GitLab
Support
Community forum
Keyboard shortcuts
vite
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Analytics
Analytics
Value Stream
solverstack
vite
03e92a41
03e92a41
Pascal Noisette
retour ligne
d68ea3f4
3
3 changed files
63 additions
15 deletions
+63
-15
src/interface/render_svg.cpp
+1
-1
src/interface/render_svg.hpp
+60
-12
tests/interface/test_svg.cpp
+2
-2
03e92a41
@@ -42,7 +42,7 @@ void Svg::init(const char *path){
\t\t\t
\n
\t\t
path
\n
\t\t\t
\n
\t\t\t\t
fill:
green;stroke:black
;stroke-width:1
\n
\t\t\t\t
fill:
none;stroke:green
;stroke-width:1
\n
\t\t\t
\n
\t
</style>
\n
\t
<desc>Rectangles</desc>
\n
03e92a41
@@ -11,15 +11,14 @@
#define MARGIN 10 //distance between two object
#define ARROWSIZE 4 //spike size
#define WAIT_NEW_CHRONO 0
#define INIT 1
#define WAIT_FOR_POINT 2
#include "render.hpp"
#include "resource.hpp"
/*typedef unsigned long Element_count ;
typedef double Element_pos;
typedef unsigned char Element_col;
class
Svg
public
Render
@@ -27,11 +26,12 @@ class Svg : public Render{
private:
std
ostringstream
_buffer
std
ostringstream
_chronogramme
int
_chronogramme_state
std
ofstream
_svg_file
inline
void
print
inline
void
rectangle
const
char
name
unsigned
long
w
unsigned
long
h
unsigned
long
x1
unsigned
long
y1
unsigned
int
r
unsigned
int
g
unsigned
int
b
inline
void
line
const
char
name
long
unsigned
int
x1
long
unsigned
int
y1
long
unsigned
int
x2
long
unsigned
int
y2
inline
void
triangle
const
char
name
unsigned
long
x1
unsigned
long
y1
unsigned
long
x2
unsigned
long
y2
unsigned
long
x3
unsigned
long
y3
inline
void
rectangle
const
char
name
Element_pos
w
Element_pos
h
Element_pos
x1
Element_pos
y1
unsigned
int
r
unsigned
int
g
unsigned
int
b
inline
void
line
const
char
name
Element_pos
x1
Element_pos
y1
Element_pos
x2
Element_pos
y2
inline
void
triangle
const
char
name
Element_pos
x1
Element_pos
y1
Element_pos
x2
Element_pos
y2
Element_pos
x3
Element_pos
y3
public:
* \brief SVG header buiding
@@ -111,6 +111,7 @@ inline void Svg::draw_container_text(const Element_pos x, const Element_pos y, c
inline
void
Svg
start_draw_containers
inline
void
Svg
end_draw_containers
@@ -128,12 +129,59 @@ inline void Svg::end_draw_states(){
inline
void
Svg
start_draw_counter
_chronogramme_state
INIT
inline
void
Svg
draw_counter
const
Element_pos
x
const
Element_pos
y
if
_chronogramme_state
INIT
if
x
_chronogramme
\n
<path d='M0 "
y
_chronogramme_state
WAIT_FOR_POINT
else
std
cerr
"draw_counter not initialised"
else
if
_chronogramme_state
WAIT_FOR_POINT
if
x
_chronogramme
_svg_file
write
_chronogramme
str
c_str
_chronogramme
str
size
_chronogramme
str
_chronogramme_state
WAIT_NEW_CHRONO
else
_chronogramme
" L"
x
y
else
if
_chronogramme_state
WAIT_NEW_CHRONO
if
x
_chronogramme
\n
<path d='M0 "
y
_chronogramme_state
WAIT_FOR_POINT
else
std
cerr
inline
void
Svg
end_draw_counter
if
_chronogramme_state
WAIT_NEW_CHRONO
std
cerr
"draw_counter not un-initialised"
@@ -141,13 +189,13 @@ inline void Svg::end_draw(){
Svg
void
Svg
rectangle
const
char
name
unsigned
long
w
unsigned
long
h
unsigned
long
x1
unsigned
long
y1
unsigned
int
r
unsigned
int
g
unsigned
int
b
void
Svg
rectangle
const
char
name
Element_pos
w
Element_pos
h
Element_pos
x1
Element_pos
y1
unsigned
int
r
unsigned
int
g
unsigned
int
b
_buffer
\n
<rect title='"
name
"' width='"
w
"' height='"
h
"' x='"
x1
"' y='"
y1
"' fill='rgb("
r
g
b
std
endl
print
@@ -155,12 +203,12 @@ void Svg::rectangle(const char* name,unsigned long w, unsigned long h,unsigned l
void
Svg
triangle
const
char
name
unsigned
long
x1
unsigned
long
y1
unsigned
long
x2
unsigned
long
y2
unsigned
long
x3
unsigned
long
y3
void
Svg
triangle
const
char
name
Element_pos
x1
Element_pos
y1
Element_pos
x2
Element_pos
y2
Element_pos
x3
Element_pos
y3
_buffer
\n
<polyline title='"
name
"' class='triangle' points='"
x1
y1
x2
y2
x3
y3
std
endl
print
@@ -173,7 +221,7 @@ void Svg::print(){
inline
void
Svg
line
const
char
name
long
unsigned
int
x1
long
unsigned
int
y1
long
unsigned
int
x2
long
unsigned
int
y2
inline
void
Svg
line
const
char
name
Element_pos
x1
Element_pos
y1
Element_pos
x2
Element_pos
y2
_buffer
\n
<line title='"
name
"' x1='"
x1
"' y1='"
y1
"' x2='"
x2
03e92a41
@@ -13,9 +13,9 @@ int main()
s
draw_container
LEVEL
2
50
100
s
draw_container
LEVEL
3
50
100
s
draw_state
100
750
NULL
0xff
0xcc
33
s
draw_state
100
750
.87
NULL
0xff
0xcc
33
s
draw_state
400
750
2
NULL
0xff
0xcc
33
s
draw_state
70
300
3
NULL
0xff
0xcc
33
s
draw_state
70
.756
300
3
NULL
0xff
0xcc
33
s
draw_arrow
100
700
LEVEL
LEVEL
3
s
draw_arrow
200
400
LEVEL
2
LEVEL
2
