GitLab
Support
Community forum
Keyboard shortcuts
vite
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Analytics
Analytics
Value Stream
solverstack
vite
03a65cdb
03a65cdb
Mathieu Faverge
Support new naming convention in Paje, the old one is still supported
205d4f05
10
Expand all
10 changed files
1146 additions
1146 deletions
+1146
-1146
src/CMakeLists.txt
src/CMakeLists.txt
+17
-17
src/parser/PajeParser/PajeDefinition.cpp
+53
-53
src/parser/PajeParser/PajeDefinition.hpp
+22
-13
src/parser/PajeParser/ParserDefinitionPaje.cpp
+97
-94
src/parser/PajeParser/ParserDefinitionPaje.hpp
+12
-12
src/parser/PajeParser/ParserEventPaje.cpp
+235
-234
src/parser/PajeParser/mt_ParserEventPaje.cpp
+153
-162
src/parser/PajeParser/mt_ParserPaje.cpp
+97
-98
src/trace/TraceBuilderThread.cpp
+456
-457
src/trace/TraceBuilderThread.hpp
+4
-6
src/CMakeLists.txt
03a65cdb
@@ -111,7 +111,7 @@ SET(VITE_HDRS
parser/ParsingThread.hpp
parser/Parser.hpp
parser/Parser.hpp
parser/ParserFactory.hpp
# Paje
# Paje
parser/PajeParser/PajeFileManager.hpp
@@ -150,7 +150,7 @@ SET(VITE_UIS
SET
VITE_SRCS
SET
VITE_SRCS
# Messages & Errors
# Messages & Errors
common/Message.cpp
common/Message.cpp
common/Errors.cpp
common/Errors.cpp
common/Tools.cpp
common/Tools.cpp
@@ -268,7 +268,7 @@ IF(VITE_ENABLE_VBO)
VITE_SRCS
VITE_SRCS
render/vbo.cpp
render/vbo.cpp
render/Render_alternate.cpp
ENDIF
VITE_ENABLE_VBO
ENDIF
VITE_ENABLE_VBO
@@ -325,7 +325,7 @@ ENDIF(VITE_ENABLE_TAU)
#ADD_DEFINITIONS(-DMEMORY_USAGE)
#ADD_DEFINITIONS(-DMEMORY_TRACE)
# BOOST
# BOOST
@@ -333,23 +333,23 @@ IF(VITE_ENABLE_SERIALIZATION)
link_directories
Boost_LIBRARY_DIRS
link_directories
Boost_LIBRARY_DIRS
include_directories
Boost_INCLUDE_DIRS
include_directories
Boost_INCLUDE_DIRS
add_definitions
"-DUSE_ITC -DBOOST_SERIALIZE"
add_definitions
SET
VITE_HDRS
SET
VITE_HDRS
VITE_HDRS
VITE_HDRS
parser/ParserSplitted.hpp
trace/IntervalOfContainer.hpp
trace/SerializerWriter.hpp
trace/SerializerDispatcher.hpp
SET
VITE_SRCS
SET
VITE_SRCS
VITE_SRCS
VITE_SRCS
parser/ParserSplitted.cpp
trace/IntervalOfContainer.cpp
trace/SerializerWriter.cpp
trace/SerializerDispatcher.cpp
ENDIF
ENDIF
@@ -386,7 +386,7 @@ if( APPLE )
SET
OSX_ICON_FILES
"interface/icon/mac_logo.icns"
SET
OSX_ICON_FILES
set_source_files_properties
OSX_ICON_FILES
PROPERTIES MACOSX_PACKAGE_LOCATION Resources
