Commit e416c301 authored by Mathieu Faverge's avatar Mathieu Faverge
Merge branch 'packaging' into 'master'
Packaging
See merge request !23
parents dc50f0a6 a037ee78
...@@ -1121,9 +1121,18 @@ generate_pkgconfig_file() ...@@ -1121,9 +1121,18 @@ generate_pkgconfig_file()
set(CPACK_SOURCE_GENERATOR "TGZ") set(CPACK_SOURCE_GENERATOR "TGZ")
set(CPACK_PACKAGE_NAME "chameleon") set(CPACK_PACKAGE_NAME "chameleon")
set(CPACK_PACKAGE_VERSION "${CHAMELEON_VERSION_MAJOR}.${CHAMELEON_VERSION_MINOR}.${CHAMELEON_VERSION_MICRO}") set(CPACK_PACKAGE_DESCRIPTION_FILE ${CMAKE_CURRENT_SOURCE_DIR}/README.md)
set(CPACK_PACKAGE_DESCRIPTION_SUMMARY "Chameleon is a C library providing parallel algorithms to perform BLAS/LAPACK "
" operations exploiting fully modern architectures.")
set(CHAMELEON_VERSION_PATCH ${CHAMELEON_VERSION_MICRO})
set(CPACK_PACKAGE_VERSION "${CHAMELEON_VERSION_MAJOR}.${CHAMELEON_VERSION_MINOR}.${CHAMELEON_VERSION_PATCH}")
set(CPACK_PACKAGE_FILE_NAME "${CPACK_PACKAGE_NAME}-${CPACK_PACKAGE_VERSION}") set(CPACK_PACKAGE_FILE_NAME "${CPACK_PACKAGE_NAME}-${CPACK_PACKAGE_VERSION}")
set(CPACK_SOURCE_IGNORE_FILES "build;.cproject;.dir-locals.el;.project;.pydevproject;.svn") set(CPACK_SOURCE_PACKAGE_FILE_NAME "${CPACK_PACKAGE_NAME}-${CPACK_PACKAGE_VERSION}")
set(CPACK_PACKAGE_VENDOR "Inria")
set(CPACK_PACKAGE_CONTACT "morse-devel@lists.gforge.inria.fr")
set(CPACK_RESOURCE_FILE_README ${CMAKE_CURRENT_SOURCE_DIR}/README.md)
set(CPACK_RESOURCE_FILE_LICENSE ${CMAKE_CURRENT_SOURCE_DIR}/LICENCE.txt)
set(CPACK_SOURCE_IGNORE_FILES "plasma-conversion;build;.cproject;.settings;.dir-locals.el;.project;.pydevproject;.svn;.git;.gitmodules;.gitlab-ci.yml")
include(CPack) include(CPack)
Some instructions about CHAMELEON usage Some instructions about CHAMELEON installation
This is a brief discussion about CHAMELEON usage. This is a brief discussion about CHAMELEON usage.
For more information, please read the document users_guide. For more information, please read the document users_guide.
...@@ -31,12 +31,11 @@ example : cmake /home/toto/chameleon -DCMAKE_INSTALL_PREFIX=/home/toto/install ...@@ -31,12 +31,11 @@ example : cmake /home/toto/chameleon -DCMAKE_INSTALL_PREFIX=/home/toto/install
threads : pthread threads : pthread
blas : refblas (http://www.netlib.org/blas/) or intel mkl blas : netlib, openblas, eigen or intel mkl
cblas : refblas (http://www.netlib.org/blas/#_cblas) or intel mkl cblas : netlib, openblas or intel mkl
lapack : refblas (http://www.netlib.org/lapack/) or intel mkl lapack : netlib, openblas, eigen or intel mkl
lapacke : refblas (http://www.netlib.org/lapack/#_standard_c_language_apis_for_lapack) lapacke : netlib, openblas or intel mkl
or the lapacke compiled in PLASMA project (http://icl.cs.utk.edu/plasma/) tmg : netlib, openblas or intel mkl
tmg : refblas (contained in lapack) or intel mkl
runtime : quark (http://icl.cs.utk.edu/quark/) or runtime : quark (http://icl.cs.utk.edu/quark/) or
starpu (http://runtime.bordeaux.inria.fr/StarPU/) starpu (http://runtime.bordeaux.inria.fr/StarPU/)
...@@ -47,10 +46,12 @@ optional libraries ...@@ -47,10 +46,12 @@ optional libraries
cuda : (https://developer.nvidia.com/cuda-downloads) cuda : (https://developer.nvidia.com/cuda-downloads)
cublas : comes with cuda (http://docs.nvidia.com/cuda/cublas/) cublas : comes with cuda (http://docs.nvidia.com/cuda/cublas/)
magma : (http://icl.cs.utk.edu/magma/) magma : (http://icl.cs.utk.edu/magma/) (version 1.6.2 recommended)
mpi : openmpi (http://www.open-mpi.org/) mpi : openmpi (http://www.open-mpi.org/)
FxT : linux package (libfxt) or releases here http://download.savannah.gnu.org/releases/fkt/ FxT : linux package (libfxt) or releases here http://download.savannah.gnu.org/releases/fkt/
These packages must be installed on the system before trying to configure/build chameleon.
Please look at the distrib/ directory which gives some hints for the installation of dependencies for Unix systems.
#!/bin/sh #!/bin/sh
git clone https://github.com/fpruvost/spack.git # Please follow http://morse.gforge.inria.fr/spack/spack.html for further instructions
cd spack git clone https://github.com/solverstack/spack.git
export SPACK_ROOT=$PWD . spack/share/spack/setup-env.sh
. $SPACK_ROOT/share/spack/setup-env.sh
cd -
spack install -v openblas spack install -v openblas
spack install -v starpu spack install -v starpu
spack load openblas spack load openblas
