y;
std::string ctname;
stat_temp = new Statistic();
this->_containers_to_print[container_id]->fill_stat(stat_temp, Interval(this->_start_time, this->_end_time));
temp_states = stat_temp->get_states();
this->_states.push_back(temp_states);
duration = this->_end_time - this->_start_time;
// Printing of the trace
//std::cout << "nb states " << temp_states.size() << std::endl;
// Depending on the kind of diagram...
pos_x = _startx;
pos_y = _starty - container_id * _WIDTH_HISTOGRAM_DEFAULT;
// Draw the container name
ctname = this->_containers_to_print[container_id]->get_name().to_string();
draw_object->draw_text(_POS_X_CONTAINER_NAME,
pos_y + _WIDTH_HISTOGRAM_DEFAULT / 2. - 5.,
ctname);
// Draw the stats
for (map<const EntityValue *, stats *>::iterator it = temp_states.begin();
it != temp_states.end();
it ++)
double length = (*it).second->_total_length;
double percent = length / duration ;
double width = percent * _graph_width;
std::string name = (*it).first->get_name().to_string();
double red = 0.7;
double green = 0.7;
double blue = 0.75;
// We search for a color
if((*it).first->get_extra_fields()->find(std::string("Color")) != (*it).first->get_extra_fields()->end())
const Color *color = (const Color *)(*it).first->get_extra_fields()->find(std::string("Color"))->second;
red = color->get_red();
green = color->get_green();
blue = color->get_blue();
draw_object->draw_rect(pos_x, pos_y,
width, _WIDTH_HISTOGRAM_DEFAULT,
red, green, blue);
if ( width > 30. )
draw_object->draw_text(pos_x + width / 2 - 10., pos_y + _WIDTH_HISTOGRAM_DEFAULT / 2. - 5.,
QString::number(percent*100., 'f', 1).toStdString()+"%");
pos_x += width;
delete stat_temp;
void draw_legend(T* draw_object, int pos_x, int pos_y) {
const double w = this->_width_for_rect_legend;
const double h = this->_height_for_rect_legend;
/* used to print legend on 3 rows */
int decalage = 0;
for (map<const EntityValue *, stats *>::iterator it = this->_states[0].begin();
it != this->_states[0].end();
it ++, decalage ++) {
draw_object->draw_text(pos_x+w+_POS_X_LEGEND_DEFAULT, pos_y, name);
if((*it).first->get_extra_fields()->find(std::string("Color")) != (*it).first->get_extra_fields()->end()) {
draw_object->draw_rect(pos_x, pos_y, w, h, color->get_red(), color->get_green(), color->get_blue());
else {
draw_object->draw_rect(pos_x, pos_y, w, h, 0.7, 0.7, 0.75);
switch(decalage%3) {
case 2:
pos_x += 100;
pos_y += 40;
break;
default:
pos_y -= 20;
break;
#endif
...@@ -124,13 +124,12 @@ public: ...@@ -124,13 +124,12 @@ public:
* \fn build(T* draw_object, Trace* trace, std::string kind_of_diagram) * \fn build(T* draw_object, Trace* trace)
* \brief The trace building function. * \brief The trace building function.
* \param draw_object the kind of object which will be drawn (OpenGL, SVG...). * \param draw_object the kind of object which will be drawn (OpenGL, SVG...).
* \param trace the trace data. * \param trace the trace data.
* \param kind_of_diagram the kind of diagram (histogram, chart...)