OSX_ICON_FILES
ADD_EXECUTABLE
vite MACOSX_BUNDLE
VITE_SRCS
VITE_MOC
VITE_RCC_SRCS
OSX_ICON_FILES
ADD_EXECUTABLE
vite MACOSX_BUNDLE
VITE_SRCS
VITE_MOC
VITE_RCC_SRCS
OSX_ICON_FILES
SET_TARGET_PROPERTIES
vite PROPERTIES
vite PROPERTIES
MACOSX_BUNDLE_INFO_STRING
"ViTE"
"ViTE"
MACOSX_BUNDLE_ICON_FILE
"mac_logo.icns"
"mac_logo.icns"
MACOSX_BUNDLE_LONG_VERSION_STRING
"Visual Trace Explorer - version
VITE_VERSION_MAJOR
VITE_VERSION_MINOR
VITE_VERSION_MAJOR
VITE_VERSION_MINOR
@@ -394,7 +394,7 @@ if( APPLE )
MACOSX_BUNDLE_SHORT_VERSION_STRING
"ViTE-
VITE_VERSION_MAJOR
VITE_VERSION_MINOR
"ViTE-
VITE_VERSION_MAJOR
VITE_VERSION_MINOR
MACOSX_BUNDLE_BUNDLE_VERSION
"1.0"
"1.0"
MACOSX_BUNDLE_COPYRIGHT
"INRIA 2006-2012"
"INRIA 2006-2012"
MACOSX_BUNDLE_INFO_PLIST
CMAKE_CURRENT_SOURCE_DIR
/vite-info.plist.in
/vite-info.plist.in
else
APPLE
else
APPLE
ADD_EXECUTABLE
vite
VITE_SRCS
VITE_MOC
VITE_RCC_SRCS
ADD_EXECUTABLE
vite
VITE_SRCS
VITE_MOC
VITE_RCC_SRCS
endif
APPLE
endif
APPLE
@@ -410,7 +410,7 @@ IF(${CMAKE_SYSTEM_NAME} MATCHES "Linux")
rt
rt
ADD_DEFINITIONS
"-DBOOST_GZIP"
ADD_DEFINITIONS
"-DBOOST_GZIP"
ENDIF
CMAKE_SYSTEM_NAME
MATCHES
"Linux"
ENDIF
CMAKE_SYSTEM_NAME
MATCHES
"Linux"
IF
VITE_ENABLE_VBO
IF
VITE_ENABLE_VBO
TARGET_LINK_LIBRARIES
vite
vite
03a65cdb
@@ -60,41 +60,41 @@ void print(std::vector<PajeFieldName>* fields, PajeDefinition *def) {
size_t
size
def
_fields
size
size_t
size
def
_fields
size
cout
def
_trid
def
_name
endl
cout
def
_trid
def
_name
endl
for
i
i
size
i
for
i
i
size
i
PajeFieldName
p
PajeFieldName
p
try
try
p
fields
at
def
_fields
i
_idname
p
fields
at
def
_fields
i
_idname
cout
p
_name
cout
p
_name
catch
out_of_range
e
catch
out_of_range
e
cout
"name not found"
cout
"name not found"
string
s
string
s
//as this won't change in the future, we can use a switch
switch
def
_fields
i
_idtype
switch
def
_fields
i
_idtype
case
case
s
"int"
s
"int"
break
break
case
case
s
"hex"
s
"hex"
break
break
case
2
case
2
s
"date"
s
"date"
break
break
case
3
case
3
s
"double"
s
"double"
break
break
case
4
case
4
s
"string"
s
"string"
break
break
case
5
case
5
s
"color"
s
"color"
break
break
default:
default:
s
"error : wrong type"
s
break
break
cout
s
endl
cout
s
endl
@@ -106,7 +106,7 @@ string print_string(std::vector<PajeFieldName>* fields, PajeDefinition *def) {
outstream
