Commit cdb0f0af authored by Mathieu Faverge's avatar Mathieu Faverge
Silent warnings
parent b2ca8009
...@@ -34,7 +34,7 @@ void chameleon_pzplrnk( int K, CHAM_desc_t *C, ...@@ -34,7 +34,7 @@ void chameleon_pzplrnk( int K, CHAM_desc_t *C,
RUNTIME_option_t options; RUNTIME_option_t options;
int m, n, k, KT; int m, n, k, KT;
int tempmm, tempnn, tempkk; int tempmm, tempnn, tempkk;
int lookahead, myp, myq; int myp, myq;
CHAMELEON_Complex64_t zbeta; CHAMELEON_Complex64_t zbeta;
CHAM_desc_t WA, WB; CHAM_desc_t WA, WB;
...@@ -30,10 +30,10 @@ void CORE_zplssq_quark(Quark *quark) ...@@ -30,10 +30,10 @@ void CORE_zplssq_quark(Quark *quark)
CHAM_tile_t *tileIN; CHAM_tile_t *tileIN;
CHAM_tile_t *tileOUT; CHAM_tile_t *tileOUT;
quark_unpack_args_5( quark, storev, M, N, tileIN, tileOUT );
assert( tileIN->format & CHAMELEON_TILE_FULLRANK ); assert( tileIN->format & CHAMELEON_TILE_FULLRANK );
assert( tileOUT->format & CHAMELEON_TILE_FULLRANK ); assert( tileOUT->format & CHAMELEON_TILE_FULLRANK );
CORE_zplssq( storev, M, N, tileIN->mat, tileOUT->mat ); CORE_zplssq( storev, M, N, tileIN->mat, tileOUT->mat );
...@@ -59,9 +59,9 @@ void CORE_zplssq2_quark(Quark *quark) ...@@ -59,9 +59,9 @@ void CORE_zplssq2_quark(Quark *quark)
int N; int N;
CHAM_tile_t *tileRESULT; CHAM_tile_t *tileRESULT;
assert( tileRESULT->format & CHAMELEON_TILE_FULLRANK );
quark_unpack_args_2( quark, N, tileRESULT ); quark_unpack_args_2( quark, N, tileRESULT );
CORE_zplssq2(N, tileRESULT->mat); CORE_zplssq2(N, tileRESULT->mat);
...@@ -24,7 +24,7 @@ ...@@ -24,7 +24,7 @@
#include <quark.h> #include <quark.h>
#if defined(CHAMELEON_RUNTIME_SYNC) #if defined(CHAMELEON_RUNTIME_SYNC)
#define QUARk_Insert_Task QUARK_Execute_Task #define QUARK_Insert_Task QUARK_Execute_Task
#endif #endif
#include "coreblas.h" #include "coreblas.h"
#include "core_blas_dag.h" #include "core_blas_dag.h"
...@@ -121,6 +121,7 @@ void INSERT_TASK_zplssq2( const RUNTIME_option_t *options, int N, ...@@ -121,6 +121,7 @@ void INSERT_TASK_zplssq2( const RUNTIME_option_t *options, int N,
STARPU_RW, RTBLKADDR(RESULT, double, RESULTm, RESULTn), STARPU_RW, RTBLKADDR(RESULT, double, RESULTm, RESULTn),
STARPU_PRIORITY, options->priority, STARPU_PRIORITY, options->priority,
STARPU_CALLBACK, callback, STARPU_CALLBACK, callback,
STARPU_EXECUTE_ON_WORKER, workerid,
#if defined(CHAMELEON_CODELETS_HAVE_NAME) #if defined(CHAMELEON_CODELETS_HAVE_NAME)
STARPU_NAME, "zplssq2", STARPU_NAME, "zplssq2",
#endif #endif
...@@ -26,20 +26,18 @@ testing_zplrnk( run_arg_list_t *args, int check ) ...@@ -26,20 +26,18 @@ testing_zplrnk( run_arg_list_t *args, int check )
static int run_id = 0; static int run_id = 0;
int hres = 0; int hres = 0;
double norm;
CHAM_desc_t *descC; CHAM_desc_t *descC;
/* Reads arguments */ /* Reads arguments */
int nb = run_arg_get_int( args, "nb", 320 ); int nb = run_arg_get_int( args, "nb", 320 );
int P = parameters_getvalue_int( "P" ); int P = parameters_getvalue_int( "P" );
cham_normtype_t norm_type = run_arg_get_ntype( args, "norm", ChamMaxNorm ); int N = run_arg_get_int( args, "N", 1000 );
int N = run_arg_get_int( args, "N", 1000 ); int M = run_arg_get_int( args, "M", N );
int M = run_arg_get_int( args, "M", N ); int K = run_arg_get_int( args, "K", N );
int K = run_arg_get_int( args, "K", N ); int LDC = run_arg_get_int( args, "LDC", M );
int LDC = run_arg_get_int( args, "LDC", M ); int seedA = run_arg_get_int( args, "seedA", random() );
int seedA = run_arg_get_int( args, "seedA", random() ); int seedB = run_arg_get_int( args, "seedB", random() );
int seedB = run_arg_get_int( args, "seedB", random() ); int Q = parameters_compute_q( P );
cham_fixdbl_t t, gflops; cham_fixdbl_t t, gflops;
/* We consider the gemm cost used in this operation as the cost */ /* We consider the gemm cost used in this operation as the cost */
cham_fixdbl_t flops = flops_zgemm( M, N, K ); cham_fixdbl_t flops = flops_zgemm( M, N, K );