void build(T* draw_object, std::vector<Container *> containers_to_print, std::string kind_of_diagram) { virtual void build(T* draw_object, std::vector<Container *> containers_to_print) {
draw_object->clear(); draw_object->clear();
...@@ -145,14 +144,14 @@ public: ...@@ -145,14 +144,14 @@ public:
for(int i = 0 ; i < number_of_containers ; i ++) { for(int i = 0 ; i < number_of_containers ; i ++) {
draw_container_name(draw_object, i); draw_container_name(draw_object, i);
draw_diagram(draw_object, i, kind_of_diagram); draw_diagram(draw_object, i);
draw_legend(draw_object, i); draw_legend(draw_object, i);
end_draw(draw_object); end_draw(draw_object);
void draw_container_name(T* draw_object, const int container_id) const { virtual void draw_container_name(T* draw_object, const int container_id) const {
// Get the position for the i-th container name // Get the position for the i-th container name
Element_pos pos_x = _pos_x_container_name; Element_pos pos_x = _pos_x_container_name;
...@@ -163,7 +162,7 @@ public: ...@@ -163,7 +162,7 @@ public:
draw_object->draw_text(pos_x, pos_y, name); draw_object->draw_text(pos_x, pos_y, name);
void draw_diagram(T* draw_object, const int container_id, std::string kind_of_diagram) { virtual void draw_diagram(T* draw_object, const int container_id) {
Statistic *stat_temp = new Statistic(); Statistic *stat_temp = new Statistic();
_containers_to_print[container_id]->fill_stat(stat_temp, Interval(_start_time, _end_time)); _containers_to_print[container_id]->fill_stat(stat_temp, Interval(_start_time, _end_time));
std::map<const EntityValue*, stats*> temp_states = stat_temp->get_states(); std::map<const EntityValue*, stats*> temp_states = stat_temp->get_states();
...@@ -171,53 +170,46 @@ public: ...@@ -171,53 +170,46 @@ public:
// Printing of the trace // Printing of the trace
// Depending on the kind of diagram... int pos_x = _START_HISTOGRAM_X_DEFAULT;
if(kind_of_diagram == "Histogram") { int pos_y = _START_HISTOGRAM_Y_DEFAULT - container_id*_size_for_one_container;
const double max_percentage = get_max_percentage(temp_states);
int pos_x = _START_HISTOGRAM_X_DEFAULT; // Draw axes
int pos_y = _START_HISTOGRAM_Y_DEFAULT - container_id*_size_for_one_container; draw_object->draw_axis(pos_x, pos_y, _WIDTH_HISTOGRAM_DEFAULT*(_states[container_id].size()+1), _percentage_height_default*100);
const double max_percentage = get_max_percentage(temp_states); draw_object->draw_text(pos_x-30, pos_y+_percentage_height_default*100-5, QString::number(max_percentage*100., 'g', 3).toStdString()+"%");
// Draw axes draw_object->draw_horizontal_line(pos_x, pos_y+_percentage_height_default*100, _WIDTH_HISTOGRAM_DEFAULT*(_states[container_id].size()+1));
draw_object->draw_horizontal_line(pos_x, pos_y+_percentage_height_default*100, _WIDTH_HISTOGRAM_DEFAULT*(_states[container_id].size()+1)); // Draw the stats
// Draw the stats it ++) {
for (map<const EntityValue *, stats *>::iterator it = temp_states.begin(); std::string name = (*it).first->get_name().to_string();
it ++) { // We have to convert the percentage in a rectangle and print it
std::string name = (*it).first->get_name().to_string(); const double length = (*it).second->_total_length;
const double height = length*100.*_percentage_height_default/(_end_time-_start_time);
const double length = (*it).second->_total_length; // We search for a color
const double height = length*100.*_percentage_height_default/(_end_time-_start_time); if((*it).first->get_extra_fields()->find(std::string("Color")) != (*it).first->get_extra_fields()->end()) {
// We search for a color draw_object->draw_rect(pos_x, pos_y, _WIDTH_HISTOGRAM_DEFAULT, height/max_percentage, color->get_red(), color->get_green(), color->get_blue());
if((*it).first->get_extra_fields()->find(std::string("Color")) != (*it).first->get_extra_fields()->end()) { }
const Color *color = (const Color *)(*it).first->get_extra_fields()->find(std::string("Color"))->second; else {
draw_object->draw_rect(pos_x, pos_y, _WIDTH_HISTOGRAM_DEFAULT, height/max_percentage, color->get_red(), color->get_green(), color->get_blue()); draw_object->draw_rect(pos_x, pos_y, _WIDTH_HISTOGRAM_DEFAULT, height/max_percentage, 0.7, 0.7, 0.75);