def
_name
outstream
def
_name
outstream
\n
outstream
\n
for
i
i
size
i
for
i
i
size
i
//try to find the name of the field we want to print
PajeFieldName
p
PajeFieldName
p
@@ -116,33 +116,33 @@ string print_string(std::vector<PajeFieldName>* fields, PajeDefinition *def) {
catch
out_of_range
e
catch
out_of_range
e
outstream
"name not found"
outstream
"name not found"
string
s
string
s
switch
def
_fields
i
_idtype
switch
def
_fields
i
_idtype
case
case
s
"int"
s
"int"
break
break
case
case
s
"hex"
s
"hex"
break
break
case
2
case
2
s
"date"
s
"date"
break
break
case
3
case
3
s
"double"
s
"double"
break
break
case
4
case
4
s
"string"
s
"string"
break
break
case
5
case
5
s
"color"
s
"color"
break
break
default:
default:
s
s
break
break
outstream
s
outstream
s
outstream
\n
outstream
\n
return
outstream
str
return
outstream
str
@@ -150,19 +150,19 @@ string print_string(std::vector<PajeFieldName>* fields, PajeDefinition *def) {
bool
check_definition
PajeDefinition
def
bool
check_definition
PajeDefinition
def
int
fdpresent
def
_fdpresent
int
fdpresent
def
_fdpresent
// If the definition requires Alias or Name,
// and the trace provide only one the both, it's ok
if
def
_fdrequired
CODE
_PajeFN_Alias
if
def
_fdrequired
CODE
_PajeFN_Alias
def
_fdrequired
CODE
_PajeFN_Name
def
_fdrequired
CODE
_PajeFN_Name
def
_fdpresent
CODE
_PajeFN_Alias
def
_fdpresent
CODE
_PajeFN_Alias
def
_fdpresent
CODE
_PajeFN_Name
def
_fdpresent
CODE
_PajeFN_Name
fdpresent
fdpresent
CODE
_PajeFN_Alias
fdpresent
fdpresent
CODE
_PajeFN_Alias
fdpresent
fdpresent
CODE
_PajeFN_Name
fdpresent
fdpresent
CODE
_PajeFN_Name
if
fdpresent
def
_fdrequired
def
_fdrequired
if
fdpresent
def
_fdrequired
def
_fdrequired
return
true
return
true
else
else
return
false
return
false
03a65cdb
@@ -82,23 +82,32 @@
@@ -82,23 +82,32 @@
* the need of the user.
#define FIELDNAME_SIZEMAX 32
#define FIELDNAME_SIZE 1
6
4
#define _PajeFN_Time 0
#define _PajeFN_Name 1
#define _PajeFN_Alias 2
#define _PajeFN_Type 3
#define _PajeFN_Container 4
#define _PajeFN_StartContainerType 5
#define _PajeFN_EndContainerType 6
#define _PajeFN_StartContainer 7
#define _PajeFN_EndContainer 8
#define _PajeFN_Color 9
#define _PajeFN_Value 10
#define _PajeFN_Key 11
#define _PajeFN_File 12
#define _PajeFN_Line 13
* Former type that are no longer used in Paje Format.
