Commit 6395bcdf authored by Mathieu Faverge's avatar Mathieu Faverge
Comment the doc step
parent 7e9d8867
...@@ -4,7 +4,7 @@ stages: ...@@ -4,7 +4,7 @@ stages:
- build - build
- test - test
- sonar - sonar
- doc # - doc
build_spm: build_spm:
stage: build stage: build
...@@ -66,20 +66,20 @@ sonar_spm: ...@@ -66,20 +66,20 @@ sonar_spm:
only: only:
- master@solverstack/spm - master@solverstack/spm
pages: # pages:
stage: doc # stage: doc
dependencies: # dependencies:
- build_spm # - build_spm
script: # script:
- git submodule update --init --recursive # - git submodule update --init --recursive
- mkdir -p build # - mkdir -p build
- cd build # - cd build
- cmake .. -DBUILD_DOCUMENTATION=ON -DSPM_INT64=OFF # - cmake .. -DBUILD_DOCUMENTATION=ON -DSPM_INT64=OFF
- make docs # - make docs
- mv docs/out/html ../public/ # - mv docs/out/html ../public/
artifacts: # artifacts:
paths: # paths:
- public # - public
only: # only:
- master@solverstack/spm # - master@solverstack/spm