else {
draw_object->draw_rect(pos_x, pos_y, _WIDTH_HISTOGRAM_DEFAULT, height/max_percentage, 0.7, 0.7, 0.75); // We print the percentage above
} draw_object->draw_text(pos_x, pos_y+height/max_percentage+1, QString::number(length/(_end_time-_start_time)*100., 'f', 1).toStdString()+"%");
// We print the percentage above //std::cout << "State : " << name << " for " << (*it).second->_total_length*100./(_end_time-_start_time)<< "% between " << _start_time << " sec and " << _end_time << " sec" << std::endl;
pos_x += _WIDTH_HISTOGRAM_DEFAULT;
//std::cout << "State : " << name << " for " << (*it).second->_total_length*100./(_end_time-_start_time)<< "% between " << _start_time << " sec and " << _end_time << " sec" << std::endl; }
else {
*Message::get_instance() << kind_of_diagram << " not yet implemented" << Message::endw;
delete stat_temp; delete stat_temp;
void draw_legend(T* draw_object, const int container_id) { virtual void draw_legend(T* draw_object, const int container_id) {
Element_pos pos_x = _POS_X_CONTAINER_NAME + _POS_X_LEGEND_DEFAULT; Element_pos pos_x = _POS_X_CONTAINER_NAME + _POS_X_LEGEND_DEFAULT;
Element_pos pos_y = -_size_for_one_container * (container_id) + _POS_Y_LEGEND_DEFAULT; Element_pos pos_y = -_size_for_one_container * (container_id) + _POS_Y_LEGEND_DEFAULT;
const double w = _width_for_rect_legend; const double w = _width_for_rect_legend;
...@@ -269,7 +261,7 @@ public: ...@@ -269,7 +261,7 @@ public:
* \return a value between 0. and 1. * \return a value between 0. and 1.
double get_max_percentage(std::map<const EntityValue*, stats*> &temp_states) const { virtual double get_max_percentage(std::map<const EntityValue*, stats*> &temp_states) const {
double value; double value;
double max_length = 0.; double max_length = 0.;
for (map<const EntityValue *, stats *>::iterator it = temp_states.begin(); for (map<const EntityValue *, stats *>::iterator it = temp_states.begin();
...@@ -285,7 +277,7 @@ public: ...@@ -285,7 +277,7 @@ public:
return value; return value;
void updateGL(T* draw_object) const { virtual void updateGL(T* draw_object) const {
draw_object->updateGL(); draw_object->updateGL();
...@@ -79,7 +79,7 @@ void Stats_window::init_window() { ...@@ -79,7 +79,7 @@ void Stats_window::init_window() {
void Stats_window::on_reload_button_clicked() { void Stats_window::on_reload_button_clicked() {
std::string kind_of_diagram = _kind_of_diagram_box->currentText ().toStdString();
// We delete the previous selected containers // We delete the previous selected containers
if(!_selected_containers.empty()) { if(!_selected_containers.empty()) {
_selected_containers.clear(); _selected_containers.clear();
...@@ -105,12 +105,30 @@ void Stats_window::on_reload_button_clicked() { ...@@ -105,12 +105,30 @@ void Stats_window::on_reload_button_clicked() {
// We get the times // We get the times
_start_time = _start_time_widget->text().toDouble(); _start_time = _start_time_widget->text().toDouble();
_end_time = _end_time_widget->text().toDouble(); _end_time = _end_time_widget->text().toDouble();
// We create a drawer // We create a drawer
DrawStats<Render_stats_opengl> drawer; DrawStats<Render_stats_opengl> *drawer;
drawer.set_times(_start_time, _end_time); if(kind_of_diagram == "Horizontal Histogram")
drawer.build(_ui_stats_area, _selected_containers, _kind_of_diagram_box->currentText ().toStdString()); {
drawer = new DrawHDiagram<Render_stats_opengl>();
else if (kind_of_diagram == "Histogram")
drawer = new DrawStats<Render_stats_opengl>();
else if (kind_of_diagram == "Chart")
else
drawer->set_times(_start_time, _end_time);
drawer->build(_ui_stats_area, _selected_containers);
_ui_stats_area->updateGL(); _ui_stats_area->updateGL();
...@@ -20,6 +20,7 @@ class Stats_window; ...@@ -20,6 +20,7 @@ class Stats_window;
#include "../message/Message.hpp" #include "../message/Message.hpp"
#include "../render/render_stats_opengl.hpp" #include "../render/render_stats_opengl.hpp"
#include "DrawStats.hpp" #include "DrawStats.hpp"
#include "DrawHDiagram.hpp"
* \brief Class used to display statistics of containers. * \brief Class used to display statistics of containers.