* Kept here for compatibility
#define _PajeFN_ContainerType 3
#define _PajeFN_EntityType 4
#define _PajeFN_EntityType 3
#define _PajeFN_Type 5
#define _PajeFN_SourceContainerType 5
#define _PajeFN_Container 6
#define _PajeFN_DestContainerType 6
#define _PajeFN_SourceContainerType 7
#define _PajeFN_SourceContainer 7
#define _PajeFN_DestContainerType 8
#define _PajeFN_DestContainer 8
#define _PajeFN_SourceContainer 9
#define _PajeFN_DestContainer 10
#define _PajeFN_Color 11
#define _PajeFN_Value 12
#define _PajeFN_Key 13
#define _PajeFN_File 14
#define _PajeFN_Line 15
* \brief Types for the fields
03a65cdb
@@ -6,13 +6,13 @@
@@ -6,13 +6,13 @@
** use, modify and/or redistribute the software under the terms of the
** CeCILL-A license as circulated by CEA, CNRS and INRIA at the following
** URL: "http://www.cecill.info".
** As a counterpart to the access to the source code and rights to copy,
** modify and redistribute granted by the license, users are provided
** only with a limited warranty and the software's author, the holder of
** the economic rights, and the successive licensors have only limited
** liability.
** liability.
** In this respect, the user's attention is drawn to the risks associated
** with loading, using, modifying and/or developing or reproducing the
** software by the user in light of its specific status of free software,
@@ -23,7 +23,7 @@
@@ -23,7 +23,7 @@
** their requirements in conditions enabling the security of their
** systems and/or data to be ensured and, more generally, to use and
** operate it in the same conditions as regards security.
** The fact that you are presently reading this means that you have had
** knowledge of the CeCILL-A license and that you accept its terms.
@@ -37,7 +37,7 @@
@@ -37,7 +37,7 @@
** - MARCOUEILLE Jule
** - NOISETTE Pascal
** - REDONDY Arthur
** - REDONDY Arthur
** - VUCHENER Clément
@@ -83,7 +83,7 @@ using namespace std;
_EventDefs[_##name]._fdrequired = required; \
i++; \
i++; \
std
map
std
string
int
_EvDefStr2Id
std
map
std
string
int
_EvDefStr2Id
std
map
std
string
int
_FTypeStr2Code
std
map
std
string
int
_FTypeStr2Code
@@ -98,34 +98,34 @@ ParserDefinitionPaje::ParserDefinitionPaje() {
_nbparsers
_nbparsers
if
_initialized
if
_initialized
_initialized
true
_initialized
true
// Initialize the list of EventDef's names
_EvDefStr2Id
insert
pair
string
int
"PajeDefineContainerType"
_PajeDefineContainerType
_EvDefStr2Id
insert
pair
string
int
_EvDefStr2Id
insert
pair
string
int
"PajeDefineEventType"
_PajeDefineEventType
_EvDefStr2Id
insert
pair
string
int
_EvDefStr2Id
insert
pair
string
int
"PajeDefineStateType"
_PajeDefineStateType
_EvDefStr2Id
insert
pair
string
int
_EvDefStr2Id
insert
pair
string
int
"PajeDefineVariableType"
_PajeDefineVariableType
_EvDefStr2Id
insert
pair
string
int
_EvDefStr2Id
insert
pair
string
int
"PajeDefineLinkType"
_PajeDefineLinkType
_EvDefStr2Id
insert
pair
string
int
_PajeDefineLinkType
_EvDefStr2Id
insert
pair
string
int
"PajeDefineEntityValue"
_PajeDefineEntityValue
_EvDefStr2Id
insert
pair
string
int
_EvDefStr2Id
insert
pair
string
int
"PajeCreateContainer"
_PajeCreateContainer
_EvDefStr2Id
insert
pair
string
int
_EvDefStr2Id
insert
pair
string
int
"PajeDestroyContainer"
_PajeDestroyContainer
_EvDefStr2Id
insert
pair
string
int
_EvDefStr2Id
insert
pair
string
int
"PajeNewEvent"
_PajeNewEvent
_EvDefStr2Id
insert
pair
string
int
"PajeNewEvent"
_PajeNewEvent
_EvDefStr2Id
insert
pair
string
int
"PajeSetState"
_PajeSetState
