Commit 3e13d023 authored by MIJIEUX Thomas's avatar MIJIEUX Thomas
minor org fixes
parent 1b536648
...@@ -28,11 +28,11 @@ ...@@ -28,11 +28,11 @@
auto dr = fabulous::deflated_restart(/*nb_eigen_value=*/k, /*target=*/0.0); auto dr = fabulous::deflated_restart(/*nb_eigen_value=*/k, /*target=*/0.0);
auto eq = fabulous::equation(N, X, ldx, B, ldb); auto eq = fabulous::equation(N, X, ldx, B, ldb);
auto arn = fabulous::arnoldi_IB(); auto arn = fabulous::bgmres::ib();
auto ortho = fabulous::orthogonalization(/*iteration_count=*/3) auto ortho = fabulous::orthogonalization(/*iteration_count=*/3)
+ fabulous::OrthoType::RUHE + fabulous::OrthoType::RUHE
+ fabulous::OrthoScheme::IMGS; + fabulous::OrthoScheme::IMGS;
auto solution = fabulous::solve(eq, arn, ortho, dr); auto solution = fabulous::bgmres::solve(eq, arn, ortho, dr);
fabulous::print_info(solution); fabulous::print_info(solution);
return 0; return 0;
...@@ -451,6 +451,3 @@ ggplot(df, aes(x=nb_mvp)) + ...@@ -451,6 +451,3 @@ ggplot(df, aes(x=nb_mvp)) +
scale_y_log10() + scale_y_log10() +
ggtitle("GCR nrhs=6 m=90") ggtitle("GCR nrhs=6 m=90")
#+END_SRC #+END_SRC
#+results:
[[file:/tmp/babel-62751xo/figure6275YIP.png]]
...@@ -37,6 +37,9 @@ ...@@ -37,6 +37,9 @@
*** DONE fix LAPACKE_?tpmqrt workspace allocation bug *** DONE fix LAPACKE_?tpmqrt workspace allocation bug
* TODO Implement GCR Algorithm * TODO Implement GCR Algorithm
* TODO iterated orthogonalization stop criterion * TODO iterated orthogonalization stop criterion
* TODO find out how to link fabulous with parallel mkl with spack * DONE find out how to link fabulous with parallel mkl with spack
CLOSED: [2017-05-22 Mon 16:23]
see [[file:NOTES.org::*fabulous%20linking%20with%20lapacke/cblas%20kernels][fabulous linking with lapacke/cblas kernels]]
* TODO parallel(distributed) test case * TODO parallel(distributed) test case
test with maphys
* TODO distributed hessenberg (with chameleon) * TODO distributed hessenberg (with chameleon)
