Commit c3f07d09 authored by Mathieu Faverge's avatar Mathieu Faverge
core_zlatm1: fix complex case
parent 75e821c9
1 merge request!266Fix many issues
...@@ -102,6 +102,7 @@ int CORE_zlatm1( int MODE, double COND, int IRSIGN, cham_dist_t DIST, ...@@ -102,6 +102,7 @@ int CORE_zlatm1( int MODE, double COND, int IRSIGN, cham_dist_t DIST,
unsigned long long int ran; unsigned long long int ran;
int i; int i;
double alpha, temp; double alpha, temp;
CHAMELEON_Complex64_t ctemp;
* Quick return if possible * Quick return if possible
...@@ -234,8 +235,8 @@ int CORE_zlatm1( int MODE, double COND, int IRSIGN, cham_dist_t DIST, ...@@ -234,8 +235,8 @@ int CORE_zlatm1( int MODE, double COND, int IRSIGN, cham_dist_t DIST,
#if defined(PRECISION_z) || defined(PRECISION_c) #if defined(PRECISION_z) || defined(PRECISION_c)
double t1 = CORE_dlaran( &ran ); double t1 = CORE_dlaran( &ran );
double t2 = CORE_dlaran( &ran ); double t2 = CORE_dlaran( &ran );
temp = sqrt( -2 * log( t1 ) ) * exp( I * 2. * M_PI * t2 ); ctemp = sqrt( -2 * log( t1 ) ) * exp( I * 2. * M_PI * t2 );
D[i] = D[i] * ( temp / cabs(temp) ); D[i] = D[i] * ( ctemp / cabs(ctemp) );
#else #else
if ( CORE_dlaran( &ran ) > .5 ) { if ( CORE_dlaran( &ran ) > .5 ) {
D[i] = -D[i]; D[i] = -D[i];
...@@ -249,9 +250,9 @@ int CORE_zlatm1( int MODE, double COND, int IRSIGN, cham_dist_t DIST, ...@@ -249,9 +250,9 @@ int CORE_zlatm1( int MODE, double COND, int IRSIGN, cham_dist_t DIST,
if ( MODE < 0 ) { if ( MODE < 0 ) {
for( i=0; i<N/2; i++ ) { for( i=0; i<N/2; i++ ) {
temp = D[i]; ctemp = D[i];
D[i] = D[N-1-i]; D[i] = D[N-1-i];
D[N-1-i] = temp; D[N-1-i] = ctemp;