_EvDefStr2Id
insert
pair
string
int
"PajeSetState"
_PajeSetState
_EvDefStr2Id
insert
pair
string
int
"PajePushState"
_PajePushState
_EvDefStr2Id
insert
pair
string
int
"PajePushState"
_PajePushState
_EvDefStr2Id
insert
pair
string
int
"PajePopState"
_PajePopState
_EvDefStr2Id
insert
pair
string
int
"PajePopState"
_PajePopState
_EvDefStr2Id
insert
pair
string
int
"PajeSetVariable"
_PajeSetVariable
_EvDefStr2Id
insert
pair
string
int
"PajeSetVariable"
_PajeSetVariable
_EvDefStr2Id
insert
pair
string
int
"PajeAddVariable"
_PajeAddVariable
_EvDefStr2Id
insert
pair
string
int
"PajeAddVariable"
_PajeAddVariable
_EvDefStr2Id
insert
pair
string
int
"PajeSubVariable"
_PajeSubVariable
_EvDefStr2Id
insert
pair
string
int
"PajeSubVariable"
_PajeSubVariable
_EvDefStr2Id
insert
pair
string
int
"PajeStartLink"
_PajeStartLink
_EvDefStr2Id
insert
pair
string
int
"PajeStartLink"
_PajeStartLink
_EvDefStr2Id
insert
pair
string
int
"PajeEndLink"
_PajeEndLink
_EvDefStr2Id
insert
pair
string
int
"PajeEndLink"
_PajeEndLink
// Initialize the list of types available for field in EventDef declaration
_FTypeStr2Code
insert
pair
string
int
"int"
_FieldType_Int
_FTypeStr2Code
insert
pair
string
int
"int"
_FieldType_Int
_FTypeStr2Code
insert
pair
string
int
"hex"
_FieldType_Hex
_FTypeStr2Code
insert
pair
string
int
"hex"
_FieldType_Hex
_FTypeStr2Code
insert
pair
string
int
"date"
_FieldType_Date
_FTypeStr2Code
insert
pair
string
int
"date"
_FieldType_Date
_FTypeStr2Code
insert
pair
string
int
"double"
_FieldType_Double
_FTypeStr2Code
insert
pair
string
int
"double"
_FieldType_Double
_FTypeStr2Code
insert
pair
string
int
"string"
_FieldType_String
_FTypeStr2Code
insert
pair
string
int
"string"
_FieldType_String
_FTypeStr2Code
insert
pair
string
int
"color"
_FieldType_Color
_FTypeStr2Code
insert
pair
string
int
"color"
_FieldType_Color
@@ -135,14 +135,12 @@ ParserDefinitionPaje::ParserDefinitionPaje() {
INSERT_FNAME
Time
_FieldType_Date
INSERT_FNAME
Time
_FieldType_Date
INSERT_FNAME
Name
_FieldType_Int
_FieldType_String
INSERT_FNAME
Name
_FieldType_Int
_FieldType_String
INSERT_FNAME
Alias
_FieldType_Int
_FieldType_String
INSERT_FNAME
Alias
_FieldType_Int
_FieldType_String
INSERT_FNAME
ContainerType
_FieldType_Int
_FieldType_String
INSERT_FNAME
EntityType
_FieldType_Int
_FieldType_String
INSERT_FNAME
Type
_FieldType_Int
_FieldType_String
INSERT_FNAME
Type
_FieldType_Int
_FieldType_String
INSERT_FNAME
Container
_FieldType_Int
_FieldType_String
INSERT_FNAME
Container
_FieldType_Int
_FieldType_String
INSERT_FNAME
S
ourceContainerType
_FieldType_Int
_FieldType_String
INSERT_FNAME
S
tartContainerType
_FieldType_Int
_FieldType_String
INSERT_FNAME
DestContainerType
_FieldType_Int
_FieldType_String
INSERT_FNAME
EndContainerType
_FieldType_Int
_FieldType_String
INSERT_FNAME
S
ourceContainer
_FieldType_Int
_FieldType_String
INSERT_FNAME
S
tartContainer
_FieldType_Int
_FieldType_String
INSERT_FNAME
DestContainer
_FieldType_Int
_FieldType_String
INSERT_FNAME
EndContainer
_FieldType_Int
_FieldType_String
INSERT_FNAME
Color
_FieldType_Color
INSERT_FNAME
Color
_FieldType_Color
INSERT_FNAME
Value
_FieldType_Int
_FieldType_String
_FieldType_Double
INSERT_FNAME
Value
_FieldType_Int
_FieldType_String
_FieldType_Double
INSERT_FNAME
Key
_FieldType_Int
_FieldType_String
INSERT_FNAME
Key
_FieldType_Int
_FieldType_String
@@ -152,20 +150,28 @@ ParserDefinitionPaje::ParserDefinitionPaje() {
// Initialize the map between the field names and the associated id
