Commit afc24160 authored by PRUVOST Florent's avatar PRUVOST Florent
fix the generation of the pkgconfig file: missing header path + bad filter on -L/path/to/lib case
parent f345eb82
...@@ -95,13 +95,18 @@ MACRO(GENERATE_PKGCONFIG_FILE _file) ...@@ -95,13 +95,18 @@ MACRO(GENERATE_PKGCONFIG_FILE _file)
set(CHAMELEON_PKGCONFIG_LIBS_CPY "${CHAMELEON_PKGCONFIG_LIBS}") set(CHAMELEON_PKGCONFIG_LIBS_CPY "${CHAMELEON_PKGCONFIG_LIBS}")
set(CHAMELEON_PKGCONFIG_LIBS "") set(CHAMELEON_PKGCONFIG_LIBS "")
foreach(_dep ${CHAMELEON_PKGCONFIG_LIBS_CPY}) foreach(_dep ${CHAMELEON_PKGCONFIG_LIBS_CPY})
get_filename_component(dep_we ${_dep} NAME) if (NOT ${_dep} MATCHES "^-L")
STRING(REPLACE "lib" "-l" dep_we "${dep_we}") get_filename_component(dep_we ${_dep} NAME)
STRING(REPLACE ".so" "" dep_we "${dep_we}") message(STATUS "dep_we : ${dep_we}")
STRING(REPLACE ".a" "" dep_we "${dep_we}") STRING(REPLACE "lib" "-l" dep_we "${dep_we}")
STRING(REPLACE ".dylib" "" dep_we "${dep_we}") STRING(REPLACE ".so" "" dep_we "${dep_we}")
STRING(REPLACE ".dll" "" dep_we "${dep_we}") STRING(REPLACE ".a" "" dep_we "${dep_we}")
list(APPEND CHAMELEON_PKGCONFIG_LIBS ${dep_we}) STRING(REPLACE ".dylib" "" dep_we "${dep_we}")
else()
list(APPEND CHAMELEON_PKGCONFIG_LIBS ${_dep})
endif()
endforeach() endforeach()
list(REMOVE_DUPLICATES CHAMELEON_PKGCONFIG_LIBS) list(REMOVE_DUPLICATES CHAMELEON_PKGCONFIG_LIBS)
...@@ -6,7 +6,7 @@ includedir=${exec_prefix}/include/chameleon ...@@ -6,7 +6,7 @@ includedir=${exec_prefix}/include/chameleon
Name: chameleon Name: chameleon
Description: Dense Linear Algebra for Scalable Multi-core Architectures and GPGPUs Description: Dense Linear Algebra for Scalable Multi-core Architectures and GPGPUs
Version: @CHAMELEON_VERSION_MAJOR@.@CHAMELEON_VERSION_MINOR@.@CHAMELEON_VERSION_PATCH@ Version: @CHAMELEON_VERSION_MAJOR@.@CHAMELEON_VERSION_MINOR@.@CHAMELEON_VERSION_PATCH@
Cflags: -I${includedir} Cflags: -I${includedir} -I${includedir}/coreblas/include
Libs: -L${libdir} @CHAMELEON_PKGCONFIG_LIBS@ Libs: -L${libdir} @CHAMELEON_PKGCONFIG_LIBS@
Libs.private: @CHAMELEON_PKGCONFIG_LIBS_PRIVATE@ Libs.private: @CHAMELEON_PKGCONFIG_LIBS_PRIVATE@
Requires: @CHAMELEON_PKGCONFIG_REQUIRED@ Requires: @CHAMELEON_PKGCONFIG_REQUIRED@
