Commit 03a3dd62 authored by Mathieu Faverge's avatar Mathieu Faverge
Add IJV expansion
parent f01e150d
...@@ -255,6 +255,7 @@ z_spmCSRExpand(const pastix_spm_t *spm) ...@@ -255,6 +255,7 @@ z_spmCSRExpand(const pastix_spm_t *spm)
* Second loop to compute the new colptr and valptr * Second loop to compute the new colptr and valptr
oldcol = spm->colptr;
oldrow = spm->rowptr; oldrow = spm->rowptr;
newrow = newspm->rowptr; newrow = newspm->rowptr;
for(i=0, row=0; i<spm->n; i++, oldrow++) for(i=0, row=0; i<spm->n; i++, oldrow++)
...@@ -298,7 +299,9 @@ z_spmCSRExpand(const pastix_spm_t *spm) ...@@ -298,7 +299,9 @@ z_spmCSRExpand(const pastix_spm_t *spm)
for(jj=0; jj<dofj; jj++, col++) for(jj=0; jj<dofj; jj++, col++)
if ( (spm->mtxtype == PastixGeneral) || ((i == j) && (col >= row)) ) if ( (spm->mtxtype == PastixGeneral) ||
(i != j) ||
((i == j) && (row <= col)) )
(*newcol) = col + baseval; newcol++; (*newcol) = col + baseval; newcol++;
#if !defined(PRECISION_p) #if !defined(PRECISION_p)
...@@ -313,16 +316,164 @@ z_spmCSRExpand(const pastix_spm_t *spm) ...@@ -313,16 +316,164 @@ z_spmCSRExpand(const pastix_spm_t *spm)
oldval -= (dofi-1); oldval -= (dofi-1);
newspm->gN = spm->gNexp; newspm->gN = newspm->n;
newspm->n = spm->nexp; newspm->gnnz = newspm->nnz;
newspm->gNexp = newspm->gN;
newspm->nexp = newspm->n;
newspm->gnnzexp = newspm->gnnz;
newspm->nnzexp = newspm->nnz;
newspm->dof = 1;
newspm->dofs = NULL;
newspm->layout = PastixColMajor;
assert(spm->loc2glob == NULL);//to do
(void)newval;
return newspm;
pastix_spm_t *
z_spmIJVExpand(const pastix_spm_t *spm)
pastix_spm_t *newspm;
pastix_int_t i, j, k, ii, jj, dofi, dofj, col, row, baseval;
pastix_int_t *newcol, *newrow, *oldcol, *oldrow, *dofs;
pastix_complex64_t *newval, *oldval;
if ( spm->dof == 1 ) {
return (pastix_spm_t*)spm;
if ( spm->layout != PastixColMajor ) {
pastix_error_print( "Unsupported layout\n" );
return NULL;
newspm = malloc( sizeof(pastix_spm_t) );
spmInit( newspm );
baseval = spmFindBase( spm );
dofs = spm->dofs;
oldval = (pastix_complex64_t*)(spm->values);
#endif
* First loop to compute the size of the vectores
if (spm->mtxtype == PastixGeneral) {
newspm->nnz = spm->nnzexp;
else {
newspm->nnz = 0;
for(k=0; k<spm->nnz; k++, oldrow++, oldcol++)
i = *oldrow - baseval;
j = *oldcol - baseval;
if ( spm->dof > 0 ) {
dofi = spm->dof;
dofj = spm->dof;
else {
dofi = dofs[i+1] - dofs[i];
dofj = dofs[j+1] - dofs[j];
if ( i != j ) {
newspm->nnz += dofi * dofj;
else {
assert( dofi == dofj );
newspm->nnz += (dofi * (dofi+1)) / 2;
assert( newspm->nnz <= spm->nnzexp );
newspm->rowptr = newrow = malloc(sizeof(pastix_int_t)*newspm->nnz);
newspm->colptr = newcol = malloc(sizeof(pastix_int_t)*newspm->nnz);
newspm->values = newval = malloc(sizeof(pastix_complex64_t)*newspm->nnz);
#endif
dofi = spm->dof;
row = spm->dof * i;
dofj = spm->dof;
col = spm->dof * j;
else {
row = dofs[i];
col = dofs[j];
if ( spm->layout == PastixColMajor ) {
for(ii=0; ii<dofi; ii++, row++, oldval++)
(i != j) ||
((i == j) && (row >= col)) )
(*newrow) = row + baseval; newrow++;
(*newval) = *oldval; newval++;
#endif
else {
for(ii=0; ii<dofi; ii++, row++)
for(jj=0; jj<dofj; jj++, col++, oldval++)
(i != j) ||
#endif
newspm->gNexp = newspm->gN; newspm->gNexp = newspm->gN;
newspm->nexp = newspm->n; newspm->nexp = newspm->n;
newspm->gnnzexp = newspm->gnnz; newspm->gnnzexp = newspm->gnnz;
newspm->nnzexp = newspm->nnz; newspm->nnzexp = newspm->nnz;
newspm->dof = 1; newspm->dof = 1;
newspm->dofs = NULL; newspm->dofs = NULL;
newspm->layout = PastixColMajor; newspm->layout = PastixColMajor;
assert(spm->loc2glob == NULL);//to do assert(spm->loc2glob == NULL);//to do
...@@ -339,7 +490,7 @@ z_spmExpand( const pastix_spm_t *spm ) ...@@ -339,7 +490,7 @@ z_spmExpand( const pastix_spm_t *spm )
case PastixCSR: case PastixCSR:
return z_spmCSRExpand( spm ); return z_spmCSRExpand( spm );
case PastixIJV: case PastixIJV:
return NULL;//z_spmIJVExpand( spm ); return z_spmIJVExpand( spm );
return NULL; return NULL;