_nbFieldNames
FIELDNAME_SIZE
_nbFieldNames
FIELDNAME_SIZE
for
i
i
FIELDNAME_SIZE
i
for
i
i
FIELDNAME_SIZE
i
_FNameStr2Id
insert
pair
string
int
_FieldNames
i
_name
i
_FNameStr2Id
insert
pair
string
int
_FieldNames
i
_name
i
// Former types no longer used in Paje format
_FNameStr2Id
insert
pair
string
int
"ContainerType"
_FNameStr2Id
insert
pair
string
int
"EntityType"
_PajeFN_EntityType
_FNameStr2Id
insert
pair
string
int
"SourceContainerType"
_FNameStr2Id
insert
pair
string
int
"DestContainerType"
_FNameStr2Id
insert
pair
string
int
"SourceContainer"
_FNameStr2Id
insert
pair
string
int
"DestContainer"
// Initialize the list of Events available
i
i
_EventDefs
resize
PAJE_EVENTDEF_SIZE
_EventDefs
resize
PAJE_EVENTDEF_SIZE
INSERT_EVENT
CODE2
Name
CODE2
Alias
CODE2
Container
Type
INSERT_EVENT
CODE2
Name
CODE2
Alias
CODE2
Type
INSERT_EVENT
PajeDefineEventType
CODE2
Name
CODE2
Alias
CODE2
Container
Type
INSERT_EVENT
PajeDefineEventType
CODE2
Name
CODE2
Alias
CODE2
Type
INSERT_EVENT
PajeDefineStateType
CODE2
Name
CODE2
Alias
CODE2
Container
Type
INSERT_EVENT
PajeDefineStateType
CODE2
Name
CODE2
Alias
CODE2
Type
INSERT_EVENT
CODE2
Name
CODE2
Alias
CODE2
Container
Type
INSERT_EVENT
CODE2
Name
CODE2
Alias
CODE2
Type
INSERT_EVENT
CODE2
Name
CODE2
Alias
CODE2
Entity
Type
INSERT_EVENT
CODE2
Name
CODE2
Alias
CODE2
Type
INSERT_EVENT
CODE2
Name
CODE2
Alias
CODE2
Time
CODE2
Type
INSERT_EVENT
CODE2
Name
CODE2
Alias
CODE2
Time
CODE2
Type
INSERT_EVENT
PajeCreateContainer
CODE2
Name
CODE2
Alias
CODE2
Time
CODE2
Type
CODE2
Container
INSERT_EVENT
PajeCreateContainer
CODE2
Name
CODE2
Alias
CODE2
Time
CODE2
Type
CODE2
Container
INSERT_EVENT
PajeDefineLinkType
CODE2
Name
CODE2
Alias
CODE2
ContainerType
CODE2
SourceContainerType
CODE2
Dest
ContainerType
INSERT_EVENT
PajeDefineLinkType
CODE2
Name
CODE2
Alias
CODE2
Type
CODE2
StartContainerType
CODE2
End
ContainerType
INSERT_EVENT
PajePopState
CODE2
Time
CODE2
Type
CODE2
Container
INSERT_EVENT
PajePopState
CODE2
Time
CODE2
Type
CODE2
Container
INSERT_EVENT
PajeSetState
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
INSERT_EVENT
PajeSetState
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
INSERT_EVENT
PajePushState
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
INSERT_EVENT
PajePushState
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
@@ -173,9 +179,8 @@ ParserDefinitionPaje::ParserDefinitionPaje() {
INSERT_EVENT
PajeSetVariable
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
INSERT_EVENT
PajeSetVariable
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
INSERT_EVENT
PajeAddVariable
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
INSERT_EVENT
PajeAddVariable
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
INSERT_EVENT
PajeSubVariable
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
INSERT_EVENT
PajeSubVariable
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
INSERT_EVENT
PajeStartLink
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
CODE2
Key
CODE2
SourceContainer
INSERT_EVENT
PajeStartLink
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
CODE2
Key
CODE2
StartContainer
INSERT_EVENT
PajeEndLink
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
CODE2
Key
CODE2
DestContainer
INSERT_EVENT
PajeEndLink
CODE2
Time
CODE2
Type
CODE2
Container
CODE2
Value
CODE2
Key
CODE2
EndContainer
@@ -183,7 +188,7 @@ ParserDefinitionPaje::~ParserDefinitionPaje() {
// Free the string to store extra names
for
i
FIELDNAME_SIZE
i
_nbFieldNames
i
